VW says, fuel cells stupid for the next decade.
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by austingreen, Mar 16, 2013.
  1. austingreen
    austingreen Senior Member
    13,663
    4,204
    Austin, TX, USA
    One challenging for phevs is absolutely charging infrastructure. I consider this a 30 year problem if the US decides to go 100% plug-in. I don't think we need to do that. What about for 15% plug-in the same number NREL thinks it should use for considering hydrogen fueling infrastructure (100% would cost taxpayers trillions of dollars by any estimate). 15% is probably doable in infrastrucrure for plug-in cars in the next 5 years. That is not much of a problem.
    Why 5 years? Only the tesla S and X are available with a greater than 150 mile range. That limits many people to a phev, and the choices volt, i3-rex, i8, etc aren't going to hit enough people. In 5 years the outlander phev, prius phv gen II, bolt, gen II leaf, 200 mile range audi SUV, tesla model III, etc giving choices from the smart fourtwo to the model X and many choices in between.
    UCS estimates 40% of the people have access to a plug, and could do with one of today's plug-in choices. With the changed california law and more insight with many states and locallities, in 5 years many more appartment dwellers will have access to plugs either at home or work.
    Going past that 15% may be tough with low gas prices. I'd say lets worry about 15% before 100% and we are almost there.
    Hydrogen fueling is much more of a problem. I doubt over 0.1% of americans would have a commute and lifestlye that would let them use what is planned for the next 5 years (2020). There will probably be at most 30,000 fcv world wide and the fueling networks worldwide will still have strains to handle that quantity of cars, but maybe then we will have a technical advance that reduces the subsidy necessary to build hydrogen infrastructure. .
  2. orenji
    orenji Senior Member
    5,887
    3,488
    In California where the majority of alternative fuel vehicles will be sold at first, there is no wide spread installation of charging stations at Condos or apartments. At this time there are no laws that when a new development is built that there needs to be charging stations included in the plans. Maybe this is one of the reasons Tesla is installing random charging stations through out the state. So owners of condos and apartment dwellers who don't have a garage are more likely not to purchase an EV.
  3. Zythryn
    Zythryn Senior Member
    6,408
    4,406
    Now this, I completely agree with.
    Here in Minnesota ther is also no wide spread installation of chargers at multi-housing dwellings. What I took point with was your implication that there were none. Current plugin owners will gravitate towards the ones that do.
    As more and more people start driving plugins, more and more multi-housing units will make that available.
    And that will happen faster than hydrogen stations pop up across the U.S.
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I think the future of plug in chargers might be challenged. Below ground inductive charging might be the competition. That would solve the snow removal obstacles of the high snow states.
  5. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
  6. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    WOW! - ev powered snow plows, except,what happens when the power goes out during a snow storm?
    Back to hand shoveling?
    DBCassidy
  7. austingreen
    13,663
    4,204
    Austin, TX, USA
    The water use is from US grid electrolysis in 2008 study.
    An Error Occurred Setting Your User Cookie
    If it is produced by SMR the water use is much lower, as it is if we use night wind electrolysis. Those are the two methods that are cheapest. If you are going to power it by bull shit, as in the toyota spot, that probably is very water intensive as well. I don't think water use is a major problem, but .... in thirsty California natural gas based SMR and night wind need to be used or the water budget will be big.
    One way to screw up assumptions is by listening to some of the overly dramatic needs that California sets up. No state in the US needs to be 100% renewable in 2030 or even 2050. Perhaps California could be 10%-30% plug-in + fcv by 2030, but over 30% is a little crazy when you realize that the average car is 11 years old, which means lots of cars in 2030 will have been built before 2020.
    The Government action plan calls for 1.5 million ZEV in 2015. I doubt they will get there, but if they do they likely won't have much over 100 hydrogen stations. That means most fcv will come after 2025 if at all.
    https://www.gov.ca.gov/docs/DRAFT_2015_ZEV_Action_Plan_042415.pdf
    If they get to 1.5 million in 2025, 4 million is probably the best they can do in 2020. There are 20 million autos in Californian, so 4 million would be 20%. I would expect the rest of the country to adopt at a slower rate.
  8. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Hopefully that was humor...but just to be sure, I was just pointing out an EV charging station does not require a post or connection box to be sticking up out of the pavement. The snowplow could scrape the entire parking lot without worry. I certainly don't expect any EV powered snow plows in my lifetime.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    First, I am not anti-EV. I drive a plugin car and I have a 7.8 kW PV system on my roof. I am responding because of the level of misinformation and bias toward hydrogen fuel cell.
    1) Hydrogen is not an energy source.
    Electricity is not an energy source either. You'll have to generate it, transport it and store it -- just like hydrogen.
    2) Electric Vehicles are at least three times more energy efficient than Hydrogen fuel cell vehicles.
    It depends on the source of energy you start with. If you start from natural gas, FCV is more efficient.
    The author isn't aware of Photocalyst panels that converts solar energy to hydrogen. He was quick to draw conclusion based on cherry picked scenario.
