Should I be worried about electrolyte loss?
Discussion in 'Gen 2 Prius Technical Discussion' started by bredekamp, Mar 11, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    :doh:
    You are a cruel, mean, heartless fellow
    I wish you plenty of this
    :smow:
    We sure have plenty on the ground right now .... what a storm!
  2. bwilson4web
    15,596
    Or me. My hair is blowing in the wind ... along side I-81, I-95, Rt. 50, I-35, . . .
  3. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    I was not saying the Prius battery will die after 5 years. I said NiMH batteries last -more than- five years. That's in "normal use". The Prius babies the traction battery. It -should- last more than 10 years. But some will die sooner, some will die later.
    None will loose hair.
    There are none (second gen) older than 5 years in North America. It's too soon to predict when they will start failing. I -suspect- it will be 10-15 years "average" life. I also suspect it will cost around $2500 to replace once they do start commonly failing. Less than an automatic transmission.
    By then most of us will want a 3rd gen or a fourth gen model anyway.
