Southern California Edison raise from .13 to .14 per Kilowatt!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by LA2014Prius, Jul 18, 2014.
  1. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    Hi All,
    Just saw this when I went online to SCE site this morning. Looks like my next bill will be .14 per kilowatt instead of .13 even though I am still in tier 1.
    Wondering if this affect my area only or the whole southern California.
    For those of you that are outside of California, how much do you pay?
  2. xliderider
    xliderider Senior Member
    7,849
    3,102
    Honolulu, HI
    I believe our rates are around 35 cents per kilowatt. :eek:
    I still see a lot of Teslas though. :D
    SCH-I535
  3. LA2014Prius
    103
    2014 Prius Plug-in
    WHAT !!!! 35 Cents?!?!?!
    My July bill will be .14 per kilowatt but starting August, it will be .15 per kilowatt... Must be me... I bought a car that use electricity... LOL
  4. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Our's were 10 cents, then the plant had a fire that shut down 80% of its output, they raised it to 12 or something and expect it to go down to 10c again next year.
    Doesn't matter since I am running 10KW of solar. Meter spins backwards during the day.
  5. Phausto
    Phausto Junior Member
    75
    16
    Pacific NW
    EIA - Electricity Data
    link Seattle, $0.08. Currently putting those savings aside for a Tesla Model III...
    rxlawdude likes this.
  6. woody weaver
    woody weaver Junior Member
    68
    16
    Frederick, MD
    2014 Prius Plug-in
    Mine is about ten cents per KWHr, and I use about a megawatthour a month. (1.47 kilowatt average consumption...)
  7. bisco
    48,995
    wow, you guys have it cheap, ours is .16/kwh. okay, not you xliderider.:cool:
  8. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    1,000kWh a month? You must have a large home or a grow room. :)
  9. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Con Edison in nyc is about 31-32 cents a kWh when you break down your bill, with no ev incentives being offered. It pays to just run gas around here. Shame.
  10. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    I'm on PG&E Time of Use E-6 rate and have a 2.8 kW AC solar panel installation so my cost is $0.105/kWh when charging before 10 AM in the Summer and almost all day in the Winter. That works out really well with my 58% EV operation. As Paradox says the low 30 cent region is the brake-even point for any EV savings over gas.
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Crazy. I was down to about 100 watts in our prior home. This new home is about double that, but hopefully not for long.
    I come up with different numbers.
    HV mode is about 7 cents a mile -- $3.50/50 mpg
    If EV is ~ 3.5 miles per kWh in pleasant weather, then the break-even is 7*3.5 = 24.5 cents a kWh.
  12. CharlesH
    2,785
    1,152
    Roseville, CA
    I am on a tiered Time-of-Use plan which varies from $0.04/kwh at tier 1 off-peak to $0.54/kwh at tier 3 peak, so I really don't know how much to say a charge costs. :confused:
  13. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    PSE&G (PEG) in NJ is ~17c/kwh--standard residential rate.
  14. CaliforniaBear
    1,179
    289
    Northern California
    Where can I get gas for $3.50/gallon?
    HV mode 4.00/50 mpg gives 8 cents/mile
    Full charge from the wall is about 3 kWh for 12.5 miles = 4.17 miles per kWh
    Then 8 * 4.17 = 33.3 cents a kWh in sunny and very dry California
    Imagine the calculation for Hawaii.
  15. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Va. is close to national avg around 12 cent/kwhr
  16. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    About two years ago we were 7.0c/kwh. In March it was 9.3c/kwh. Today's bill was 11.6c/kwh. All base rate. Tax adds a penny or two /kwh. Last winter average of 2000 kwh per month for 5 months. Summer about 200 to 250 kwh. All electric house. First Energy/MonPower
  17. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    About $0.25/kWh here in suburban NYC ConEd territory. Costs me more to charge than use gas, but I prefer it anyway. And I make more than the car uses with my solar. But no smart metering, except for future promises.
  18. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    11 cents a kWh in Pahrump, Nv. About 60 miles west of Las Vegas where it is also 11 cents. Doesn't matter to me because I am running 9 kW solar system. If they keep raising it I will add another 9 kW plus batteries.
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    National average for petrol in the US is about $3.50. <<shrug>>
    We should be clear what the calculation means: any electric rate *below* the calculated cost per kWh favors electricity.
    CaliforniaBear likes this.
  20. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    In my location I would expect any EV (PiP, Volt, Leaf, Tesla) could be operated for 2 to 3 cents per mile. Prius C, V, and HB models @50MPG and $3.75 per gallon for 7.5 cents per mile.
    Actual 09 Lexus 450h awd and 03 Chevy Cavalier @25 mpg and $3.75 per gallon for 15 cents per mile. Neither of these are driven for efficiency or by me. Lexus averages 20 miles per day and the Chevy around 3 gallons per month
    I live in the land of coal and frak gas yet my electricity has gone up 65% in just last few years. And where is this cheap natural gas I here about? Certainly not here as it's up 50%.
