For Sale Transaxle fill/drain aluminum crush washers
Discussion in 'Private Sales' started by xliderider, Aug 26, 2014.
  1. xliderider
    xliderider Senior Member
    7,904
    3,136
    Honolulu, HI
    I have 7 sets of aluminum crush washers (18mm ID x 24mm OD x 2mm thick) for sealing the fill and drain bolts when doing a drain and fill of the Prius transaxle (transmission).
    These are not oem washers, but they are the proper size. Oem washer on the left, washer for sale on the right:
    I recently completed a transaxle fluid drain/fill on our Gen 3 Prius using these washers.
    Each set of 2 washers are $2.50, $4.50 if you want 2 sets (4 washers).
    PM me if interested, with your name and address, and I'll provide you with my PayPal account email address.
    The oem washers were $2.75 per washer plus tax at my dealer. Once the 7 sets are gone, I will not be selling more. ;)
  2. xliderider
    7,904
    3,136
    Honolulu, HI
    ttt. No one changing their transaxle fluid? :D
    SCH-I535
  3. tigerpilot
    tigerpilot Member
    141
    Naples FLorida
  4. xliderider
    7,904
    3,136
    Honolulu, HI
    pm sent. Thanks. :)
    SCH-I535
  5. xliderider
    7,904
    3,136
    Honolulu, HI
    Bump, still have several sets available. :)
  6. project_tl
    project_tl Junior Member
    22
    Do these fit on Gen 2?
  7. Mike500
    Mike500 Senior Member
    2,593
    764
    YES!
  8. xliderider
    7,904
    3,136
    Honolulu, HI
    Bump. Still available, fit Gen 2, Gen 3, and v wagon transaxle drain and fill plugs. Also fits the inverter coolant drain plug as well.
    SCH-I535
  9. OzPrius
    OzPrius Junior Member
    43
    New South Wales Australia
    Postage to Australia would be more than the parts :(
  10. xliderider
    7,904
    3,136
    Honolulu, HI
    Sorry, yes, no international shipping. :(
    SCH-I535
  11. vegas4x4
    vegas4x4 Junior Member
    Las Vegas, NV
  12. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Welcome to PriusChat Vegas4x4!
  13. xliderider
    7,904
    3,136
    Honolulu, HI
    Crush washers will be mailed out today. Thanks!
  14. xliderider
    7,904
    3,136
    Honolulu, HI
    Still have 2 sets (4 washers available). Fits transaxle fluid drain/fill and inverter coolant drain plug locations.
  15. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    i bought two from dealer last week...
    fill plug's washer was literally glued to the plug so i was only able to change on the drain plug...
  16. xliderider
    7,904
    3,136
    Honolulu, HI
    Should of tried some gentle heat from a heat gun or torch to soften the adhesive, then separate the washer from the bolt.
    Yours might be the first report of a glued on washer. Makes no sense. :confused:
    SCH-I535
  17. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    it literally was in one piece...
    oh well, will get new plug...
  18. xliderider
    7,904
    3,136
    Honolulu, HI
    Still have 4 washers, 2 sets available.
  19. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
  20. xliderider
    7,904
    3,136
    Honolulu, HI
    Message received and response given.
    1 pair of washers remaining. :)
    SCH-I535
