Total loss of power after 1 day?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by asha, Jul 29, 2014.
  1. asha
    asha New Member
    District of Columbia
    2014 Prius Plug-in
    There are many threads, but I can't find a definitive solution. I last drove my 2014 PiP Sunday evening. It's been in the garage plugged in since. This morning, I go outside to grab camera equipment from my trunk...I hit the unlock button on the trunk... nothing. I hit my unlock button on the key fob... nothing. Finally, I take the key out and open the driver side door. I hit 'Start' ...and... NOTHING.
    How could this be possible after less than 48 hours of being parked; especially since the car was plugged in? I didn't have time to troubleshoot this morning, but if anyway can tell me where to begin, I'd really appreciate the guidance. My car isn't even two months old. Thanks in advance.
  2. GregP507
    GregP507 Senior Member
    3,002
    480
    This sounds familiar. My new car went dead in the water in less than 15 minutes on acc. It turned out to be a bad aux battery and it was replaced under warranty. I'd recommend having the dealer test it. I believed (along with most people apparently) that if the car was plugged in, the battery won't go dead. Not true.
    There are other possibilities of course. You may have a drain on the 12V system. A good mechanic should be able to trace the leak for you.
  3. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I suspect being plugged in will only charge the traction battery, not the 12V battery. If some 12V electrical load was left on (interior lights are a good suspect) The 12V battery will be totally drained in about 24 hours. Recharge that battery ASAP, as sulfation damage will destroy the battery fairly quickly.
  4. GregP507
    3,002
    480
    It's been a controversy on here whether Toyota should have engineered a way to protect the 12V auxiliary battery from going dead, especially when there is abundant power available from the traction battery. Some claim such a system would endanger the traction battery, and others maintain it could be designed to protect both from over-discharge. For myself, it's less of a risk, knowing that the acc mode will time-out long before the aux battery will go dead, if it's in reasonably good condition. I'm not sure about interior lights, but I'd be surprised if they didn't time-out as well.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Recharge the 12v aux battery, start-up the car after a few minutes. Then you will have to trickle charge the same aux battery for a couple of days until it stabilize itself.
    The surface charge to start up the vehicle will not be sufficient to render it fully usable in a long term; better yet, have it replaced under the vehicle warranty.
  6. bisco
    49,798
    dealer proxy deep sixed it before selling it to you. they tend to do that when on the lot or in the showroom. it's a small fragile battery compared to what they are used to.
  7. GregP507
    3,002
    480
    Toyota may be squandering their stellar reputation just a little. A dead 12V battery is easy to blame on the customer, justifying a visit to the service department, and the subsequent opportunity for up-selling other repairs.
  8. bisco
    49,798
    nah, this has been going on for years.
  9. asha
    asha New Member
    2014 Prius Plug-in
    Thanks. I'll try to find someone who can jump the battery when I get home. While I don't think I left any interior lights on, I can't definitely say no. However, I've been in the car with the radio on and maybe some interior lights and after a few minutes the car automatically shuts everything down and gives you a message that it doesn't want to drain the battery. I assumed that was a safeguard to prevent this sort of thing from happening... le sigh.
  10. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Can leaving the charger door opened but not plugged in cause significant drain on the 12V battery? I accidentally forgot to close it one night, and have been double checking ever since. I assume it's a small LED so it shouldn't be too much of an issue.
  11. GregP507
    3,002
    480
    It's a safeguard that works with a reasonably good battery, but it fails if there are repeated draw cycles without recharging. Such was the case in the showroom of the dealership where I bought my Prius Plug-in. Apparently people were opening doors and leaving lights on all through the day, for day after day for 2 years. The battery was destroyed when I got it.
  12. GregP507
    3,002
    480
    It's possible, if it never shuts off. The aux battery isn't very large, and if it's in poor condition, it may not take much to drain it.
  13. asha
    asha New Member
    2014 Prius Plug-in
    Got it. Thanks again. I found a jump starter at Wal-Mart that I'm going to take home with me. Fingers crossed that it was simply user error and nothing more serious.
    Here is the jump starter just in case anyone else is interested:
    Schumacher Battery Jump Starter, Electric 750 Peak-Amp - Walmart.com
  14. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    It doesn't turn off on it's own. I thought that was pretty stupid on behalf of Toyota's engineering.
  15. GregP507
    3,002
    480
    Yes, stupid engineering, if your 12V battery has a slow drain on it indefinitely, when the door is open while the charger is plugged in.
  16. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Note that you don't need a lot of peak amps since the 12v battery isn't actually starting the engine. All the 12v battery is doing is booting up the hybrid system. Now if you own another vehicle that requires the amps, that's a different story.
  17. GregP507
    3,002
    480
    That's on the plus side, but on the negative side, below a certain voltage, you can't turn the system on, rendering the car:
    Dead in the water.
  18. fuzzy1
    10,272
    Others point out that a complete shutdown and disconnection of the high voltage system is necessary for the safety of crash responders. Most of them won't touch a hybrid or EV without very strong assurance that they won't be electrocuted.
  19. GregP507
    3,002
    480
    I have one of those, but here's the one I carry in the car:
    Stanley Tools Simple Start Battery Booster: Decor : Walmart.com
    But it's no good without one of these:
    http://keysandsigns.com/image/cache/data/caraccessories/poloi-500x500.JPG
    When the battery is dead, so is the 12V socket, therefore you have to go straight to the boosting terminal on the fusebox.
    SAronian likes this.
  20. fuzzy1
    10,272
    Very serious overkill, that peak capacity is meant to help turn the starter motor of a traditional nonhybrid.
    The Prius 12V battery should not be charged faster than about 4 amps, easily with the capacity of much smaller chargers. At actual startup, the power brake system may briefly pull 50-ish amps.
