Thinking of upgrading my speakers
Discussion in 'Prius c Audio and Electronics' started by cubchan, Mar 15, 2012.
  1. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    using a pac-swi steering wheel control adapter, the steering wheel controls were preserved... including the phone bluetooth buttons..
    so.. yes.. from prior experiences and from what other people have told me, the stock microphone doesn't work well with aftermarket systems, so the mic that came with the avic unit was routed and mounted in front of the map/dome lights.
    also got a license plate rear-view camera routed and hooked up to the headunit as well.
    fyi, just to be sure everyone knows, this is not my Prius C, but kewlfox's.. he just finished having tint done to the vehicle (20% rear, 50% front) as well as finishing up hooking up a subwoofer and amp which we spent a good amount of time routing wires for the other night.
    much thanks to Bryan and Jim at All Pro Audio in Santa Clara for the additional help and assistance.
    2 people like this.
  2. nallioni
    nallioni New Member
    Cabo Rojo PR
    looks nice!:rockon:
  3. Daze
    Daze Prius C Owner
    92
    23
    Utah
    Do you think you could post the pictures of the subwoofer? And the amp? Im installing one too and I'd like to see what you came up with.
  4. SquallLHeart
    826
    247
    San Jose, CA
    the amp is hiding on the driver side.. forward left of the spare tire.. mounted in that corner.. and then the foam insert cut out to make space for it.. the power wire routed right to the battery where the rear passenger seat is.
    the sub box fits snugly in the trunk area with enough room for the cover to come down and still a good amount of storage area. kewlfox is out and about and i might see his car tomorrow so i can snap some photos.
  5. Shiesty
    Shiesty New Member
    Jacksonville
    I took the rear door panels off yesterday and was going to install some Polk DXi 650 6.5" speakers on the C1 and no wires were there. Took out the stock stereo and there was one wire on the harness going to the rear speakers but no speaker wires. Wow wonder what bean counter decided to save .50 for not installing speaker wires to the back doors. The stereo has a fade so you would think that they at least would have ran wires back there but no.
    Anyway the sound on the C1 is horrible to say the least. I will buying a Pioneer AVIC-X940BT and Pioneer TS-D1720C 6.75-Inch D-Series 280-Watt Speaker Package for the front doors, drilling out the riveted sub woofers in the door. I think the 6.75-Inch sub woofers with fit in the front doors but I am not sure.
  6. actiondonkey
    actiondonkey Member
    91
    30
    Looks great. Is there an amp you had to bypass or does the C2 not come with one? Did Kewlfox notice if the added draw hurt his MPG? I'd think not since it pulls from the 12v and not EV battery but may add a cap just in case...
    Next time I head down to Orlando in early May I'll be putting in a PNX-671 with the rear license plate camera and Access ASWC steering wheel module. Of course amp and speakers (Memphis Audio). But we need the grocery/luggage space so the subs ( two 8s or 10s) will go in the spare tire area with a custom (plexiglass?) enclosure. Also going to incorporate the bass adjustment knob into one of the unused button slots next to EV.
  7. SquallLHeart
    826
    247
    San Jose, CA
    he hasn't driven his car long enough prior to installation... so there's no real control from his previous mileage to compare to..
    there was no amp to bypass.
  8. kewlfox
    kewlfox New Member
    san jose
    sorry on not really posting, work for the dealer i baught mine from(no discounts hahaha) but the project is simple i took my stand by image dynamics idq3 sub and a sealed 12" slanted box and a jl audio JX500/1 amp and stock speakers and so far the system is on par with a decent mid grade sound system. the intriging part of the install was the simplicity of it. if i were to do it again install time would be 5hrs-7hrs. the dash insert right now is a custom fit thin mdf piece with suede wrap, it will be fitted with a metra or what ever kit that comes out. the only pain in the @$$ problem was the cutting of foam for the hidden amp. up next is tails head light smoking and a set of scion iQ liquid metal alloys. and much more to come.
  9. Daze
    Daze Prius C Owner
    92
    23
    Utah
    That sounds very exciting. Once my Habanero prius C 3 arrives im going to install a 10 inch alpine type r with a 500 watt alpine amplifier (mrp-m500). Then im going to tint the windows to the legal limit and get some black rims. Ill make a thread of my own once i get everything figured out.
    I was thinking of doing the same with hiding the amp under the styrofoam inserts but wasnt sure if this could lead to possible overheating problems for the amp. I might just mount it on the enclosure. I would be really thankful if you could post pictures of your setup!
  10. kewlfox
    kewlfox New Member
    san jose
    sure ill get some pics up later this afternoon, depending on the amps heat reducing properties(fans large heatsinks,etc etc) i personally like the under styrofoam method with quick disconnects for the sub box, later down the line im having a pocket mounted 10" sub installed.
  11. MICT
    MICT New Member
    CT
    Can you guys list the model number of the wire harness used and also the module to retain the stock controls? If you have links to where they were purchases that would be handy as well.
    Thanks,
    MICT
  12. kewlfox
    kewlfox New Member
    san jose
    of course let me get those for you guys
  13. Tek55
    Tek55 Junior Member
    96
    Houston
    I had a pac-swi setup w my Camry and a kenwood dnx9140 and was always annoyed at the long delay between button presses and the head unit responding, ESPECIALLY with iPod control.
    I understand some of this is just the iPod, but do you notice a delay with all button presses w your pioneer head unit + pac-swi?
    That seriously drives me nuts waiting 2-5 seconds for the head unit to respond
  14. kewlfox
    kewlfox New Member
    san jose
    oddly enough no theres not a whole bunch of lag in it maybe like a half second to a second delay in it.
  15. Tek55
    Tek55 Junior Member
    96
    Houston
    And every function is kept intact? Looks like I'm gonna be surprisingly pleased at not getting entune! Aftermarket here I come!
  16. nallioni
    nallioni New Member
    Cabo Rojo PR
    i hear ya
  17. drew935
    drew935 Member
    168
    22
    Nor Cal
    Any updates on the steering control wiring harness diagram?
  18. JRo
    JRo Junior Member
    Hi Squall, in a totally unrelated note, where did you get that wheel cover that fits? I had that same one for my old Rav4 and would like the same for the little Prius c.
    Thanks.
  19. koipond
    koipond Member
    198
    39
    I just purchased a Prius C 3 with the nav system/radio combo-unit. Due to all the features built into this device (and the fact that it even functions as a monitor for some car/driving data display), I'd really rather leave it in place.
    Trouble is I'm also an audiophile.
    Question... by any chance does this existing head unit have RCA/line-level output to feed an external amp? I'd be willing to live with the compromise of the factory pre-amp section if I could have my own external amp. If no, is there any reasonable step-down device that can, with "decent" sound-quality results, take the speaker-level output of the headunit and step down to line-level for an amp? I have two linear power amps I'd like to use if possible and they only have line-level input. Thoughts? Bottom line is I'm wondering what's the best-sounding option I have that also keeps the existing head-unit in-tact in the dash.
    thanks!