    3) You need to build a multi-trillion dollar hydrogen delivery infrastructure.
    Building the grid probably cost more yet, we still have slow charging network. Most homes have 200 amp service. To recharge a 312 miles EV in 5 mins, you'll need 12,000 amp service (about 60 homes). That's the scale FCV is able to achieve with minimal loss (relative) in compressing H2 gas to 10,000 psi.
    4) Hydrogen is Not Clean.
    Neither is electricity. More than 2/3 of it comes from fossil fuel. In the US, 100 MPGe EV emits about the same greenhouse gas as a 50 MPG gas car.
    5) Hydrogen is not ‘Renewable’!
    Sure it is. Excess renewable electricity can be captured in hydrogen, which works better than storing in the battery packs. Photocatalys panels can also generate 100% renewable hydrogen straight from the roof.
    6) Hydrogen Fuel Cell Vehicles can’t compete with Electric Vehicles.
    There is no 312 miles EV that you can purchase for the price of Mirai $58k. There will be more H2 stations than SuperChargers in the state of California by the end of this year.
    Former DOE Secretary Steven Chu also changed his mind about hydrogen before he resigned.
    orenji likes this.
  10. hill
    8,724
    well for one, you were thinking plugins are no good because of apartment dwellers - and therefore hydrogen cars are the best answer for future autos.
    Problem is, majority of apartment dwellers will never be able to afford a hydrogen car. The people that can, for the majority, would never want them. That's why in part, many have to wait for months to get a Tesla .... because it's a better deal - whereas hydrogen cars are virtually unavailable most everywhere, use non-renewable natural gas as fuel for the future, and no one knows for certain whether they'll even be around in the near future. (disclaimer - not an automotive FC advocate)
    in South OC there hasn't had to be any laws to install EVSE's because some of the condo manufacturers are already installing charge stations in their garages as an option;
    The above picture is of us in a new (model home) tract just a few blocks away. The PV inverter? Those are stock - but they don't work for creating your own home brew hydrogen.
    #111 hill, Oct 7, 2015
  11. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    In all fairness, most of the criticism of fuel cells has not been with the technology, but the use of taxpayer money to force a technology deployment prematurely or uneconomically. Points 1, 4, 5 are really not issues with the posters here. I will agree to those.
    Number 6 is obvious. If it could compete, then all the government money being poured into the premature deployment would not be needed. How stupidly the government waste money is not evidence of competitive equality.
    Number 3 is also obvious. The grid was built to power nearly everything, so commenting on the entire grid cost is a red herring to be honest. The cost that matter are what is needed for autos. EV infrastructure cost is orders of magnitude less than the H2 infrastructure cost no matter how contorted the numbers are manipulated. The 5 minute artificiality is overblown. It certainly matters to a fractional percentage of drivers but nowhere near the majority unless the economics are even.
    Which brings us to Number 2. It does depend on the energy source you start with...and all the inefficiencies getting to the final utilization. So far, EVs look to be remain in the lead. If recurring fuel cost and non-recurring vehicle buying costs are vastly better with EVs, then don't expect FCVs to be anywhere close to a majority car technology.
    austingreen likes this.
  12. austingreen
    13,663
    4,204
    Austin, TX, USA
    Here, I think efficiency is a red herring, what should be said is the cost of fuel if it is 10,000 psi hydrogen looks to be much more expensive and carbon intense than electricity for plug in cars, baring technical breakthroughs.
    If we are making the hydrogen out of renewable electricity we need to build two and a half to four times the wind turbines or solar panels to produce hydrogen as we would need to charge batteries in plug-in cars. On top of that instead of needing a charger in the home or office and some odd fast chargers, you need compressors, chillers, and pumps, much more expensive infrastructure.
    Now photocatalyst may make this economocially better, but today those systems are more expensive than regular wind turbines and silicon PV. Its like the promise of CSP, where people talked about efficiency, but today costs look to be at least twice as high. Maybe, in 5 years with a break through. The most promising start up 5 years ago can't make low pressure hydrogen for less than $7/kg.
    Where hydrogen has the most chance economically is not from bs or lemonade but distributed SMR (steam methane reformation) from pipe line natural gas. Here there is rough parity in efficiency.with plug-ins. Yes I know toytoa made a slide in 2008 saying that fuel cells would be more efficient, but fcv aren't as efficient as big auto thought they would be.
  13. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    That slide set the goal for 2020.
    They're right on schedule for 2015.
  14. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    In some sense "efficiency" and "economics" are interchangeable in these discussions if the starting point is electrical generation sources. When the start point is not the same energy types (e.g. Solar Electric vs Natural Gas), then efficiency is quite secondary to economics. In these situations I would not call it a red herring, but it is secondary.
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Why not the same criticism to EVs and PHEV with 16kWh+ battery when they were launched?
