Top 20 - MPG Record Holders
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 25, 2012.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    wow those are crazy numbers I guess I need a road trip soon
  2. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Movin on up...
    69.5 at avg speed of 40 mph.
    From June 13th to July 1st.
    Conditions 90% of days were clear with temps in the low 80s to upper 70s. I Did have a couple days of HEAVY HEAVY down pour rain that took me down 1 MPG that I had to recoup from.
    Using stock yokohamas with 39k on them. Filled at 40 PSI all around
    I have a 24 mile strech of interstate each day, I just ride in the far right lane, pulse and gliding with the gentle hills along the way, hoping to get behind another slow car or even better semi and ride the length of my drive. I try to keep my speeds low if possible at around 60 max, even though speed limit is 70, its never heavy traffic so others just go around....
    F8L likes this.
  3. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    You have that backwards, higher tire pressure helps on wet roads. Feel free to experiment with anything below sidewall max.
    nfujii likes this.
  4. sisharp
    sisharp Member
    46
    29
    South Carolina
    Hey guys, it's been a while since I've tried for the records. In my recent travels, I was averaging around 58mpg for my normal commutes then I thought I would try to one up my past record of 59.9 with about 1 gallon left. Lo and behold I managed an 87.8 for 36 miles and then a 73mpg trip for 20 or so. This ended up tying my record of 59.9mpg which I was glad to do. This has given me renewed interest in shooting for those high 60's although it's hard to make an attempt on the record with daily commutes where I'm at and with short commutes to boot. :( And I have a semi long trip coming up too which sucks so there goes my 60+ trip attempt. I know my car can do it I just need 500 miles of flat straight open road with no cars and I'll be back in the top 20. I was there briefly last year. My best tank so far is 553 miles at 59.9 mpg. Be on the look out for this c. :)
  5. nfujii
    nfujii New Member
    16
    Dear dhanson865,
    I did not know that, will try it next. Thank you.
  6. markabele
    5,084
    1,782
    Nebraska
    Can I make an entry with my PiP if I don't plug it in during the 500 miles?
    F8L and Agent J like this.
  7. walter Lee
    1,126
    376
    Maryland
    Wow! You finally got a replacement Prius. :-D
    markabele likes this.
  8. rokibler
    rokibler Member
    88
    31
    Cabin John, Md.
    • Gentle on the accelerator, glide when possible, opportunistic drafting. All the driving was necessary. Commute is 12 miles each way.
    • Time of year: last two weeks in June 2013 in the Washington DC area. Warm and cloudy most days with some rain, but not many heavy downpours.
    • Tires: Bridgestone Ecopia 44 front, 42 rear
    F8L, walter Lee and minkus like this.
  9. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    Time to move up a couple slots on the list!!, even though I'm not gonna be in the top 5 im still looking forward to trying harder the next time I hypermile... I have a package 5 on the original 17" wheels, my record is 78.0 mpg for 830 miles!
    Here is my car
    I have the Toyo proxies 215/45 r17
    I use p&g, dwb, timing traffic lights, and a lot of coasting :)
    With a combination of city, freeway, and traffic!
    Record has been achieved on July 10 2013
    F8L, nfujii, walter Lee and 2 others like this.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nice! Great Job. :D
  11. nfujii
    nfujii New Member
    16
    This is a great Job! I am really grad to see more people join this. As F8L said, the goal is to encourage more people joining, so that small piece of saving gas will ultimately multiply to zillions gallons wherever Prius exists.
