Substitute bulbs for H11 low beams on Gen IIII've
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Aegison, Jun 28, 2010.
  1. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I'm surprised at the comments of poor light output from the OEM lights. I'm thrilled with the stock light output of my Prius. It is very bright with a wide beam pattern. That being said I've always improved on the stock light output if possible. I will try the H9 bulbs as I did HIR bulbs in my 09 Corolla. I'm even doing a proper HID retrofit from The Retrofit Source. It will provide the best light output but is not plug-n-play.
  2. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    It's the base of the bulb....I know you asked this like 5 months ago, but there's another thread on here that shows pictures. You have to do a slight trim of the "ears" on the base.
    http://priuschat.com/forums/gen-iii...98-need-geniii-owner-test-headlight-idea.html
    There's the link that shows some pictures. As I mentioned there, I used small wire cutters because the ears were plastic on those HID bulbs.
    I've slacked, and still haven't gotten the comparison pictures done yet. Maybe the upcoming Presidents Day weekend I can do it.
  3. sofistikats
    sofistikats New Member
    Burlingame, CA
    Does anyone know if the H11 LED bulbs on iJDMTOY's website are compatible?
  4. Azimuth
    Azimuth Member
    136
    32
    Austin
    Most LED SMD "bulbs" will only put out around 500 Lumen. The H11's (stock) are somewhere around 1300 Lumen. H9's are around 2100 Lumen.
    I'm debating installing H9 bulbs but don't want to melt the housing.
    has anyone actually run the H9's for any extended period of time?
  5. movingforward
    movingforward Member
    169
    The Great White North
    HID 4300K at 35W will give you 3000 lumens of output, for the gen3 it is pretty much plug and play, only problem is the squirrel finder in that projector housing will cause glare to on coming drivers. HIR bulb will not work for gen3's low bean, only for works for the high beam, unless some serious modification is done to the base and plug...i think...
  6. subjective
    subjective Member
    203
    30
    The OEM H11 bulb in our new(19Dec11) Prius lll, was either mounted incorrectly or shook loose to cause the low beam projector to warp from heat. So the projector is heat sensitive and can warp. This is an expensive and time consuming problem. Our service mgr. at 250 miles repaired this under warranty which was a great relief to us ever though it was not our fault.
  7. CrniMilorad
    CrniMilorad Junior Member
    Technology
    I have these H9 installed for a couple months and I am quite happy.
    It has more light about 30% at least.
    It is winter and i see no difference regarding temperature.
    I have read comments that there should be not problems at summer too.
  8. xliderider
    xliderider Senior Member
    7,904
    3,136
    Honolulu, HI
    I ran H9 bulbs in both of my cars for over a year before switching to HIDs (blocked the squirrel finder cutouts). No problems with the H9 bulbs in the time they were installed.
    #28 xliderider, Feb 21, 2016
    CrniMilorad likes this.
  9. r.p.
    r.p. Junior Member
    Late to the party, but a simple question: Are H11 low beam bulbs the same as H11 fog lamp bulbs, i.e. can they be interchanged?
