Smart Key won't start the car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by golfclubs44, Jul 14, 2014.
  1. john hone
    john hone New Member
    Oakland, Ca
    was this resolved?
    I have the exact same issue.
    John
    49,038
    welcome to priuschat! not to our knowledge. exact same issue?
  3. john hone
    Oakland, Ca
    Yes
    Alarm went off and after that fob does not open doors or start car without being inserted into dash.
    checked the 'set' button, checked the fob battery.
  4. usnavystgc
    3,159
    988
    Tucson, AZ
    You know, this really sounds like one of the buttons on your fob is stuck or inoperative. It sounds to me like its the alarm/panic button. If this were happening to me, I would likely take the fob apart and carefully examine all the buttons for the mechanical action of a properly opening and closing switch. If mechanics are ok, I would likely de-solder the alarm switch on the suspect fob and see if it works then.
  5. john hone
    Oakland, Ca
    Thanks, I will try that.
  6. bisco
    49,038
    and if that doesn't work, check the 12 volt.
  7. bisco
    49,038
    do you only have one fob?
  8. john hone
    Oakland, Ca
    thanks
  9. john hone
    Oakland, Ca
    buttons working freely, could not take apart
  10. john hone
    Oakland, Ca
    No two, although we only use one, the 2nd has never been used in 5 years. Found it yesterday and tried it with a new battery and it was the same....dead.
  11. usnavystgc
    3,159
    988
    Tucson, AZ
    Then how are you going to change the battery if you can't take it apart? These fobs do come apart. I don't have one with me right now but could someone help this gentleman figure out how to take it apart?
  12. john hone
    Oakland, Ca
    Thanks for the reply, I have no problem changing the battery in the fob but cannot dismantle it further than taking the battery cover off. From what I am reading in other posts I will have to take it to the dealership to reprogram.
