Ultra Gauge, mg1 or mg2 temperatures
Discussion in 'Gen 3 Prius Technical Discussion' started by joematlack, May 22, 2013.
  1. joematlack
    joematlack Junior Member
    I just installed an Ultra Gauge on my 2012 Prius, I wanted to see engine rpm,s and temp, no problems with getting these values, now I want to see battery temp and mg1 and mg2 temps, I don,t see these any where, Anyone able to get these without a degree in computer science?
    Thanks, Joe
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I use both Ultra Gauge and Scangauge. Ultra Guage does not have the codes needed for non conventional vehicles like the Prius. That's why I also bought the Scangauge.
  3. syscon
    syscon Member
    329
    42
    Edm. Alberta
    I have an Ultra Gauge as well and find it to be very limited in use.
  4. joematlack
    Thanks, I should have bought a Scanguage!!!
    Joe
  5. Feri
    Feri Active Member
    761
    144
    I find using the two in tandem is very useful. The UltraGauge shows all the conventional stuff like RPM and engine temp etc. and its display is easier to read. I use the Scangauge to show all the Hybrid stuff like traction battery voltage, inverter temps etc.
  6. syscon
    syscon Member
    329
    42
    Edm. Alberta
    But you can have only connected one at a time, isn't it?
  7. Feri
    Feri Active Member
    761
    144
    No I have a splitter. I did have trouble at one time with a false emergency warning but since then I have used them in tandem without problems.
  8. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Just consider the Torque Android application as an alternative. I use it on BT OBDII adapter & cheap mobile phone combo for years. It is fully flexible for PID settings, gps tracking, different gauges .....
    Bob G IA likes this.
