Streaming Android Phone Music to 2005 Prius Bluetooth with Nav
Discussion in 'Gen 2 Prius Main Forum' started by tleisher, Mar 3, 2010.
  1. tleisher
    tleisher New Member
    Hey everyone,
    I bought a 2005 Prius with Touchscreen Navigation, and I got it to sync with my bluetooth phone (The T-Mobile G1).
    The bluetooth phone feature works great, but I want to be able to stream music that I loaded onto the phone.
    Is there a setting or something to enable this? I tried to pair it, and then just start playing music but the system didnt pick it up.
  2. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    The BT in Gen 2 Prius does not have A2DP. You'll need a device like below. And if your 2005 has an Aux in, you can connect this thing directly to the Aux port. If not, you can fall back to the FM Transmitter.
    BTW, the G1 has A2DP Bluetooth?
    http://www.amazon.com/Satechi-Bluetooth-Hands-free-Transmitter-supported/dp/B000NVYVRO
  3. raholco
    raholco Ailurophile
    51
    Yessir-G1 has A2DP.
    As an aside, I would not connect the G1's line-level output-somehow, HTC borked the audio section and its very noisy at low settings.
  4. zenMachine
    3,355
    300
    I had the G1 when it first came out. I'm not sure if it had A2DP in the first version. (I wasn't too interested in A2DP back then anyway).
    I used to connect the G1 to the Prius Aux in using an adapter that plugs into the charger port for both charging and Aux out purposes. There were no sound issues at all.
    Does your 2005 have an Aux line-in port?
  5. raholco
    raholco Ailurophile
    51
    I have a 2009 and it does have an aux input.
    You're right, the initial Android 1.0 did not have A2DP-I think Cupcake (1.5) brought A2DP to the G1.
  6. zenMachine
    3,355
    300
    Ah, OK. Thanks for that. I may get my G1 upgraded then.
    BTW, this is the charger/adapter I used with the G1 to play audio in the Prius:
    http://www.amazon.com/dp/product/B0011WDLES?tag=priuschatcom-20
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    plug it in to aux port. i tried BT streaming and the audio quality... was not desirable. i doubt if the phone or the car makes that much of a difference. wireless streaming of music was probably the issue.
    dont get me wrong, did sound good when it worked good, but had a lot of outside interference. moving the phone around helped a bit, but it seemed like i had to reposition too much. i got lazy since i have audio plugged into my i pod anyway
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Warning! If you update the Android operating system you will loose phone connection to the car! They broke it in the first update, and now, five updates later, still haven't fixed it. Check out the android system Wiki. Lots of discussion on hacks to get it to work.
  9. raholco
    raholco Ailurophile
    51
    Your phone should have already been upgraded over the air-the current base code is 1.6 (Donut), but there's rumors that 2.0 is coming soon.
  10. raholco
    raholco Ailurophile
    51
    I have not had an issue with my G1 and the Prius-and I've been through all of the OS upgrades.
