Typical lifetime of 12V battery...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ichiro, Mar 28, 2012.
  1. Mendel Leisk
    41,486
    I do what I can to minimize the chance of an accidental drain, shutting off of the hatch and dome lights, periodically checking the 12 volt's voltage and hooking it up a maintenance charger. And then:
    I replace it after about 4 years, regardless of it's condition. With just the OEM, nothing fancy.
    kenoarto and HaroldW like this.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Optima batteries are warrantied for a maximum of 36 months.
  3. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The Exide Edge battery is warrantied for 48 months.
  4. kenoarto
    398
    Chicago, IL
    Optima web site clearly says 36 months. In any case, there's your proof: batteries are only expected to live about 4 years. You are taking risk to expect anything but problems as documented, here on PriusChat.
  5. Britprius
    5,194
    1,921
    I repeat the Exide Edge battery part number FP-AGM51JIS is available in the US has a 4year (48mnths) full replacement guaranty and is a deep cycle AGM battery with a higher amp/hr capacity than both the OEM and Optima batteries. It is a direct replacement for the Prius battery and comes with the small posts (JIS) and breather hole at about $160. There is a $20 off coupon on line at the moment.
    This battery is expected to last a lot more than 4years. Check on Exides web site and if you have not herd of Exide the are one of the biggest manufacturers in the UK and have been around for over 100years. The Exide Edge battery is made in the US.
    In the Uk and Europe there are batteries made by Bosch and Varta that have 5year guarantees these again are full replacement if the product proves not to last that long and Lucas are bringing out a range with an eight yes eight year guaranty.
    HaroldW and uart like this.
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks Britprius. So the "JIS" suffix is important right.
    Unfortunately I don't seem to be able to get that one anywhere in Australia. I found this one (which ships to Australia) on ebay, but I don't think it's the right one (doesn't say "JIS" anywhere). : Exide Edge Group 51 Flat Plate AGM 440CCA | eBay
  7. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    Take your car to Autozone, Advance Auto, Napa, Pepboys or any other automotive parts store and they will do a free load test on your battery. Typically batteries last 4 years and then slowly start to lose performance.
    Just think how much it will cost if you get stranded on the side of the road with a dead battery. The tow charge alone would pay a significant cost of a new battery. I don't think you can put a price on peace of mind.
    Maybe I over maintain my cars but at 4 years I will change the battery. At 20k I changed the oil in the CVT transmission.
    kenoarto likes this.
  8. Britprius
    5,194
    1,921
    Yes that is the same battery (size, amp/hr capacity) but has the standard (larger) posts still worthwhile fitting, getting negative cable from breakers off almost any car and adapting the positive connector. I would try asking the supplier if they can get the JIS version of the battery. Remember a good connection is important but the Prius battery connections do not need to carry starter motor current.
    The kit that was used with the Optima would also do the trick.
    John.
  9. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Sorry to interrupt, but I am about to purchase a new battery for my 2007 Prius. I was looking at the yellow Optima, but now am very interested in this Exide battery mentioned by Britprius (Exide Edge battery part number FP-AGM51JIS). Sounds like the way to go.
    Would I need some sort of adapters for this battery? That is the part which is confusing to me as I read through these posts. Or would this battery simply drop right in as the yellow Optima will?
    Thank you very much.
    Julia
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Julia. No you wont need any adapters if you get the correct part number. That's the one with the "JIS" suffix.
    I'm in Australia however and cant seem to find that one here.
  11. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you very much, uart. I appreciate your response.
    You are a very helpful PriusChat member.
    Thanks for your many helpful posts in response to my way-to-many questions!
    Julia
  12. Julia2001
    Julia2001 Member
    290
    32
    Maine
    That should read "way-TOO-many"!!! :mad:
  13. Britprius
    5,194
    1,921
    Hi Julia as Uart said the Exide is a direct drop in replacement providing you get the JIS version.
    John.
  14. Julia2001
    Julia2001 Member
    290
    32
    Maine
  15. Julia2001
    Julia2001 Member
    290
    32
    Maine
    I bought the Yellow Optima battery from Advanced Auto. 15% off the regular price of 199.99 -- overnight delivery to my local store.
    Now to see if I am capable of installing it! Off to read posts and watch videos to prepare myself!
  16. PriusDIY
    PriusDIY Junior Member
    49
    Minneapolis, MN
    Anyone notice how this website states "Prius Starting Battery." :LOL:
    I will be getting the direct fit Optima yellow top when the time comes. I'm still on the original OEM battery which is probably 4+ years old now.
  17. Britprius
    5,194
    1,921
    Well it does start the computers and and connects the HV system without witch the car cannot move.
  18. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
  19. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I have noticed my mileage slowly dropping, and did a load test using the on board MFD diagnostics.
    The video says to hold down the "display" button before flipping the headlights 3 times.
    For my 2009 Prius I've been holding down the "info" button before flipping the headlights 3 times. I'm at 11.8 volts at the first diagnostic check 11.7 - 11.4 volts under load, and 14.0 volts with the engine running. I've ordered a Optima Yellow Top 8171-767 and should be delivered in a few days.
    Watched this video to learn the necessary steps to install it when it arrives. The video, is slow moving but very detailed.
    there is also this video which is much shorter and to the point:
  20. PriusDIY
    49
    Minneapolis, MN
    Ok, yes technically I guess the description works. I should have stated traditional car vs hybrid....
