Steering wheel noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by GT81, Apr 11, 2013.
  1. Cap'n
    Cap'n Junior Member
    34
    TX
    I'm throwing this recent 2015 experience into this 2013 pot in case anyone is doing "power steering" searches.)
    Anybody else had the following experience with their Prius v?
    At 46K miles my 2012 Prius v SUV recently developed a "knock" when moving the steering wheel. It's not a problem with the steering wheel itself; somewhere else in the system. The car handles & steers just fine as always.
    Last week at 48K miles, I took it into my Toyota dealer.
    Their first guess was the intermediate shaft might need to be replaced. However, when they actually checked out the problem (no $ charge), they determined the whole steering column needed to be replaced. Total cost $1,700 (!!; parts, labor, tax). I was in such shock at the dollars, I can't honestly say I even remember their description of the cause of the problem. Just that the cost is so high because the steering column includes an electric motor.
    Two separate Service Advisors did assure me the repair was NOT safety related, so the decision to repair or not was simply a matter of my choice. It doesn't bother me $1,700 worth, so I continue to drive the car. Again, the car handles just fine without any issue other than an occasional "clunk" felt when turning the steering wheel.
    (NOTE: They said they had an Avalon {year?} in that day for the same repair.)
  2. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    If they say it's not a needed repair, and it doesn't bother you that much, I would just not do anything unless it gets worse. Save the $1,700!
  3. flynz4
    flynz4 Member
    329
    Portland, OR
    2015 Prius v wagon
    Question: If you had purchased the extended warranty coverage from Toyota... would this have been covered?
    /Jim
  4. totita
    totita Junior Member
    28
    New Jersey
    My 2012 Prius v (lowercase v for the Prius v wagon) developed the steering knock. It gradually got worse over the past 6 months. Decided to take a look and finally I fixed it by tightening one bolt. You need 1a 12 mm wrench and open the lower panned above the pedals held by two screws. I also applied some blue thread locker on the receiving end but was not comfortable to remove the bolt completely. Easy fix but very disappointing for a Toyota! Happy I saved some money, in NJ any dealership will have probably replaced the steering column.
  5. Air_Boss
    Air_Boss Senior Member
    3,917
    1,069
    New Yawk
    Steering column U-joint bolt?
