Steering wheel noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by GT81, Apr 11, 2013.
  1. GT81
    GT81 New Member
    2013 Prius v wagon
    My 2012 Prius V Wagon has developed a "cracking" sound when turning the steer at standstill or low speeds. Does anyone have the same problem? If is, how does one fix this?
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    One drives into a competent dealer;)
  3. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Is the sound coming from inside the car or outside?
    SPH-D710 ? 2
  4. jdenenberg
    jdenenberg EE Professor
    3,839
    1,829
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Try to sense if the noise is from the steering wheel itself as my 2004 has some looseness between the outer material and the steel core which produces some noise. If the noise comes from the steering column, get thee to the dealer at once as there have been problems and a recall in earlier model Prii steering columns.
    JeffD
  5. GT81
    GT81 New Member
    2013 Prius v wagon
    'Golly gee Batman, we've got ourselves a Joker!'
    Thanks Jeff, you might be on to something. I thought I saw the outer material behind my steering wheel move during the afore mentioned "cracking" noise. What was the deal with those earlier models then?
    Btw, I have an appointment scheduled with a Toyota dealer in 2 weeks, so I'll get 'em to have a look at this as well.
  6. jdenenberg
    3,839
    1,829
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I was talking about the material covering the steering wheel itself in my case. Check that the steering wheel tilt adjustment is locked down.
    There was a recent recall on Gen2 steering columns. Some metal fatigue caused looseness in the assembly. I had mine repaired before the recall and am waiting for a reimbursement of almost $1000 (there is a paperwork gauntlet that takes weeks to traverse).
    JeffD
  7. GT81
    GT81 New Member
    2013 Prius v wagon
    Okay, well the steering wheel's casing seems fine. It's basically that the plastic behind it moves along with the cracking noise. Steering itself seems fine, hopefully it wont deteriorate untill the appointment...
    Sounds dangerous. Hope you get your money back!
  8. jdenenberg
    3,839
    1,829
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I only know of one Prius owner that reported a loss of steering control, but in that case symptoms were noticed and ignored too long. We all need to be aware of and new noises coming from steering, suspension or braking systems and take remedial action for safety.
    Since Toyota Customer service asked for some additional documentation (Visa receipts - proof of purchase) 6 weeks after the first round, I see some light at the end of the tunnel.
    JeffD
  9. toyotechwv
    474
    251
    Princeton, WV
    Have you had any non-OEM accessories installed in that area? Remote start, scangauge, etc.
    SPH-D710 ? 2
  10. GT81
    GT81 New Member
    2013 Prius v wagon
    No, nothing of the sort. I'll let you guys know what the dealer says in 2 weeks.
  11. GT81
    GT81 New Member
    2013 Prius v wagon
    Problem solved under warantee bij local Toyota dealer. Seems that one of the 6 bolts that holds the whole steering-column in place was loose. No idea how that is possible, only have like 14.000 miles on the Wagon. The mechanics also had no idea how this could happen, but I still find it immensly scary.
    Chazz8 and PLSPUSH like this.
  12. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Anyone know the location of these bolts? Can they be checked easily or are they hidden away?
  13. Emcguy
    Emcguy Member
    176
    29
    Australia
    My 2012 v has just developed the same thing. There is still the same amount of slop (deadzone) but it is now accompanied with a knock. The sound can be reproduced stationary and +/- 5 degrees. I'll post Toyota's response, of course.
  14. ursle
    ursle Gas miser
    1,049
    192
    NH
    Golly, a competent dealer after all, whew
  15. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    It could happen if they didn't torque them properly - particularly if the running torque was too high. Did they remove the bolts before retightening them? High running torque is a fairly common problem where bolts eventrually loosen in my experience. Clamping force that is much lower than expected allows sliding of the item intended to be constrained. The sliding loosens the bolt. Step and repeat. Usually caused by bad threads or crap in them.
  16. Emcguy
    Emcguy Member
    176
    29
    Australia
    OK, so we went to the dealer today and it ended up been that two of the steering wheel nuts were loose. We own a 2012 v(agon) as well as a 2012 yaris and I have to say, I'm a little bit disappointed in Toyota. I expected perfection in the first 3 years but we have already had minor issues as well at squeeks and rattles.
  17. MarieG
    MarieG New Member
    I have the same problem with my Prius V 2014. The steering wheel nuts were fine. They replaced the spiral cable. I still hear the noise. Any more suggestions?
  18. mediahound
    903
    155
    My dealership told me the noise was normal...
    I'm just ignoring it unless it gets worse.
  19. MarieG
    MarieG New Member
  20. MarieG
    MarieG New Member
    My son has a Prius V 2013 and his doesn't have the noise. I don't believe it is normal. My Toyota mechanics told me to bring it here when I hear the noise and take them for a ride. I made a video of the noise and steering wheel, but they said they have to hear the noise themselves. I'm frustrated!
