Upgrade to 17" wheels and tires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by joeb24, Jan 5, 2010.
  1. joeb24
    joeb24 Junior Member
    Alexandria, VA
    I bought a Gen III Prius IV a couple of weeks ago and am thinking of upgrading to 17" wheels and tires. Question: Will handling improve, or is the better handling of the Prius V with 17" wheels due to a stiffer suspension on the V? Also, will I have to install new TPMS sensors on the new wheels, or can the sensors on the present 15" wheels be used on the new 17" wheels? These sensors seems very expensive. Can anyone recommend websites, other than TireRack, that sell !7" wheel and tire combinations for 2010 Prius?
    Thanks!
  2. Creaky
    Creaky Still motorin...
    85
    New York, NY
    Congrats on the recent purchase.
    I was in your shoes a few months ago myself. I ended up buying my 17's from TireRack, but I also looked at DiscountTire and any other online vendor I could find at the time.
    Going with 17's did improve the handling of the car, expecially in taking on/off ramps, the car feels as if it's not running at the limit anylonger. Although body-roll is still present, it's manageable. To address that, we'll need larger anti-roll bars. But of course, because of the lower profiles of the 17" tires, the ride will be firmer, feeling more of the surface irregularities than you would with your 15's.
    From what I understand, the suspensions between the IV and the V aren't different. The steering turning ratio and steering wheel speed is the only difference between the two as the motors used differ between models. Because I haven't driven a V, I can't make any comparisons for you.
    You can take your TPMS wheel sensors off of the 15's and transfer them to your new 17's. That'll definitely save you a bundle.
    Hope this helps answer your immediate concerns.
  3. joeb24
    Alexandria, VA
    Thanks very much for the input. Which wheels and tires did you get from TireRack? So an installer will transfer the TPMS sensors from the 15" wheels to the 17" wheels, right? And a Toyota dealer will have to adjust the speedometer for the larger wheels, right?
  4. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    A few of us have the motegi sp10 which are light weight at a good price. I bought them from tire rack, then bought continental extremecontact dws 205/50R17 from discount tire that charged me $30 for rebuild kits to move my tpms sensors from my 15" wheels. The new tires are very close to the same size of the yokohamas. Most people upgrade to the same size as on the V 215/45R17 which are slightly smaller than the stock 15", but your speedometer should read at most 1mph fast. Tire rack has revolutions per mile on their site for comparisons.
  5. joeb24
    Alexandria, VA
    Thanks very much.
  6. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    Congrats on your Prius! I've had mine for about 5 weeks, had this idea myself when I first got mine, a IV. I don't know what you can get a set of wheels for from these "aftermarkets", but I found a set of original Toyota V, 17" wheels at auction on Ebay, (didn't buy them, maybe should have). I think they ended up selling for over $700, had no tpms valve stems on them. You might keep watching on Ebay, as there are people, dealerships as well, for customers, who buy the V's and then want aftermarkets on the car. I think I've decided to buy the center caps for the 15" wheels and go that route. I really want the "mud guards", but want some that can be painted in my Barcelona Red, to match the cars color. :D
  7. kurtvote
    kurtvote New Member
    Fresno, CA
    I shopped around and ended up using Tire Rack The TPMS sensors from factory 15" wheels can be used on your new 17" wheels. I chose 215/45R-17 Bridgestone Potenza G 019 Grid XL tires (50,000 mile treadlife warranty) and 17X7.5 Elbrus I02 SDC Ice wheels. Great handling. So far, loss of only 1-2 mpg.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Nice rims, and the 1-2 mpg hit is about equivalent to the stock 17" on the V.
  9. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
    kurtvote, those came out great! I love the stock 17's, but I think those just might be even nicer-looking. Good job!
  10. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    They really do look nice - not over the top. They look like they could have come that way. Did you notice any difference in ride or noise?
  11. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    Maybe upgrade to 17" brake pads instead?:D just kidding.
  12. Much More Better
    Much More Better Active Member
    655
    163
    Nice rims Kurtvote.