  12. bwilson4web
    16,217
    Easier format, feel free to cut-and-paste:
    Column 1
    0 [tr][th]username[th]model[th]miles[th]gal[th]MPG[th]mph[th]hrs
    1 [tr][td2]ufourya[td2](Prius_c)[td2]501.1[td2]5.02[td2]99.9[td2]19[td2]26.37
    2 [tr][td2]vincent1449p[td2](Prius_c)[td2]833.2[td2]9.20[td2]90.6[td2]28[td2]29.76
    3 [tr][td2]Ferls80[td2](GenIII)[td2]750.0[td2]9.25[td2]81.1[td2]25[td2]30.00
    4 [tr][td2]Mark57[td2](GenIII)[td2]805.2[td2]10.15[td2]79.3[td2]22[td2]36.60
    5 [tr][td2]markabele[td2](GenIII)[td2]818.7[td2]10.35[td2]79.1[td2]24[td2]34.11
    6 [tr][td2]kalome[td2](GenIII)[td2]703.6[td2]9.10[td2]77.3[td2]27[td2]26.06
    7 [tr][td2]nfujii[td2](GenIII)[td2]550.9[td2]7.25[td2]76.0[td2]21[td2]26.23
    8 [tr][td2]Kore971[td2](GenIII_on_17s)[td2]813.4[td2]10.76[td2]75.6[td2]28[td2]29.05
    9 [tr][td2]kdkuhns3[td2](GenIII)[td2]703.1[td2]9.36[td2]75.1[td2]23[td2]30.57
    10 [tr][td2]mozdzen[td2](GenIII)[td2]701.9[td2]9.55[td2]73.5[td2]30[td2]23.40
    11 [tr][td2]walter_lee[td2](GenIII)[td2]800.1[td2]10.90[td2]73.4[td2]19[td2]42.11
    12 [tr][td2]hcpc[td2](Prius_c)[td2]548.9[td2]7.49[td2]73.3[td2]31[td2]17.71
    13 [tr][td2]Tony_Schaefer[td2](GenII)[td2]662.0[td2]9.17[td2]72.2[td2]25[td2]26.48
    14 [tr][td2]F8L[td2](GenIII)[td2]702.5[td2]9.80[td2]71.7[td2]37[td2]18.99
    15 [tr][td2]Codyroo[td2](GenIII)[td2]752.3[td2]10.55[td2]71.3[td2]35[td2]21.49
    16 [tr][td2]MattPersman[td2](GenIII)[td2]531.5[td2]7.53[td2]70.6[td2]25[td2]21.26
    17 [tr][td2]Agent_J[td2](GenII)[td2]808.7[td2]11.52[td2]70.2[td2]25[td2]32.35
    18 [tr][td2]Optical_Illusions[td2](Prius_c)[td2]582.1[td2]8.39[td2]69.4[td2]25[td2]23.28
    19 [tr][td2]eliteconcept[td2](GenIII)[td2]541.5[td2]7.93[td2]68.3[td2]43[td2]12.59
    20 [tr][td2]rokibler[td2](GenIII)[td2]626.3[td2]9.28[td2]67.5[td2]31[td2]20.20
    I've uploaded the excel spreadsheet that generates the table and the graph. Because the original table does not use standard names, there are two styles for "GenIII", it is not optimized. Also, I'm not a good enough excel wizard to figure out how usernames could be added to the graph in a way that makes sense. Regardless, please feel free to pickup the spreadsheet.
    F8L, minkus and mozdzen like this.
  13. markabele
    5,084
    1,782
    Nebraska
    It's funny how the summer heat is really not allowing too many new entries right now. Or really sad...however you look at it. ;)
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You guys are throwing up some really impressive numbers!
    I am going to split up the list according to model like everyone has agreed to. I need to do it on a regular computer though so I'll get to it tomorrow or the next day. Please bear with me. :)
    Kore971, retired4999, kalome and 2 others like this.
  15. CHACHYONTOP
    CHACHYONTOP New Member
    Lakewood
    Here is my best record..thanks.. I have a prius c with factory 15 inch alloys tire size 175-65-15.. inflation 35 psi.
    I did the same drive cycle everyday on this tank, and in the month of may.. 25 mile trips to and from work..this includes about two miles of city driving and 23 miles of all hwy..When on the streets i use EV only as much as the car will allow.. On the hwy i will enter with almost full power until i reach 50 mph, then i will ease back and cruise to 54 mph. once i reach 54 mph i will let off the accelerator and cost to 42 mph, then i will hit max EV range until i drop to three bars of battery life.. i will basically repeat this cycle until i exit the hwy.
    hcpc, bwilson4web and Kore971 like this.
  16. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    Very nice!
  17. bwilson4web
    16,217
    I'm pretty sure I had a short fill because I had to invert the nozzle. The 10.9 gallons consumed appears to be right. I only got about two miles down the road before 'dry tank.'
    This is the "flash" indicating 2.34 gallons were remaining. I normally use 2.1 gallons but in this case, I was on a grade which may have led to an earlier than expected "flash."
