Toyota Unveils Advanced Prius Tech
Discussion in 'Gen 4 Prius Main Forum' started by Jeff N, Oct 13, 2015.
  1. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I suspect they have just been busy and forgot to mention the "e-four" option. Tideland, cars coming to Canada must all be "certified" for Canada. There is no "me too" for US certification. I'm going to go out on a limb and predict WE will see the system, and the US will too. There are lots of skiers who will want it at any cost and lots of cars sold in the NE US. It's a no-brainer for Canada.
    The induction motors sometimes use "slip rings" to supply current to the rotor for magnetizing, allowing them to have good torque at low RPM (the induction magnetization isn't very effective until the rotor is turning at least 10% or so of rated speed). This would require DC as well as the three phase AC to be supplied, but I suspect the main reason for using these is to reduce reliance on rare earth materials, which are pretty much controlled by China.
  2. Mendel Leisk
    40,717
    Seems like they're shrinking battery size and loading them up more. Hopefully they don't go down the same rabbit hole as Honda.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  4. E46Prius
    E46Prius Active Member
    314
    219
    Costa Mesa
    ^Very good post thank you!
    giora likes this.
  5. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    " To improve brake feel and control while reducing noise reduction, the all-new Prius utilizes a newly-developed active hydraulic booster for its regenerative brakes."
    This is from an official press release. I don't understand what they mean by an "active hydraulic booster."
  6. Tideland Prius
    16,466
    I'm no engineer but my interpretation of that statement is that the car will preemptively provide power brakes via the hydraulic brakes to smooth out the transition from regen to friction brakes as opposed to now where it'll only activate when the friction brakes are applied.
  7. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    At the end of the Web page behind this link there are two interesting pdf's. For example, page 16 of the second one shows how the engine can stop at higher speeds than for the Gen 3 (110 km/h vs 60 km/h according to page 6 of the document here).
    giora and Jeff N like this.
  8. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Gen 3 can stop the engine at about 75km/h. Gen 3 PHV can stop at higher speeds, about 90km/h, with the same hardware (P410 transaxle).
  9. GasperG
    GasperG Senior Member
    1,168
    600
    Slovenia
    2018 Prius
    75 kmh on EU cheating spedometer ;)
  10. fotomoto
    fotomoto Senior Member
    5,630
    3,804
    So. Texas
    My wife's subaru does that now. It's a great idea that applies to many other situations.
  11. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Increasing engine stop speed from 70 to 110 km/hr.
    Improving cd from 0.25 to 0.24 and slightly less frontal area.
    Good signs that highway fuel efficiency improvement may be as dramatic as city improvement.
  12. HGS
    HGS Member
    307
    123
    Unless I'm looking for it, I don't notice the change over from regen-braking to hydraulic braking at low speed (7 mph?). I'm sure there is a good reason for a new braking system, but I'm very happy with my Gen 3 brakes.
  13. KrPtNk
    323
    283
    Pacific Northwest
    Thank you. I don't drive a Prius (yet) so I am unable to understand how this improvement would alter the driving experience. Also I wonder if it could increase the amount of energy captured in regen braking.
  14. bwilson4web
    16,050
    That comes from the page describing the higher charging capabilities of the new traction batteries. Today, charging limits determine when the mechanical braking augments the regen braking.
    Tideland Prius likes this.
  15. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I noticed that the new MG2 has adopted the use of rectangular wire "bar windings" very similar to the style used in the first and second generation GM Volt.
    Here's an image of a Volt motor below:
    #55 Jeff N, Oct 16, 2015
  16. KrPtNk
    323
    283
    Pacific Northwest
    What do they mean by "newly developed active hydraulic booster"?
  17. bwilson4web
    16,050
    We may have to wait for the "New Car Features" to get the details. The existing brake uses a metal bellows filled with nitrogen and a high-pressure, electric pump, and complex valving. It is complex yet amazingly effective. Such parts are subject to redesign using "lessons learned."
    Trollbait and KrPtNk like this.
  18. Lee Jay
    Lee Jay Senior Member
    5,850
    4,031
    Westminster, Colorado
    This is most commonly called "form winding" as opposed to "random winding".
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Notice in here (page 3) that they have improved cabin warm up in a cold day.
    Google translate:
    Third generation Prius, while stopping the circulation of cooling water to the engine warm-up, was to specifications that can not use the heating by the heater.Accordingly, etc. When the vehicle compartment is cold in winter, it can not be warmed by the heating had become a challenge immediately. The two lines branching cooling water, even before the engine warm-up, it has become possible to use the heating immediately by circulating cooling water to the heater side.
    In two lines branching they refer to the lines from the EHR heat exchanger.
    #59 giora, Oct 16, 2015
  20. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Here's a good technical background write up.
    http://www.wardleonard.com/filephotos/1/Technical-Note---Random-Wound-.pdf
    Bottom line is that form windings are more common in larger motors, tend to have better "slot fill" (less wasted space), and are more rugged and less susceptible to voltage spike damage or physical wear from vibration.
    All of the motor windings on hybrids or plugins that I have noticed have been random windings (including Tesla) except for GM Volt/ELR/Malibu/Spark and now MG2 on the new Prius.
