The Physics of Natural Football Deflation
Discussion in 'Fred's House of Pancakes' started by SageBrush, Jan 21, 2015.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Need is in the eye of the beholder, namely the quarterback. A team can have a group meditation around the ball followed by a group hug for all the NFL cares, so long as the ball passes the pre-game umpire exam.
    49,066
    i think the balls are new. someone did a good interview with several qb's, either usa today or cnn, all described their preferred process for breaking in game balls before the game. they described them as shiny and smooth, not what they wanted for a good grip.
    #42 bisco, Jan 24, 2015
  3. SageBrush
    11,627
    2,530
    Southwest Colorado
    Yep, but it does not matter. Teams are allowed to do whatever they want to the balls. They become game balls if they pass pre-game ump review for quality, weight and pressure. Period. Notice that ball temp is not considered.
    49,066
    correct. and there was a time when they could not scuff up the ball before the game. pre 1999 i believe.
    btw, i don't think filling them with an alternate gas is illegal, at least i have not heard that it is.
  5. SageBrush
    11,627
    2,530
    Southwest Colorado
    The only detail none of us correctly guessed was why the ball reaches the umpire warm. Turns out to be a massaged football rather than a hot room.
  6. bisco
    49,066
    who knew? in fact, who knew there were rules about football weight and pressure? i always thought the league provided the balls.
  7. wjtracy
    wjtracy Senior Member
    11,315
    3,588
    Northern VA (NoVA)
    It was Brady himself who got the NFL rule changed to allow teams (quarterbacks) to control the ball preparation around 2005. Prior to that the home team supplied balls, needless to say they tended to give fresh slick balls to visiting team. The only fresh new balls are now the kickers, marked with "K". That was because the kickers were overly massaging the balls...kickers like a really soft ball with a bigger sweet spot.
    If Brady needs a vigorous massage, he can get that the day before the game. Any "vigorous massaging" of the balls 5-minutes before the Refs measure the pressure has questionable if not suspicious purpose.
    What's the process look like? 12 guys vigorously massaging 12 balls in the locker room just before the Refs get the balls? If I was Ref, I wouldn't touch those balls with 10-feet pole. I guess Brady only needs one hot ball to get through to his liking. Also he probably wants some variations in pressure, if the ambient temps goes down 10 degrees he may want to change to a different ball.
    No way will NFL allow this next year.
    #47 wjtracy, Jan 25, 2015
  8. bisco
    49,066
    i think they do it after the balls are brought out onto the field. i wish some intrepid reporter would post the rules, instead of being judgemental and asking stupid questions. these guys aren't worth the money they're paid.
  9. SageBrush
    11,627
    2,530
    Southwest Colorado
    i like the idea of the ball having to be within say 5 F of ambient, along with the other standing criteria.
  10. bisco
    49,066
    why not just have the ref stick a gauge in them at every tv time out?
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    Or have an offensive lineman sit on the ball and measure the deflection.
  12. bisco
    49,066
    newsflash: bill nye says rubbing the balls won't change the pressure.
  13. SageBrush
    11,627
    2,530
    Southwest Colorado
  14. bisco
    49,066
    funny how they don't quote nye. usa today only quoted him on rubbing up the balls, not the temp and other. interesting report today that the ball boy in a regular season game (carolina?) was holding the balls in front of a space heater on the sidelines, which is illegal, and the refs went over and told him to knock it off.
  15. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Next NFL scandal--Miscalibrated offensive lineman
  16. bisco
    49,066
    they already have that, ped's.:cool:
  17. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    Found some calcs, not sure if definitive:
    Football Vol (approx) = 4200 ccs or 1.1 Gallons or 0.15 ft3
    So 0.15 ft3/380 scf/mole x 29 MW = 0.015 lbs air = 5.2 grams at 14.7 psia = 9.8 grams air at 13 psig = 27.7 psia
    So that's only about 9.8 grams air, so if you were 3-psia short that would be 1-gram difference if deflated to 10 psig.
    Basically no impact on weight. Even if He was used just be maybe 8 grams lower.
  18. bwilson4web
    15,434
    Interest hypothesis about vigorously rubbing the balls. I'll have my wife test it.
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    For scientific rigor, be sure to stick a thermistor in them. A graph is worth a thousand words.
  20. SageBrush
    11,627
    2,530
    Southwest Colorado
    ^^ exhibit #1 for the abuse of engineers by the US system of measurements. Sheesh.
    Try metric:
    Air weighs about 1.25 grams per liter, so 4.2 liters weighs 5.25 grams at one ATM
    The football is inflated to almost two ATM, so the air weight is doubled to 10.5 grams
    Removal of 20% of air removes two grams of weight.
