Took my first Test drive
Discussion in 'Gen 2 Prius Main Forum' started by Hostage46, May 26, 2006.
  1. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I like the foot brake, kind of like my old Dodge. But the Dodge was much easier to use because you pushed to engage, pulled a lever to release, and if you held the lever you could push it like a regular brake pedal.
  2. Sarge
    Sarge Senior Member
    1,298
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(Jack Straw @ May 27 2006, 02:58 AM) [snapback]261698[/snapback]</div>
    I had an stick shift with a conventional handbrake in my previous car and I was a bit skeptical about how I would feel with the "old fashioned" footbrake. Though it was a concession I was willing to make.
    As others have said, it is not a true e-brake, as you could never really use that in an emergency, as you would a handbrake.
    On the other hand, how often do brakes really fail in a modern car? Very seldom, unless sabotaged.
    Aside from parking, the only time I ever used the handbrake was when I was doing things I shouldn't... :rolleyes: The Prius is not built for performance but rather efficiency - heck you can't even peel your tires thanx to the TCS... ;)
    Bottom line, I agree that the centre space in this car is more efficiently used as expanded storage rather than a handbrake that will never really be "used". B)
    - Kevin
