The C needs new shoes!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TC400, Nov 16, 2014.
  1. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I'm starting to look at summer tires for our Camry hybrid. The Turanza has about the lowest tread wear rating anywhere on Tirerack. 260
    I looked at the Yokahama Avid Ascend Blue earth, which I believe is on my Prius. Comes in at 740. Our old Envigors lasted 4-5 years now, probably around45 thousand miles. Fronts scrubbed.
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    IMO there isnt reason to buy high threadwear tire if you dont drive much. After 3 years rubber is getting too hard and brittle, it is either wears too fast or doesnt hold the road. So the 60k tire and 90k tire will matter not at that point. This is based on year around use. If you switch to winter tires you see 4?
  3. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    ^That longer term thinking is something I hadn't considered, but I should given my dry, hot climate.
    My bad Bridgestone experience with the OEMs had me steering clear this go-around anyway. ;)
  4. cyclopathic
    3,292
    547
    2014 Prius c
    Nokian also makes newer WRG3 in direct replacement size but those more expensive. They are marked LRR and supposed to last much longer than older WRG2. WRG2 were awesome in wet, ice and snow, but didn't like heat; would melt off in summer. Something to consider if you live in snowmelt.
  5. Stevevee
    821
    224
    Vermont
    The new Pirelli Cinturato P7 All Season Plus seems to get stellar reviews.
  6. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    They must be brand new. I checked their site not long ago and they had no tires for the c. At least not in OEM size.
  7. Oldwolf
    Oldwolf Prius Enthusiast
    816
    106
    NC
    2016 Prius v wagon
  8. Mendel Leisk
    38,316
    For the TPMS I'd tell them to just leave it alone.
    cyclopathic likes this.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    Just make sure they know how to install tires with TPMS sensors (they should seat rubber to avoid damaging sensors) and they give you warranty. I had one broken off by installer. It was flying around in tire giving clunking sound at low speeds and by the time it stopped working it was too late to take it back. Cost me a new sensor ($31) and reprogramming tool ($150) to fix it, bummer.
  10. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I have about 40k and still on the OEM 15 inchers!
  11. orenji
    orenji Senior Member
    5,884
    3,486
    I am at 42,000 miles and will need tires in about 5,000 miles.....
  12. Habnar
    Habnar Junior Member
    43
    Oakley, CA
    2019 Prius Prime
    I've got 60k on my OEM Goodyear Assurance Fuel Max and they look to be good for at least another 20k.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    Oh gawd! I hope kill mine before that
  14. Oldwolf
    816
    106
    NC
    2016 Prius v wagon
    I have 43k on my C's OEM Bridgestone Turanza's.
    They still have quite a lot of tread but have worn unevenly and make a lot of noise.
    I have eight Ecopa 422 Plus on order for both of my Prii now and they should be installed this coming week.
  15. tgpii
    tgpii Member
    382
    63
    TC400 likes this.
  16. vinnie97
    1,430
    277
    Somewhere out there
    My Turanzas became threadbare by 30k. Wonder if the desert climate had something to do with it. Sitting pretty with some Michelin Energy Savers for the last 10k.
  17. Habnar
    43
    Oakley, CA
    2019 Prius Prime
    Goodyears are bad? 80k is a pretty good run on the same tires.
  18. cyclopathic
    3,292
    547
    2014 Prius c
    It would certainly be if it were good tires :)
  19. orenji
    5,884
    3,486
    I have 42,000 on mine and still going......Bridgestone Tires are always my first choice!
  20. vinnie97
    1,430
    277
    Somewhere out there
    OEM disasters in my case. I'm liking the Michelins so far.