    I had added 1 gallon about four to five miles away. But if we use the next tank, fill gas divided into the final 'dry tank' miles, 10003/12.1 = ~82.9.
    I'm not sure what a photo of the empty tank does.
    Summary:
    • Use cruise control set for 26-27 mph
      • shift into "N" when energy flow shows charge to traction battery
      • shift into "D" and "resume" to:
        • moderate speed
        • come to a stop
        • returning to set speed
    • Select routes and times that allow 25 mph traffic
      • multiple lanes and change lanes so overtaking traffic does not have to change
      • use left-turn lane or parking lot to let following traffic pass
      • when two lanes of traffic overtaking, hit "emergency flashers" so they can change and pass
      • 4:00 AM - 7:00 AM, 1:00 AM - to nap time, 1:00 PM - 4:00 PM
      • take right-hand yield routes
      • July 7-21, 2013
    • Car fully prepared
      • tires fully inflated
      • Scangauge II - used to monitor engine coolant, engine rpm, fuel consumption, and instant MPG to four decimal places
      • driving on "flash", use energy flow display to detect 'dry tank' when all energy flow arrows go away
      • tires Sumitomo T4 195/65R15, replaced by Toyota Service Center, originals had a nail that could not be repaired
        • GPS and trip meter error less than 1%
    Off hand, I think this means an entry in every "xxx mile" tank list and an entry in the "Top 20" list. Perhaps a few updates are warranted:
    username model miles gal MPG mph hrs
    1 ufourya (Prius_c) 501.1 5.02 99.9 19 26.37
    2 bwilson4web (GenIII) 1000.8 10.90 91.8 22 45.49
    3 vincent1449p (Prius_c) 833.2 9.20 90.6 28 29.76
    4 CHACHYONTOP (Prius_c) 607.9 7.50 81.1 26 23.38
    5 Ferls80 (GenIII) 750.0 9.25 81.1 25 30.00
    6 Mark57 (GenIII) 805.2 10.15 79.3 22 36.60
    7 markabele (GenIII) 818.7 10.35 79.1 24 34.11
    8 Kore971 (GenIII) 830.9 10.65 78.0 26 31.96
    9 kalome (GenIII) 703.6 9.10 77.3 27 26.06
    10 nfujii (GenIII) 550.9 7.25 76.0 21 26.23
    11 Kore971 (GenIII_on_17s) 813.4 10.76 75.6 28 29.05
    12 kdkuhns3 (GenIII) 703.1 9.36 75.1 23 30.57
    13 mozdzen (GenIII) 701.9 9.55 73.5 30 23.40
    14 walter_lee (GenIII) 800.1 10.90 73.4 19 42.11
    15 hcpc (Prius_c) 548.9 7.49 73.3 31 17.71
    16 Tony_Schaefer (GenII) 662.0 9.17 72.2 25 26.48
    17 F8L (GenIII) 702.5 9.80 71.7 37 18.99
    18 Codyroo (GenIII) 752.3 10.55 71.3 35 21.49
    19 MattPersman (GenIII) 531.5 7.53 70.6 25 21.26
    20 Agent_J (GenII) 808.7 11.52 70.2 25 32.35
    21 Optical_Illusions (Prius_c) 582.1 8.39 69.4 25 23.28
    22 eliteconcept (GenIII) 541.5 7.93 68.3 43 12.59
    23 rokibler (GenIII) 626.3 9.28 67.5 31 20.20
    Source: "Top 20 thread"
    #697 bwilson4web, Jul 22, 2013
  18. walter Lee
    1,126
    376
    Maryland
    Wowsers! Bob, you outdid yourself!
    With a Gen3 no less! :)
  19. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    I have a better tank that I did last month.
    Distance = 871.8 miles
    Refuel volume = 9.612 gallons
    FE (MFD) = 97.1 mpg
    FE (Calculated) = 90.7 mpg
    Avg. Speed = 28.0 mph
    EV Distance = 579.2 miles
    Outside Temp. = 89.6 ºF
    Time of year : 8/6/13 ~ 23/6/13 (16 days)
    Distance after blinking low-fuel warning light : 164 km (101.9 miles)
    Vincent
    walter Lee likes this.
  20. walter Lee
    1,126
    376
    Maryland
    geez ... soon 75 mpg will be the new low....:p o_O
