UV Protection on the Prius C?
Discussion in 'Prius c Accessories and Modifications' started by xecure, Jul 25, 2015.
  1. xecure
    xecure Junior Member
    Bay Area
    2015 Prius c
    Hey guys, I recently leased a 2015 Prius C and was wondering if the windows blocked out a percentage of the UV rays. I have some issues with my skin after long sun exposure and was wondering if the stock glass does the job already or if I should get some tints installed.
    49,799
    congrats and welcome! idk, does tinting block uv? i use a sunshade on the door window, but i dk if that blocks uv either. i do know the prius greenhouse design makes it impossible to escape the sun. i'll be interested to see if anyone knows. all the best!(y)
  3. orenji
    orenji Senior Member
    5,884
    3,486
    My understanding the side glass does block out 100% of UV and so does the front.
    #3 orenji, Jul 26, 2015
    xecure likes this.
  4. xecure
    Bay Area
    2015 Prius c
    Do you by any chance have source for this info?
  5. orenji
    5,884
    3,486
    Look at the small print on the glass. Not all windshields are the same....and the majority of them offer up no protection at all. Toyota does promote the fact that the windshield on it's prius models block all UV rays.
    #5 orenji, Jul 26, 2015
    xecure likes this.
  6. xecure
    Bay Area
    2015 Prius c
    I'm confused, the majority of windshields offer no protectional at all but toyota promotes the fact that the windshields on it's prius blocks all UV rays?
  7. orenji
    5,884
    3,486
    Not sure what you are confused by? Most windshields offer very little protection, but in 2011 TOYOTA started offering glass with 99% blockage of UV Rays.
    xecure likes this.
  8. xecure
    Bay Area
    2015 Prius c
    Oh you meant most windshields on cars in general? And then in 2011 Toyota starting offering UV protection for the windshield it shipped with it's Toyota prius?
  9. orenji
    5,884
    3,486
    Not sure when TOYOTA started to offer protection on the front windshield for the Prius, but in 2011 they started to offer 99% UV protection on the side glass on all Toyotas.
    xecure likes this.
  10. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi xecure,
    Here is the spec. from the NCF:
    Vincent
    xecure and masterC like this.
  11. Roy Lin
    Roy Lin New Member
    Currently in Taiwan
    2014 Prius c
    WOW, thanks for the info above.
  12. orenji
    5,884
    3,486
    Where you getting this info? US Prius C does not use green or gray tint. US model glass blocks out 99% of all UV.
  13. Roy Lin
    Roy Lin New Member
    Currently in Taiwan
    2014 Prius c
    We Taiwan's Prius C has minor green color window; however, only four windows and rear windshield have UV mark on it; front windshield doesn't have. So we are also curious if front windshield has UV block function or not, though some people said front windshield is laminated, it originally has UV block function.
  14. IL Traffic Attorney
    IL Traffic Attorney New Member
    Naperville
    Sorry to post on such an old topic but where did you get the is information? I've been searching for weeks and visited several dealers who can't tell me anything like this.
  15. orenji
    5,884
    3,486
    Toyota uses UV glass on windshield and side glass, it cuts out 99% of all UV.
  16. IL Traffic Attorney
    Naperville
    I understand that but for my case, I drive 30,000 miles per year. I really want to confirm this information is accurate. I have called Toyota several times, spoken to nearly 10 dealerships, and even have a field tech looking into this question and they still haven't found this graphic. I was wondering where it came from so I could confirm the authenticity with Toyota and whether it applies to my 2012 model Prius C.
    I really appreciate your post and your response. Had you guys not provided this, I would have no way to show that there is UV protection on the windows and find myself paying for tints I don't need. That said, my health depends on having a verifiable answer to this question of where this information is located given that I spend on average 4-6 hours per day in my car during peak sunlight hours. I'd like to be able to confirm this information with Toyota.
    Thank you in advance. I truly appreciate the time you are taking entertaining such an old post.
    BTW, I found out where that image comes from. It is pulled from the "New Car Features" section (NCF) on the Technical Information System for Toyota vehicles.
    Toyota looked it up and verified this was accurate. The image posted by vincent1449p is correct. They stated that the numbers for the green glass were the correct numbers.
    #16 IL Traffic Attorney, May 25, 2016
  17. bisco
    49,799
    uv protection is important to everyone who is intent on reducing the possibility of skin cancer, and even more important to those with history or weakened immune systems. if this data is true, toyota should be working with an official agency to promote the benefits.
    keep in mind, there are uva and uvb rays. b cause sunburn, and a cause cancer.
    #17 bisco, May 25, 2016
  18. Kenny94945
    Kenny94945 Active Member
    788
    401
    Sausalito
    2016 Prius v wagon
    Wow...that is an unexpected perk.
    My v has so much glass.
    I am glad the OP asked this question.
  19. bisco
    49,799
  20. orenji
    5,884
    3,486
    "Combined with UV-reducing windscreens, the use of the new front-door glass will result in an approximate 99 per cent reduction in overall UV penetration through the front-door windows and windscreen. Toyota estimates that the resulting sunburn protection is equivalent to that of wearing gloves while driving.
    Windscreens, which use laminated glass, reduce UV by approximately 99 per cent through the use of a UV-blocking film between two sheets of glass in the laminating process. Door windows, however, generally use single-piece tempered glass that is often instilled with UV-absorbing material to achieve approximately 89 per cent UV protection." Motorward.com
