Speedometer accuracy - reads faster than real mph?
Discussion in 'Prius c Main Forum' started by WiscPriusc, Oct 8, 2012.
  1. WiscPriusc
    WiscPriusc Member
    63
    37
    Wisconsin
    Our city has installed a number of auto-radar "you are traveling ___ mph" stations in the last couple years. While not the most accurate of devices, so far they seem to be reading me slower than my C speedometer says. Any other C drivers noticed this? I have the standard 15" steel wheels on my Two.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    If anything the speedo is going to read high. A GPS unit is a better reference than an uncalibrated sign.
  4. chicagoaficionado
    chicagoaficionado Junior Member
    57
    23
    Chicagoland
    Maybe eco mode tells ya you are going faster than you are so ya let off the gas... Hehe jokes
    WiscPriusc likes this.
  5. Mr Gee
    Mr Gee Member
    88
    30
    Australia
    I believe it is about 5% over-reading. GPS nanny on the screen verbal warnings is what I go on.
  6. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Can't speak for the US, but Australian regulations (ADR 18/03 specifically) implement the European Standard, UNECE Regulation No. 39/00.
    The practical upshot of this standard is:
    • Speedometers must never show a speed less than the vehicle's true speed. There is no acceptable tolerance for showing a speed lower than the true speed.
    • Acceptable tolerance for displaying a speed greater than the vehicle's true speed is 10% + 4 km/h.
    Two practical examples:
    • If a vehicle's true speed is 80 km/h, the acceptable readings on a speedometer are from 80 km/h to 92 km/h.
    • If a speedometer shows 100 km/h, this could mean the vehicle's true speed could be anywhere between ~87.3 km/h and 100 km/h.
    I've yet to cross-check my speedometer against a GPS, but I did recently time a run past a series of odometer check mileposts with the cruise control holding 110 km/h. I missed the first one, but recorded 2 minutes 16.35 seconds to cover 4 km. That equates to an average speed of 105.6 km/h. You need to allow some tolerance for the accuracy of my use of the stopwatch, but this was the kind of result I expected.
  7. crebble
    crebble Member
    176
    46
    Shohola PA
    My speedo typically reads 1-2 MPH high compared to GPS.
  8. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    My C reads 1-ish mph faster than the Scangauge or traffic radar.
  9. oberkc
    oberkc Junior Member
    22
    Ohio
    My prius C speedometer is very close to "truth". I have concluded that my various GPS and public RADAR displays are pretty accurate. My speedometer matches very closely.
    I am thinking that the prius comes with a couple of different wheel and tire size combinations. Perhaps this would explain minor differences?
  10. Mr Incredible
    955
    506
    Neb
    The final circumference of the tire/wheel combinations are the same.
  11. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Most speedometers read high. The obvious examples are German cars and motorcycles, which are known to read up to 10% high [e.g. 77 indicated, 70 actual]. American and Japanese speedometers are typically closer to accurate. I wouldn't be surprised in the slightest if the Prius C reads a little bit optimistic.
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    All Prii do this. The GenII was 2mph too fast and the GenIII is between 1mph and 2mph too fast depending on the wheels and tires that came on the car. The 17" wheels show a larger error than the 15" wheels due to the 17" tires being shorter.
  13. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    mine reads 1 MPH higher then GPS on my C
