Tire pressure light comes on, goes off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yam, Jul 6, 2011.
  1. yam
    yam
    Expand Collapse
    Junior Member
    64
    Austin TX
    My tire pressure light flashed for a while and then remained lit for several minutes during a several-hundred-mile roadtrip a few days ago. The vehicle did not pull, drag, or show any sign of tire problems, and when I checked the pressure on all four tires the next morning they were fine.
    The next day, the same thing happened again after another several hundred miles. This time I pulled over within a few minutes and checked all four tires - good pressure on all of them again.
    I couldn't check the spare since I had a bunch of luggage loaded. Can't imagine it would help anyway since my tire gauge tops out at just 50 psi.
    What is my tire pressure light telling me??? If I could figure out what was wrong, I would fix it!
  2. stream
    stream
    Expand Collapse
    Senior Member
    2,977
    445
    Long Island, NY
    When was the last time you reset the TPMS? Try that.
  3. yam
    yam
    Expand Collapse
    Junior Member
    64
    Austin TX
    It's been a while, but the pressure in each tire is within a couple pounds of the original set point.
  4. LulzChicken
    LulzChicken
    Expand Collapse
    Prius Enthusiast
    790
    133
    Alabama
    Do you have your license plate bulbs replaced with LED's?
    I had the same issue and it turned out to be the LED's that were interfering with the TPMS reciever which is located near the rear of the vehicle. The ONLY LED's that caused this problem were the high power SMD ones. I got some different LED's and it works just fine.
  5. yam
    yam
    Expand Collapse
    Junior Member
    64
    Austin TX
    No aftermarket LED lights, but there were plenty of electronic gizmos running to keep the family happy during the long drive. One DVD player, one GPS, two iPhones rotating through the charger plug and checking for important facebook updates, and an iPad. Do any of these devices have a history of interfering with the tpms sensor?
  6. LulzChicken
    LulzChicken
    Expand Collapse
    Prius Enthusiast
    790
    133
    Alabama
    I honestly don't think they would interfere with the TPMS receiver. When the light flashes, and then stays on - it means there is a malfunction in the tire pressure monitoring system. If it just comes on without flashing, that means you are actually losing pressure. This is in your manual if you'd like to confirm. Maybe you have a fault with the system, but I doubt it. I say if this happens again be sure to post and let us know. I've never had this issue - only when I had the LED's in the license plate area.
  7. adamace1
    adamace1
    Expand Collapse
    Senior Member
    1,403
    177
    Charlotte, NC
    Check all 4 tires and then set the tpms. If it goes off again see dealer.
  8. pjksr02
    pjksr02
    Expand Collapse
    Member
    258
    32
    Connecticut
    Is your light still on, flashing for a minute after you start the car?
    If your light flashes a minute, then stays on, this indicates some type of system problem. It the light simply comes on, this indicates a tire-pressure problem.
    If your light is on, you can determine the problem if you're brave, by shorting TC and CG on the DLC3 connector, with your car on, but engine off (press "on" twice without pressing the brake). The TPMS light will sequentially flash the DTCs stored in the TPWS ECU, and then you'll know what's wrong.
    Here are the codes:
    http://www-rohan.sdsu.edu/~nash/TCH/TPMS.pdf
  9. Kryten
    Kryten
    Expand Collapse
    New Member
    I think you just solved a mystery regarding my Prius... I was about to post a question about it.
    A year or so after I bought my '06 Prius, I got 4 wheels for a set of X-Ice for the winter. Work great, but with those wheels/rims on, every time I drive past a certain spot on the interstate some 60 miles from here, the tire pressure light comes on. Stays on for the rest of the day, then eventually goes off and stays off until I happen to drive past that spot again.
    At first I checked the tires, but eventually I knew they were fine and there was something special about that spot. The road, the elevation, something. Now it seems pretty clear that there is probably some type of interference right there that make the light come on when I'm using those wheels, which are not Toyota rims.
    Anyone else experience this?
  10. pjksr02
    pjksr02
    Expand Collapse
    Member
    258
    32
    Connecticut
    That location is 15 minutes from your home, right? At 15 minutes, the TPMS light will go on, if any of the TPMS sensors' signals has not been received (ie. you drive away from the tires, with sensors, that are in your garage).
  11. wick1ert
    wick1ert
    Expand Collapse
    Senior Member
    1,316
    181
    Delawhere
    Seems unlikely at 15 minutes, since the poster said it was about 60 miles, unless they got that pursuit mode from KITT in Knight Rider ;).
    It seems odd that the one particular spot seems to cause it, then cancel it though. Even if there was some sort of interference (something using a similar frequency), I would expect it to clear before driving past it again.
  12. pjksr02
    pjksr02
    Expand Collapse
    Member
    258
    32
    Connecticut
    My bad. I didn't read the post closely. Clearly, he is passing a TPMS check-point!
  13. Kryten
    Kryten
    Expand Collapse
    New Member
    No-- way more than 15 minutes. Takes almost that long to get from my house to the freeway. Plus it doesn't do it any other time or place, even if I'm on the road for a hour.
    But one thing I got to thinking about was that I found this thread doing a search, and hadn't noticed it was in the 2010+ models area, so I'm not positive my 06 has the RF sensor system. It may have the type that compares the rotations of the wheels to determine if one is "fuller" than the other (-if I'm remembering that right)...
  14. pjksr02
    pjksr02
    Expand Collapse
    Member
    258
    32
    Connecticut
    Hey kid, go play in your own forum.
    No seriously, that could be the case. My 2002 Sienna has that system. The way to check is to look at your valve stems. If they're rubber, they aren't the TPMS-type.
