Toyota to Recall 1.9 Million Priuses to Update Software
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Nicaaz, Feb 12, 2014.
  1. Nicaaz
    Nicaaz Junior Member
    16
    Toronto Canada
    2013 Prius Alpha
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I have no reason to expect it is not. If it is, you will be notified when the dealer has the update.
    So far, the v has not been mentioned in any material I have seen.
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  4. Nicaaz
    16
    Toronto Canada
    2013 Prius Alpha
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    My v doesn't show any recalls, does anyone else yet see this on their VIN?
  6. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    The V (Prius+ UK) is not affected as it uses different electronics in the boost control circuit.
  7. crpriusv
    crpriusv Junior Member
    43
    Delaware
    My 2012 v isn't recalled either. But I'm not sure how up-to-date the information is on that site...does it include this latest recall?
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Hey, there was a whole different thread, I think the original one announcing the recall, that I was discussing the recall within.
    Suddenly it has disappeared along with any evidence of my communication within it.
    What gives?
  9. bisco
    48,999
  10. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    It's been recalled :whistle:
    WE0H and Braddles.au like this.
  11. The Electric Me
    9,083
    5,796
    Relatively unamusing smilies aside...
    I'd be very disappointed if the thread was removed.
    IMO there was no commentary that wasn't valid. It was discussion about the recall, and about the definition of the problem.
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Yes, I was just trying to locate that thread also. I too would be disappointed if it was removed due to comments made not favorable to Toyota.
  13. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    Don't know where the other thread went. As I stated yesterday, I had the update performed at my dealership. I wanted to get in there before another 10,000 or so Prius showed up. It took an hour. I have no noticeable difference in performance, although, I have noticed that my cruise control is letting the car creep above my set MPH by one MPH and then slowly goes back down.
    No parts are needed to be ordered as others have been told by their Service Advisers, it is just a download from Toyota to the techs computer, which he then installs to the vehicle.
    I am hoping the new software has some improved algorithms. Maybe Toyota is using us to Beta Test new software?
  14. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    Yeah, and I was just gearing up to put up a basic explanation of how switching transistors can make sine waves and vice versa. Now it's all gone.
    I don't remember anything negative, just people falling all over each other talking about the recall. I wonder if it was the beginning of my tech explanation of How Things Can Go Wrong that did it? It's not like that stuff is rocket science, pretty much any EE/EET knows how inverters work.
    KBeck
    cwerdna likes this.
  15. bisco
    48,999
    i thought it was one of my better ones.:oops:
  16. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I am bad. I am the one pointed out Toyota is doing a software fix for a hardware problem to save hundreds of millions of dollars.
  17. Former Member 68813
    3,524
    981
    US
    Too bad the previous thread was censored. Is anyone planing to do before and after 0-60 times?
  18. bwilson4web
    15,410
    I'll run a series of benchmarks before the patch and then afterwards:
    • max hill climb
    • "B" mode descent
    Can anyone remember any other items to test?
    WE0H likes this.
  19. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yeah, what happened to it??? I started it.
    Finally, NHTSA has documents on it. See http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM450077/RCAK-14V053-1068.pdf and http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM450071/RCDNN-14V053-0945.pdf.
    You can easily find it by searching for campaign 14V053000 under ID number, then going to Associated Documents from
    Code:
    http://www-odi.nhtsa.dot.gov/owners/SearchSafetyIssues
    . I'm sure more documents will be posted, including the procedure.
    I sure hope at least kbeck's post can be restored.
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
