Stinkbug in Tail Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CSMgms, Jun 21, 2014.
  1. CSMgms
    CSMgms Junior Member
    Not sure if this is more funny than it is annoying. A stinkbug managed to work its way inside my tail light. My plan is to follow the DIY instructions to remove the tail light. I will then purge/dump the bug. Any ideas on short cuts? Vacuuming via the bulb access port did not work.
  2. El Dobro
    El Dobro A Member
    7,106
    3,282
    Hopefully, the thing didn't lay eggs in there. That would really stink.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  4. El Dobro
    El Dobro A Member
    7,106
    3,282
  5. CSMgms
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    Use Google search, it's much better. Use priuschat.com as one of the search parameters.
    SCH-I535
    CSMgms likes this.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    UGH! That is just so wrong! What a PIA!
    Good luck getting the carcass out!
