turning off beep while in reverse
Discussion in 'Gen 2 Prius Technical Discussion' started by derh2o, Apr 8, 2011.
  1. derh2o
    derh2o Junior Member
    34
    i have done this before, but did not document how i did it. i will this time. i followed other discussions and read comments, but were not any instructions of how to do it. there are a few links that are supposed to tell you, but those links did not lead me to any instructions. i am hopeful someone here can help. thank you.
  2. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    ELIMINATE REVERSE BEEPS.
    1. Power on the car to IG-ON or Ready.
    2. using the Trip/ODO button, set the trip/ODO display to ODO (Not trip A or B)
    3. Power off the car.
    4. Now power the car to READY (Brake on). This is required so that step 6 works correctly.
    5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more.
    6 While still holding the ODO button *after* the 10 seconds, shift the "gear" selector from P to R then back to P. Now release the ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip odometer or Odometer is normally displayed ("b on" is beep on) ("b off" is beep off).
    8. Press Trip/ODO button to toggle the mode.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected.
    silver_05 and derh2o like this.
  3. derh2o
    34
    thanks, i will give this a try.
  4. Chris2128
    Chris2128 New Member
    85
    Oklahoma
    Will that work for a gen III?
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    No.
  6. Chris2128
    85
    Oklahoma
    Can a scanguage II do it on a gen III?
  7. wslin
    wslin New Member
    Massachusetts
    Yes, SG II can turn off (or rather make it a single
    beep) the reverse beeping on a 2010. I have not tried
    it on a 2011.
    Cheers,
    Bill
  8. Chris2128
    85
    Oklahoma
    Heres a silly question. Will the beep come back if you take off he scanguage and return to your friend?
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No, but it will come back when the 12 battery dies.
