The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. Air_Boss
    Air_Boss Senior Member
    3,925
    1,073
    New Yawk
    How are you bracing that shell so it doesn't fold up behind the firewall?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    This is one of the most interesting and entertaining projects to watch unfold vicariously from a distance.
    I will drink a non- alcoholic toast to the entire enterprise in honor of Bill The Engineers creation upon it's completion.
  3. Bill the Engineer
    1,044
    2,272
    467
    At the beach in Delaware...
    The way I am going about the merger, the upper reinforced part of the firewall and front door support from both cars will be welded together including any cross-bracing I can add. The box section should be every bit as rigid as the original firewall, if not more so, since much of the Firebird's metal is twice as thick in that area.
    The upper portion of the Firebird rocker panels will also be fully seam welded to the tops of the "v" rocker panels, creating a double thick configuration that will then be capped-over on the outside with an additional welded on cover. (The "v" rides lower to the ground than the Firebird, so the difference in height should not be noticeable.) All of the Prius v cabin floor and bracing will remain. The Firebird seat support and rear body internal bracing will be welded on top of it with fabricated filler pieces where needed to seal-off between the two. As usual, I am working out much of the geometry on the CAD system before cutting.
    I'll have an Iced Earl Grey and drink to that. Cheers!
    Bill the Engineer
    The Electric Me likes this.
    49,072
    i'll have a cold butterbeer please.;)
  5. ChapmanF
    15,156
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I think the most important question people need answered is...
    did you weld the folding chair in place and does it have a seat belt?
  7. Bill the Engineer
    1,044
    2,272
    467
    The folding chair is fully adjustable. In fact, it is fully stow-able in case you want to carry something large...
    ... like a convertible body. ;)
    Bill the Engineer
    valde3 likes this.
  8. pking51
    pking51 New Member
    Jacksonville, FL
    2013 Prius v wagon
    Bill, I found your Firebird / Prius mash up thread today; was reading it with little more than mild bemusement when long about page 6, I suddenly realized you were showing me all those great inside shots with the interior removed. I bought a ’13 Prius v, 3 weeks ago (white just like yours) and (besides commuting to work) plan to convert it into a one person RV, for trips (let’s hear it for the battery powered AC). Now I will not have to take so much of it apart to see what’s behind all the plastic panels. Thank you so much. Your pictures will really help with planning.
    Question 1: I’d like to remove the console to facilitate moving front to back without stepping outside (stealth requirement). It looks like the console is built on a metal cage. Is the metal cage a bolt-off removal so I could put it all back in later if I need warranty work?
    Question 2: Other than the “EV, ECO, PWR” mode switch pack, are there any other wires/electronics in the console that might discourage me from removing it because taking it out will make the car not run? I will need to put it all back in if the car ever needs warranty work.
    Question 3: Finally, and this is just ‘cause I’m curious, where do you plan to locate the “EV, ECO, PWR” mode switch pack in the Firebrid? I assume it has 4 wires. Will you have to lengthen them?
  9. Bill the Engineer
    1,044
    2,272
    467
    Wow, thanks for the compliments. Your project sounds quite interesting too. I will try to answer your questions to the extent of what I have learned so far.
    Answer 1: There is an unpainted metal cage-like structure that supports the console that can be unbolted from brackets welded into the floor. What remains on the floor are a series of low welded brackets on the floorpan. These should probably not be disturbed since they also provide some protection for the parking brake cable that runs along the center of the hump. They also protect some electronic sensors that shouldn't be disturbed attached to the floorpan in this area. If you remove the console, I would recommend bolting a metal plate in its place to step upon. This would prevent damage to the items below it.
    Answer 2: I mentioned above that there are floor-mounted electrical items in this area. While your car will run with the EV/ECO/PWR switch disconnected (with the result of always being in "normal" mode), the other items need to remain connected and in their existing locations on the floor. Fortunately they do not mount on the console itself. Protection from being trampled is required though.
