Toyota Recalls Certain 2004-2009 Prius models for Steering, Pump Defects
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Scrittibear, Nov 14, 2012.
  1. Dana Sion
    Dana Sion New Member
    Hudson, New Hampshire
    Quite true, and many of the recalls are more so "just in case" because if something DID happen it could be quite serious. For instance the recent steering shaft recall situation says if people are operating at low speed and pretty much slamming the wheel from one full stop on the wheel to the other over time there may be a problem. Hmmmm I rarely if ever turn to a full extreme stop left or right.
    So many times it's just to be safe, they are not saying "run away from the car if you press the power button more then 1,101 times the battery bank will explode "
    They are doing the right thing and you can only hope people will understand it that way, and after what happen in the past they are being careful to make sure and not hold back if something should be done.
  2. Dana Sion
    Well then I feel bad for who ever buys my 2009 Prius used from the local Toyota dealer that I am trading into when my 2012 PIP advanced comes in as the trade in price is locked in for 30 days and it may be in the hands of the dealer before I am told I can even bring it in to look at the recall part. I hope they do the right thing before it's re-sold.
  3. dipper
    dipper Senior Member
    1,242
    252
    I remember doing this on my wife's Prius. And also the hybrid coolant pump too.
  4. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    I'm one of these people who turn the steering wheel quite forcefully at low speed and have noticed an unusual, uneven and ever more frequent judder and dull noise of the steering wheel at these occasions. I have an '07. I've never had an engine light on, but if they want to replace the electric water pump let them do it.
    How many pumps has Toyota had to recall -or issue a TSB for- on the Gen II Prius?
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Unfortunately, it seems like my replies in the other thread that came before this (but was incorrectly posted by someone else in the PiP area) are gone. I was hoping the threads would be merged.
    I wonder if this recall is related to the replacement pumps from LSC A0N - HV (Inverter) Water Pump; Dealer Letter and Technical Instructions | PriusChat crapping out. It seems a # of people had theirs replaced due to the LSC, only to have theirs crap out in w/fewer miles on the 2nd pump than the original. Hopefully these new pumps are better and not the same as the replacements from the LSC, which seem questionable...
    Maybe this means another free inverter coolant change. (y)
    Yeah, my 06 Prius (bought new in January 06) I don't think was ever part of the 1st steering shaft recall.
  6. El Dobro
    El Dobro A Member
    7,079
    3,259
    I thought that Petraeus was so upset about the scandal that he hopped into his Prius and slammed it into a house.
  7. Wimble
    Wimble Junior Member
    30
    uk
    According to UK recall website it's possible that both will need to be done to second gen Prius - takes 2.5 hours.
  8. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    A bit more info and why you might see a larger # reported: Toyota recalling 670k Prius models in US, 2.77 million vehicles worldwide [UPDATE] .
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    ...which was in Indianapolis that blew up torching the neighborhood.
  10. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    My 2008 came up with both recalls. My VIN starts with JTDKB20U78775xxxx
    From the Toyota Recall Information – 2009-2011 Recall Notices
    Below are the open Safety Recalls or Service Campaigns that have not yet been completed for your vehicle.
    Safety Recall C0U (C1U) Preliminary Notice - Hybrid Electric Water Pump
    At the present time, Toyota is currently preparing the remedy.
    What is the Condition? There is a possibility that the coil wire of the electric motor installed in the Water Pump for the Hybrid System may have been scratched during the coiling manufacturing process at the supplier. In this condition, the coil wire may corrode at the scratched portion and in some cases break. If this occurs, the water pump could stop, leading to the illumination of various warning lights in the instrument panel. In limited instances, a short circuit can occur between adjacent coil wires, resulting in an open fuse for the electric power supply circuit. If the fuse is open, the hybrid system will stop while the vehicle is being driven, which may increase the risk of an accident.
    When will the Remedy be Available: The remedy procedures will be provided to each dealership shortly. At which time, Toyota will notify owners of covered vehicles by first class mail. Additional information will be posted on this site once the remedy is available.
    Safety Recall C0T (C2T) Preliminary Notice - Steering Intermediate Extension Shaft
    What is the Condition? The steering shaft system of the subject vehicles consists of a steering intermediate shaft assembly, steering sliding yoke sub assembly, and steering intermediate extension shaft assembly. Due to insufficient hardness of the extension shaft supplied by a specific supplier, the splines which connect the extension shaft to the steering gear box may deform if the steering wheel is frequently and forcefully turned to the full-lock position while driving at a slow speed. This may create an increased backlash, and splines may eventually wear out over time, which could result in loss of steering ability.
    cwerdna likes this.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Interesting. Thanks! For my 06 where its VIN starts with JTDKB20U0631xxxxx, under RECALL ALERT, I only see
    "Safety Recall C0T (C1T) Preliminary Notice - Steering Intermediate Extension Shaft". The inverter water pump one isn't there.
    My inverter water pump was replaced at my request awhile ago due to LSC A0N - HV (Inverter) Water Pump; Dealer Letter and Technical Instructions | PriusChat.
    I don't see either recall yet at safercar.gov when I lookup the 06 Prius.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I doubt I have turned the steering wheel all the way to one side 10 times in the past 9 years, let alone aggressively. If I had known this was the required abuse necessary to risk failure I would never have bothered with the recall in 2005.
    As for the coolant pump -- is this inverter or engine ? So long as I have warning of impending failure I'll just replace it if needed.
  13. El Dobro
    El Dobro A Member
    7,079
    3,259
    Inverter pump.
  14. Flying White Dutchman
    4,376
    313
    strange
    i already have a steering shaft recall done and a electric coolant water pump .... and now there is again a same recall?
    did they discover that also other cars that where not involved in the recall before also have trouble or is this still the same recal that they updated?
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  16. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    Yes re: steering shaft they have expanded the scope of vehicles to include most/all GenII, whereas as prior recall ended at early 2006. I think we have a few reports of steering failaure on Prius Chat but most of those involve the pre-early 2006 cars, perhaps I can think of one steering failure reported here on a post-early-2006 car. Mostly the failure does not occur because the recalls fix the problem before the failure is seen by most.
  17. Tideland Prius
    16,499
    How does this differ from the steering wheel recall back in 2005?
  18. Trollbait
    12,430
    ON CERTAIN PASSENGER VEHICLES, THE STEERING YOKE WAS NOT WELDED TO THE STEERING SHAFT. IF THE VEHICLE IS OPERATED IN THIS CONDITION, THERE IS A POSSIBILITY THAT THE YOKE MAY COME OFF FROM THE SHAFT, AND COULD RESULT IN A LOSS OF VEHICLE STEERING CONTROL.
    STEERING:COLUMN Recall for 2005 AVALON TOYOTA Auto Recalls - Justia Car & Truck Recalls
    That's the recall from 2005. The article at cleanmpg said the current one was because the gearing on the shaft wasn't properly hardened, and the gear teeth could deform leading to slippage.
    Tideland Prius and wjtracy like this.
  19. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  20. Adam Leibovitch
    498
    102
    The Prius I crashed last month would have needed this.
