Total loss of power after 1 day?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by asha, Jul 29, 2014.
  1. asha
    asha New Member
    District of Columbia
    2014 Prius Plug-in
    Thanks. I'm not driving today (obviously) and I'm just looking for something available at the Wal-Mart across the street from my office park that I can grab and take on the metro with me home. It may be overkill, but if I does the job without blowing the car up tonight... I'm okay with that. Are there any specific risks that would prevent me from the Schumacher jump starter?
  2. asha
    asha New Member
    2014 Prius Plug-in
  3. GregP507
    GregP507 Senior Member
    3,002
    480
    The big jump-starter is overkill, and may damage that tiny thing they call a battery by boosting too many amps through it.
    The battery maintainer is designed to be left on the battery for extended periods of time, but it would get you started if you had access to a power outlet. You may have to leave it connected for over half an hour or more, before you could start your car.
    The best thing would be a smaller booster pack (with battery clips) that you can keep in the car, and recharge it once in awhile. They often have useful attachments, like tire inflators, work-lights and power-inverters on them as well.
    asha likes this.
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
    No!
    That light is only lit when it is charging!
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    Make sure your rear hatch is closed tight, rear cargo light can be on even if you think it is shut. I turn that light off so this can not happen!
  6. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    No, that light turns on when you open the charging door, but turns off once you plug a J1772 plug in. It's meant to give you light so you're not blindly plugging in at night.
    trentofdestiny likes this.
  7. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! Sorry you are right of course! I forgot about the white led light. My bad! I was thinking about the yellow charging light!
    It will Not hurt if you leave the white led light on. Almost no drain on battery.
  8. asha
    asha New Member
    2014 Prius Plug-in
    Thanks again to everyone for the information.
    I ended up buying a smaller jump starter kit (15 amps, I think). It charged the battery and the car has been working normally since. One bonus is I didn't lose any of my presets or Bluetooth connections.
    I'm going to attribute this power loss to user error. Perhaps I left a done light on or something. If it happens again, then I'll take her to the dealer.
    ftl likes this.
  9. fuzzy1
    10,050
    If you can figure out what interior lights were left on, consider changing them to LED. Standard brightness or power, not extra brightness compared to the original lights, so the current is reduced by 80 to 90%.
    This won't cure the dead battery issue from leaving lights on, but it will give 5X to 10X more hours to discover and fix the problem before the battery actually dies. This should be enough time to survive the night without going dead.
    asha and trentofdestiny like this.
  10. GregP507
    3,002
    480
    I've done that, but I'd be surprised if the interior lights didn't time-out at some point.
    But at least now I can assume that they can stay on longer with less impact on the battery.
  11. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    The ones that will kill the battery are the map lights, using the manual switch activated by pushing on the map light lens, those will not time out. BTDT.
    SageBrush and fuzzy1 like this.
  12. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Another good reason to replace the incandescent interior lights with LED's.
    Even if one or two were left on all night they probably wouldn't drain the 12v batt enough to cause trouble.
