Turn off the damn backup beep
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by alanvw, Dec 10, 2011.
  1. RAM v
    RAM v Junior Member
    71
    St. Paul, MN
    2014 Prius v wagon
    Along the same lines, does anyone know the scangauge codes to make a remote keyfob unlock press unlock ALL doors on first press, not just the drivers door?
  2. Aaron Roemer
    Aaron Roemer Junior Member
    United States
    2013 Prius v wagon
    To use Techstream, just go to Amazon and buy any Mini VCI cable. I bought this one.
    Amazon.com : Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software : Toyota Mongoose Cable : Car Electronics
    The software that came with mine wasn't the newest out there so I just downloaded the most recent version. You can find it pretty easily. Then you'll need the Mini VCI drivers. The hardest part for me was locating an XP computer to run it on (software needs XP, but there's a work around for newer PCs). Then it's just plug-n-play.
  3. Mendel Leisk
    38,332
    Not sure about the v, but with a regular Prius there's a procedure outlined on page 48 of the Owners Manual. No need for ScanGauge, it's a regular, owner customizable setting:
    DogDaze likes this.
  4. xliderider
    xliderider Senior Member
    7,852
    3,103
    Honolulu, HI
    That's for the door handle setting, they're asking about using the keyfob unlock button. I've done the door handle setting to unlock all doors and hatch, but it still requires two unlock button presses on the keyfob to unlock all doors/hatch.
    #104 xliderider, May 26, 2015
    DogDaze and Mendel Leisk like this.
  5. Mendel Leisk
    38,332
    Hmm, you're right. And two obnoxious beep-beep, beep-beep's to boot.
    DogDaze likes this.
  6. PeacePeace
    PeacePeace New Member
    Oregon
    2015 Prius v wagon
    Very kind of you, ready to help others. If I was in CA I would had stopped by. I'm in OR, anyway u can help ?
    DogDaze likes this.
  7. bisco
    49,079
    of course, dianne is up there all the time at her summer place.(y)
    DogDaze likes this.
  8. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Yep, was the FIRST thing on my list when I dropped mine off to Toyota for a once over after I bought it; former fleet vehicle so even as a 2013 it STILL had the backup beep (constant beep) when put in reverse. They did not charge but I did have A LOT of other routine maintenance done so that's probably why.
    DogDaze likes this.
  9. Mark F.
    Mark F. New Member
    Columbus, OH
    I have a 2012 Prius and this did not work for me. After entering the "AT SH 7c0" and getting the "OK", I entered the "21ac". But instead of the expected response, I got "NO DATA" instead. Any ideas?
  10. jacktechie
    jacktechie Junior Member
    27
    South SF Bay Area
    2014 Prius v wagon
    I got the same thing several times. Keep tugging at it and you will succeed. Sorry can't tell you more since I did this 7 months ago.
    DogDaze likes this.
  11. Mark F.
    Mark F. New Member
    Columbus, OH
    The trick turned out to be that you have to enter "atsp6", send, and only then send the "AT SH 7c0" etc.
    DogDaze likes this.
  12. stpeterick
    stpeterick Junior Member
    st pete fl
    At 5000 mile service, tech "adjusted" both seat belt and backup buzzer. What a relief!
    DogDaze likes this.
  13. cucaio90
    cucaio90 Junior Member
    48
    debary ,fl.
    2015 Prius v wagon
    Beep or not to be beep....I like my beeps.
    DogDaze likes this.
  14. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    the beep saves lives, how long do you sit with the car in reverse anyway?
    DogDaze and cucaio90 like this.
  15. Red15Persona
    Red15Persona Junior Member
    35
    North Carolina
    You really think the interior beep saves lives? How about just paying attention when you're in reverse. It's annoying and unnecessary. I'm so glad I got it turned off when I purchased the car.
    LG-D801 ?
    DogDaze likes this.
  16. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Just wondering - does the beep get completely de-activated ? My Prius v 2015 is getting delivered early next week and I've asked the dealer to disable it. I've read different things where people say it's completely gone, some say it still beeps but only once. I'm just curious!
    When I went for a test drive with it - that's the first thing I said to the sales rep "That's realllly annoying"!
    DogDaze likes this.
  17. xliderider
    7,852
    3,103
    Honolulu, HI
    You can't disable it completely, some dealers won't do the modification if you ask to "disable" the reverse beep. For this reason, you should ask to have the reverse beep setting changed to single beep, not "disabled". ;)
    The only options are continuous beeping or single beep when shifted into reverse.
    DogDaze and ricomtl like this.
  18. Red15Persona
    35
    North Carolina
    When you put it in reverse it's a single short beep.
    LG-D801 ?
    DogDaze likes this.
  19. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Thanks! :D
    Red15Persona likes this.
  20. fopoku2k2
    fopoku2k2 Member
    292
    59
    Columbus - Ohio
    What code did you use to turn off the seat belt beep?
    XT1060 ?
