Washer is not spraying front windshield wiper liquid
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Autoconfig, Aug 7, 2014.
  1. Autoconfig
    Autoconfig Junior Member
    Bay Area
    when i tried to spray fluid into front windshield fluid is coming out very very very little on left and right side wipers, do i need to add any liquid(if yes please name it ) or any problem with that..?
    #1 Autoconfig, Aug 7, 2014
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Yes, I would start by checking your windshield wiper fluid reservoir. If its low you will need to refill it. Any wiper fluid that you can buy at a grocery store, big box store or auto parts shop will work. If after you check your reservoir and find it has fluid then you need to trace down the black hoses/tubes for leaks. If the tubing is sound the last place that will constrict fluid flow will be the nozzles themselves. Often time inserting a sewing type of needle or the like, into the nozzle and wallering it around can break up and solids residue that may have dried in there. From your symptoms it's apparent that your wash fluid motor is working you either have low/no fluid or an obstruction(s) in the system.
    Autoconfig likes this.
  3. Autoconfig
    Bay Area
    Thanks, any idea which is good company, i am very new to autoworld.
    48,995
    nah, they are all the same. you can pick it up at any department store, hardware, home depot, auto parts, etc.
  5. Autoconfig
    Bay Area
    thank you, i was able to get from autoparts and fill the reservoir,how ever when i spray fluid it spaying very high., do i need made any chagnes.
  6. bisco
    48,995
    the nozzles should be adjustable. check your owners manual, or perhaps someone hear will know. take a look at them, it might be obvious. are they shooting over the roof?
  7. koolingit
    koolingit Member
    158
    50
    Mocksville NC, USA
    The nozzles are like a ball in socket. You can aim them by sticking a pin in the hole in the nozzle and move the ball in what ever direction you want. Try the spray again and fine tune the adjustment.
  8. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    There is a Toyota Specialty Tool to adjust the nozzle; probably an arm and leg if you were to buy it.
    Some have had success using a safety pin/sewing needle/paper clip (find one with the best diameter to work with).
    Amazon also lists a tool ($19) that will probably do the trick, and should be easier to manipulate the jets because of the handle. LINK
  9. Autoconfig
    Bay Area
    Yes, fluid is going till rear windshield.
  10. Autoconfig
    Bay Area
    Thank you very much, i will check it and update you.