  16. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Because I have made the same criticism! But I need to be clear about the criticism specifics. I have no problem with tax incentives and other government measures when they are technology independent and driven by regulatory requirements, such as clean air. I have a huge problem with technology dependent government measures when specific technologies are singled out. This includes favoring specific battery sizes, chemistries, etc. It also includes subsidizing specific infrastructures such as EV recharging stations paid for by the government. Other posters may not agree with my point here, but I have always stressed the consistent failure of government to pick the best technology combination for whatever technology is favored.
    usbseawolf2000 likes this.
  17. austingreen
    13,663
    4,204
    Austin, TX, USA
    How's that. In 2008 they were going to have a fuel cell hylander gettting 68 mpge in 2015 selling for $50,000. Instead they have a fuel cell camry with one seat missing gettting 67 mpge for $57,000. I doubt they thought they would only try to lease 200 in 2015 when they poured all that money in in 2008.
    in the slide they have natural gas to hydrogen getting 67% efficiency then in a fuel cell car getting 23% better milage than a natural gas ccgt to be more efficient than a bev. Last I checked california is only 60% efficient in natural gas to 10,000 psi at the pump, but who knows maybe they can get to 67%. eia says the average, not the best ccgt is 45% efficient, drop it by the grid efficiency we get 41.4% or 48 mpge well to wheels nat gas ccgt for the i3-rex in charge deplete mode. Ad the new ones are 58% efficient. Even the model x P90d 4wd 3.1 seconds to 60 gets 38 mpge. The mirai if we give a future 67% efficiency which they haven't been able to build in california yet , we get 67% x 67 mpge = 45 mpge. That chart says the equivalent bev should get 37 mpge, but is the model x p90d equvalant or the 48 mpge i3-bev? That mirai is much slower than the beemer. It can't charge in your garage. It can't go many places that bmw can go. No it should not be compared to an ultra fast suv bev. Toyota thought fuel cells would be more efficient and plug-ins less efficient. The chart like much of toyota's internet ads are powered by bull shit. The mirai is less efficient on natural gas than the bmw i3 on natural gas. If you use electricity it takes more than two times the solar panels or wind turbines. Give me a break that it is much more efficient. In what world? I think that chart must be based on using japanese testing for fcv and epa for plug-ins. if you think it is a prediction toyota has failed at fuel cell efficiency promises. The last I checked 48 mpge nat gas is more efficient than 45 mpge nat gas, but hey they have only been working on it for 20 years, maybe in anouther 20 they can show how 45 is much much better than 48.
    #118 austingreen, Oct 7, 2015
    finman likes this.
  18. orenji
    5,887
    3,488
    Thats great news that some builders are adding chargers as an option. But what about the other 90% of condos that have been build from the 70's through 2013......there are over 300,000 Community Associations in the US and with about 60 million living in Community Associations. That a whole lot of vehicles. How many of these owners don't have garages and must park outside in designed spaces with no means to a charger? So yes, FCV and Hybrids will be needed and demanded by many who can't or won't buy an EV.
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    That was the same reason why I was critical of some BEV, Volt and other badly designed PHEVs. Not only there were pork specific to the battery from NREL battery patent, loan to build factors, manufacturing, ZEV incentives to manufacturers and federal, state and local tax incentives to buy plugins. On top of that free electricity were provided and they don't clean the air either. PHEV version of the hybrid version emitted more. A compact Volt emit more than a regular Prius. Pre-2012 Leaf emitted more than Prius. Model S was the only one that did better than comparable gas or diesel cars.
    I would have the same criticism with Hydrogen Fuel Cell if it didn't deliver the results (cleaner well-to-wheel emission). It has many of the good things from battery electric and gasoline vehicles. The only negative criticism is the lack of infrastructure and the cost of fuel. Both of those can be addressed simply by scaling to the mass market, which by way is naturally going to happen.
    FCHV-adv prototype came out in 2008 and that was based on the Highlander. 68 MPGe was not an official EPA rating but from a lab test.
    This from a 2010 article:
    TOYOTA SAYS IT has cut the cost of building fuel-cell vehicles by 90 percent and could sell its first hydrogen vehicle for $50,000 by 2015.
    Toyota says it has cut the cost of building such cars by 90 percent in recent years. It hopes to cut that by another 50 percent in coming years, so it can can sell an “affordable” mid-sized hydrogen-fuel-cell vehicle. Such a car would offer the same range as a conventional auto “with some extra cost,” says Yoshihiko Masuda, Toyota’s managing director of advanced vehicles.
    “Our target is, we don’t lose money with introduction of the vehicle,” Masuda told Bloomberg. “Production cost should be covered within the price of the vehicle.”
    When it was stated, there was $8,000 federal tax credit for FCVs. The real news is, they were able to cut the cost of FCHV-adv from $1 million to $58,000 and sell it without loosing money. At the time of the announcement, you guys did not believe it could be done. You guys probably still believe that Toyota is selling Mirai at a loss which lead to negative perception of fuel cell vehicle viability.
    Toyota scaled down the FC components to fit in a midsize sedan (perhaps to share parts with Camry hybrid to lower cost) but lost a seat in the rear. I think Honda did a better job with their upcoming FCV but price is still unknown. Hyundai and Mercedes stuck with SUV.
