Too aggressive?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mnml, Dec 31, 2012.
  1. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    I found a set of wheels on tirerack.com but the fitment has me a bit worried.
    The specs:
    - 16x7.5
    - +38 offset
    - 205/55/16 Continental PureContact tires
    The offset seems a bit aggressive to me but the customer service rep says it'll fit flush and their sizing system is legit. Any advice before I pull the trigger? They also offer the same wheel in a 15x6.5 +38 which can utilize my same tires. Mostly worried about the +38 offset on a PiP.
    Your thoughts
  2. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    the 7.5+35 will fit fine.
    mnml likes this.
  3. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    it would fit just fine..
    I'm using 18x7.5 ET38 (ET33 at the rear w/ the 5mm spacer) with 215/40 tires and it fits fine....
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I think they stick out too far in the front but that is just my opinion. I had a set of 15x7 +38 and didn't like the way they sat in the front. The rear looked good.
    You'll get style points from the tuner group but negatives in the fuel efficiency group. :p
    mnml likes this.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    7.5 inch wheel width is the normal maximum wheel width recommended for that tire size. Running max recommended wheel with gives better handling and make the tire wear more tolerant of high pressure (conversely less tolerant of low pressure). As far as how it looks, that's a styling exercise and no one but you can answer that.
    mnml likes this.
  6. mnml
    377
    161
    Ladera Ranch, CA
    bino - do you have any pics of your front wheels which show how flush they are?
  7. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
    here.... 18x7.5 (ET 38 front/ ET33 rear) 215/40 tires conti DWS
    mnml likes this.
  8. mnml
    377
    161
    Ladera Ranch, CA
    Thanks for the pics, wheels look flush.
