The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    looks like Godzilla stepped on it,two Japanese could have that back together in in 12 min's
  2. Bill the Engineer
    1,044
    2,272
    467
    At the beach in Delaware...
    More measurements. More drawing in AutoCAD during my lunch times. I hope these colors show up here.
    The Prius v internal a/c system WILL fit behind the dash, but it will be tight. I will need to cut-out part of the Firebird transmission tunnel, since the Denso a/c will be lower than that on the bottom. Ducting will be interesting too once things are together. It is looking more and more like I will need to radically customize the console on the transmission hump to fit all of the controls too.
    Still planning to nest the frames the same way as before. The final car will sit an inch higher than it did originally, and the bottoms of the doors and fenders will need to be flared out. It should give it an interesting appearance!
    Bill the Engineer
    #222 Bill the Engineer, May 27, 2015
  3. Bill the Engineer
    1,044
    2,272
    467
    A little more detail added today...
    These are my guides as to where to make my cuts on the firewall of the Firebird body. If things go to plan and I get enough dry weather this weekend, I will pass the point of no return on the Firebird body. I bought the extra saw blades this evening. Fun times coming!
    Bill the Engineer
    49,019
    unfathomable.
  5. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Looks like you'll be cutting out and fitting a fuel door in the Firebrid as well.
  6. Beachbummm
    1,160
    392
    ya know the guys on "fast N loud" would have had this done by the third commercial and sold by the end of the show.
    just duct tape it together,paint it with spray paint and sell in on the "interweb" like they do.
    the beer is getting warm
    :D
  7. Bill the Engineer
    1,044
    2,272
    467
    Hoping to pick up a late '60's GM fuel door with the same contour for that. The original fuel door on the Firebird was over the center of the rear bumper. I plan to use that as the location of the power-out plug and also use the bird emblem as the center brake light.
    They can be as fast and as loud as they want. I'm into calm and quiet myself. They can find their own Firebird to work on.
    Oh, and selling this car will be my heir's problem far into the future, not mine.
    Enjoy your beer. I'm allergic to alcohol, so I've spent my life as the designated driver.
    Bill the Engineer
  8. bisco
    49,019
    not a bad allergy to have.;)
  9. Bill the Engineer
    1,044
    2,272
    467
    No progress this weekend. Rain and lots of indoor chores. Hoping for better weather next weekend.
    Bill the soggy Engineer
  10. bisco
    49,019
  11. Bill the Engineer
    1,044
    2,272
    467
    Looking like it could be a productive weekend this time.
    Bill the Engineer
  12. bisco
    49,019
    stop playing with your etch a sketch and get to work.;)
    redhotz likes this.
  13. Bill the Engineer
    1,044
    2,272
    467
    As you requested. :confused:
    Today I have past the point of no return. Many Firebird owners just passed out over what I did today... :rolleyes:
    Marking where to cut.
    Mischief managed. It should look somewhat like the etch-a-sketch drawing in the previous post. :D
    Tomorrow it's time to measure the floorpans to see what stays and what goes.
    Bill the Engineer
    m.wynn and sfv41901 like this.
  14. xliderider
    7,849
    3,103
    Honolulu, HI
    Wow, with all that metal cutting, maybe a plasma cutter would've been a worthwhile investment? (y)
  15. bisco
    49,019
    i solemnly swear that you are up to no good.:whistle:
    Bill the Engineer likes this.
  16. Bill the Engineer
    1,044
    2,272
    467
    Nah. Having too much fun with the sawz-all.
    Would a Muggle do this? I don't think so!
    Bill the Master of Transfiguration
  17. bisco
    49,019
    you should have used a ford anglia.;)
  18. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Prius C is so much wider than Anglia. Wheels would sit almost completely outside the body line. You would have problems even getting the Prius C strut tower inside the front fender of Anglia. :D
  19. Bill the Engineer
    1,044
    2,272
    467
  20. bisco
    49,019
    and, you can fly them all the way to surrey and back. right over bristol!:)
Thread Status:
