The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. Bill the Engineer
    1,044
    2,272
    467
    At the beach in Delaware...
    1960's Generous Motors at it's best. Most people don't know that the cowl and many other parts that went into GM's hurried Camaro/Firebird initial design had already been developed for the 1968 Nova and was taken as-is. I have even seen photos of a Nova converted into a 4-door "Camaro" by someone. GM lived to regret this compromise when the wild twisting of the convertible body on the highway had to be controlled by adding the heavy vibration dampeners in all four corners.
    Bill the Engineer
    sfv41901, bisco and orenji like this.
  2. Bill the Engineer
    1,044
    2,272
    467
    Right side passenger compartment floor is out. Tough old 'Bird. The left side will need to wait until next week. I need to be careful where I stand now, because some areas can't support my weight any more.
    I am including a comparison shot of the tunnel cut-out and the corresponding "v" floor area that will be under it. The tunnel will end just shy of the fuel tank wiring access hatch.
    Bill the Engineer
    49,049
    starting to get complicated now.:confused:
    Bill the Engineer likes this.
  4. Bill the Engineer
    1,044
    2,272
    467
    The fun is just beginning. Getting that last seat belt out was a real pain...
    Note that I haven't even begun to cut-out the trunk area yet.
    Bill the Engineer
  5. bisco
    49,049
    can you reuse it?:whistle:
  6. Bill the Engineer
    1,044
    2,272
    467
    Yes. The traction battery will be where the bottom rear seat cushion was. I plan to put it in a rain-proof ventilated box with a hinged top. The rear seat cushion will go on top of that, still below the side window height, but elevated. It will be the perfect place for the dog to ride on the way to the beach... or for a homecoming queen to ride with the top down in a parade. ;)
    Bill the Engineer
    Burna J and bisco like this.
  7. Bill the Engineer
    1,044
    2,272
    467
    I can go under the convertible body and stand up in the middle now. :D
    Bill the Engineer
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    mine just unbolt.. never needed to cut the floor out but I never worked on a classic car ...
  9. Bill the Engineer
    1,044
    2,272
    467
    Passenger compartment floor cut-outs completed. Tough old bird. It ate a dozen saw blades in the process.
    I also opened a hole in the trunk floor so I could feed through a tape measure to start to layout the cuts there.
    More reports as progress is made.
    Bill the Engineer
  10. Bill the Engineer
    1,044
    2,272
    467
    Progress not likely this weekend. I'm just back from a business trip 3 time zones away, and the heat index here both Sat and Sun is supposed to be 100F or above.
  11. bisco
    49,049
    brutal weekend between humidity and storms.
  12. Bill the Engineer
    1,044
    2,272
    467
    Yeah, and the jet lag isn't helping. I should have been in bed hours ago.
    So far the forecast for Saturday sounds good. I have a lot of black marker work on both the body and the chassis to do before I cut any more. The rear axle area will be the most tricky, since I need the structure of the "v" for the rear suspension, but the structure of the old Bird for the convertible top and side quarter windows. That fuel filler neck needs to be accounted for too... Glad I like solving puzzles!
    Bill the Engineer
  13. bisco
    49,049
  14. Bill the Engineer
    1,044
    2,272
    467
    Life is what happens when you were planning to do something else. I got as far as marking the location of the rear axle centerline on the "v" chassis and Firebird body yesterday. Then my neighbor called me over to help him get his car running that had died in the garage... and the rest of the day was shot.
    The rear axle centerline is the "zero point" of the project from which all other dimensions are based. I am remeasuring everything to make sure things will fit together properly when I finally drop the body onto the chassis. The next step will be to unbolt the traction battery on the "v" chassis. Then I can create cardboard templates for the rear wheel well cut-outs on the Firebird body.
    Next weekend I am off to a car show in search of Firebird parts. Maybe I'll get some time to sneak out to the garage during the week.
    Bill the Engineer
    #274 Bill the Engineer, Jul 26, 2015
  15. bisco
    49,049
    that's what neighbors are for.(y)
  16. Bill the Engineer
    1,044
    2,272
    467
    A good couple of days this weekend.
    Friday I went to an all-Pontiac flea market ad car shoe in Norwalk, OH. My Firebird wasn't equipped with a/c originally, but I want the finished car to use the donor car's a/c. I was lucky to find a vendor who had the set of three Firebird a/c vents out of a salvaged car for $25.00. For that price, I couldn't say no.
    Saturday was a good day too. After some initial garage clean-up, I got the trunk floor cut out. Then I was able to re-measure my passenger compartment floor cuts directly from the zero line. They were an inch too far aft, so I was enlarging the holes forward by an inch all afternoon. Tough old Bird...
    Bill the Engineer
    sfv41901 likes this.
  17. bisco
    49,049
    looking good, happy august!
  18. Bill the Engineer
    1,044
    2,272
    467
    Yesterday's photos were all of the Firebird body. Marking and verifying of the donor Prius v chassis also continues. The rear wheel wells of the donor car will be protruding into the trunk of the Firebird body, so that all needs to get figured out. Also i have marked where the side sills and firewall will land once the assembly is together.
    Bill the Engineer
  19. bisco
    49,049
    thank you bill, for keeping this step by step. i'm having a hard time following, but i think when i can look back from beginning to end, it might make more sense.:)
  20. Bill the Engineer
    1,044
    2,272
    467
    Well, you can most definitely see my thought process at work if you start at the first post and read up to the present. The plans evolve as I discover things about the cars. Usually they are happy discoveries. ;)
    Bill the Engineer
Thread Status:
