Technical Question dc/dc converter 12v max amps?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ilikesilvercars, Jun 24, 2013.
  1. Ilikesilvercars
    Ilikesilvercars Junior Member
    37
    Does anyone know what the maximum number of amps the device that converts energy in the traction battery to the 12v system is rated at? Basically trying to determine which size inverter to get. So I'd like to know max and then max recommended, as the latter is likely lower in order to be safe and avoid premature failure of the device. Thanks
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Lots of threads here on doing this - search on inverter.
    The consensus seems to be that a 1 kilowatt inverter is about the maximum safe size.
  3. Ilikesilvercars
    37
    Thanks, that's good enough for me. If anyone has technical documentation at their disposal it's worth an upvote :)
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Like ftl said, if you will use the Search function and search for inverter you will find more than enough technical documentation.
  5. prius_in_pa
    prius_in_pa Junior Member
    208
    27
    I don't know the answer to your question. However, to be on the safe side, I always hook an additional 12v car battery in parallel to the 12v battery in the Prius, wherever I'm using an inverter. The extra battery is there for handling peak loads. When I'm not using peak loads, the dc to dc converter would charge both batteries.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It has been posted on this forum but like the rest of you I forget the value - 70 Amps?
  7. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    The max amp output is 120 amps. but there is a 100 amp fuse in the line to the aux battery.
  8. Ramialmughrabi
    Ramialmughrabi New Member
    US
    Is this amps can handle 3900w amplifier and 2 subs pioneer 1400w
  9. Currahee
    Currahee Member
    103
    33
    CT
    No, since 100A * 12V = 1200W
  10. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    According to the Manual:
    Fuse for DC/DC converter is 5A. 12V*5A=60W
    The recommended charging rates for the 12V is 4.2 A max.
  11. ChapmanF
    15,111
    That's not the fuse you're looking for. :)
    There is a 5 amp fuse labeled "DC/DC-S" (names from the 2010 wiring diagram), but that is only protecting the converter's remote-sense lead. A funny thing happened in Gen 3 ... in both Gen 1 and 2, the remote sense lead went all the way back to the battery in the rear and attached to the positive battery post through a separate 5 amp fuse, so it really was sensing the voltage right at the battery. The Gen 3 converter still has a remote sense lead, but they must have decided they didn't really need remote voltage sensing after they added a battery temperature sensor, so the converter's "remote sense" lead now senses ... the bus in the engine compartment fuse box, about six inches away. :)
    The fuse labeled "DC/DC" (which you'd hardly recognize as a fuse, it's part number 90982-08297 and pretty much buried inside the whole front right corner of the engine compartment fuse box) is rated 125 amps.
    Bear in mind those 125 amps have to run all the 12 volt stuff in the whole car, on top of whatever accessories you are hoping to add. Also, the DC/DC converter has a "help! ease up!" output, called IDH (it's a blue wire from connector A59 pin 2 in a 2010). The HVAC controller (at least) watches that signal; if the weather is cold, the engine isn't warmed up yet, and the electric heat is on, the HVAC controller will drop it temporarily if the converter asserts IDH.
    If you're adding a significant load somewhere, you could consider having it watch IDH also. Alternatively, you might think about just putting a red LED on the IDH signal, somewhere easy to see, and then you can watch it and decide how you want to reduce your load if you see it come on.
    -Chap
  12. Ramialmughrabi
    US
  13. ChangeMachine
    ChangeMachine New Member
    Portland, OR
    ChapmanH said something very interesting. I think. ;) Unfortunately, if it answered the question I am not smart enough to decipher it. Can anyone clarify what the max amperage applied to the 12v battery would be in a gen3 / 2010? Something less than 125A, I presume. Do you reckon it's less than 20A? 5A?
    Cheers
  14. ChapmanF
    15,111
    It seems like you might be looking for this thread.
    -Chap
  15. ChangeMachine
    Portland, OR
    Thanks a ton for posting that link, CF! I did search, but never saw that. Short of seeing it in the manual, I'd say that's evidence enough that the max amperage is 60A, maybe 70A. Sounds believable. Unfortunately it does eliminate a lot of Lithium batteries I'd been eyeing as a replacement for the 12v, but maybe not the EarthX with it's max of 60-something. But that's for another post, I suppose.
  16. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Nominal voltage of the Prius is around 14v on ready. That will change your equation.
  17. ChapmanF
    15,111
    I think Bob Wilson posted some trial results some years back showing that the voltage will sag a bit as the current is approaching the limits.
    -Chap