    Answer 3: For my project, he EV/ECO/PWR mode switch will be mounted centrally in the Firebrid's modified dash. I don't expect that particular cable will need to be lengthened, but a number of others will. I need to get a lot of sheet-metal work out of the way first before I address that part of the project. The final dash is planned to be as close to the original Firebird design as possible, but with the multi-function screen hanging under the center of the dash where originally an 8-track player would have been (had the car originally had one.)
    Please note that I use the term "Firebrid" for the car after the conversion, and "Firebird" for the convertible prior to the conversion. The donor Prius v has the nickname "Donna the Donor Car" among my family members. I normally try not to use that name since I bought the car incomplete and wrecked with a salvage title, so that VIN number essentially no longer exists as a car.
    Bill the Engineer
    #249 Bill the Engineer, Jun 13, 2015
  10. Bill the Engineer
    1,044
    2,272
    467
    This coming weekend is all about a concert that my wife and I plan to attend, as well as Father's day. Progress will resume the following weekend when the parts of the Firebird floorpan that need to get cut away will start to go!
    Bill the Engineer
    (Updated 6/17/15)
    #250 Bill the Engineer, Jun 16, 2015
  11. Bill the Engineer
    1,044
    2,272
    467
    Good news: Did some part trading with Steve at autobeyours.com in Scottsburg, IN, on our way to the concert this past weekend. Traded parts he can use for collision damaged Prius v's for some Gen-II parts I wanted for the project. (gas door assembly and surrounding sheetmetal, plus an additional intermediate steering shaft so I can extend mine.) The Gen-II door will fit the contour of the Firebird rear fender much better than the Gen-III would. It is also closer to a late-1960's shape.
    Also ordered the blank version of the Firebird center dash panel. I had noticed that it was disappearing from the various parts catalogs, so I found one on-line.
    Bad news: My wife broke her forearm on the trip. She'll be in a cast for a while. We still enjoyed the concert though!
    Bill the Engineer
    #251 Bill the Engineer, Jun 23, 2015
    sfv41901 likes this.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Glad 2 hear about the parts but not about ur wife......hope she's ok & in good spirits
    VS980 4G ?
  13. bisco
    49,072
    ouch! sounds like more honey do time, and less firebrid.:(
  14. Bill the Engineer
    1,044
    2,272
    467
    My prettier half is home and as stable as she will be for now. Saturday is forecast as a wash-out day, so Sunday looks like the fun-in-the-garage day. Getting that Sawz-all itch...
    Bill the Engineer
  15. bisco
    49,072
    trigger finger twitch...
  16. Bill the Engineer
    1,044
    2,272
    467
    The convertible is a tough old bird. Not only is the sheet metal twice as thick, the area under the front bucket seats is triple thick for strength.
    The front two areas under the dash are where the forward floor cross beam in the donor v is located. There were a lot of rust holes in that location, so I also cut the rotted parts away.
    The aft floor cross beam in the donor v is located directly under the driver's seat in the Firebird. Fortunately the cuts do not get near the seat attachment points.
    I had planned to cut out four locations in the floor today. However, the convertible ate so many saw blades that I had to stop at three. There is always next weekend...
    Bill the Engineer
    #256 Bill the Engineer, Jun 28, 2015
  17. bisco
    49,072
    is this unibody?
    Bill the Engineer likes this.
  18. xliderider
    xliderider Senior Member
    7,852
    3,103
    Honolulu, HI
    Body on frame for the Firebird, unibody for the Prius v.
    Bill the Engineer and sfv41901 like this.
  19. Bill the Engineer
    1,044
    2,272
    467
    Not exactly.
    Again, not exactly. The Firebird had a sub-frame in the front that only extended back to under the front seats. This overlapped a unibody structure that runs from the cowl to the rear bumper mounts. A bit of an odd set-up that caused vibration problems for GM. The car has viscous vibration dampers that mount in all four corners that add about 80 lbs to the car. I may or may not need them (TBD) due to the double sills I will have on the car.
    Bill the Engineer
  20. bisco
    49,072
    so, the firebird was a firebrid after all.;)
Thread Status:
