Water slush sound under dash on initial ICE startup
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TCW1184, Apr 20, 2015.
  1. TCW1184
    TCW1184 Junior Member
    Has anyone else ever noticed a water sloshing sound coming from under the dash on initial start up when the ice engine comes on? I found a few things from searching, but nothing really conclusive. I didn't think much of it at first. Like maybe water was just coming up into the heater core or something. It doesn't do it all the time, but often enough that I'm starting to wonder if I should get it checked out. Anyone else ever noticed this?
    t ro
  2. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    If it's a gurgling sound, check your coolant levels. You may be low or have air in the system. There are a number of posts here regarding that symptom. Don't delay, because running your Prius with low coolant could significantly damage expensive systems.
  3. TCW1184
    More of like water running then gurgling.
    All my fluid levels look good.
    #3 TCW1184, Apr 20, 2015
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I experienced this once when I was a little bit low on ICE coolant. Due to a small water pump leak. Added some more coolant and after a couple drives it was gone. That's just my experience
  5. Yakoma
    470
    122
    ATL-ish
    Seems to me you have two possibilities here.
    1) You have a leak or somehow rainwater has collected in your car - either in or under your front tray somehow. Perhaps you have a clog. Or the water is elsewhere in the car - it just SOUNDS like its in the dash. There have been numerous instances of water collecting in the spare tire area due to seam weld cracking and leaking. Search this and you will see them.
    2) You have a low coolant issue in or need to purge air from one of the two coolant reservoirs. This seems the more likely scenario to me. Even if the levels look good, you could have trapped air bubbles in one of the cooling systems. You can search for this scenario as well.
    Reading through those two scenarios for similar symptoms should lead to some insight for your particular case. I know it's not a definitive answer, but I hope it helps.
    Like Aaron, I had a low coolant situation in my Prius that caused gurgling. I determined that I had a faulty radiator cap that was allowing seepage. I replaced the cap and topped off the coolant and have not had that issue since.
  6. Mendel Leisk
    38,253
    Might also be the air conditioner fluid flowing. Are you running AC when you hear this?
  7. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    I am thinking you have heat on and it is low coolant level...you can have air trapped in there, I think the fix is to add coolant but you gotta get the air pocket out of there and I don;t know how on a Gen3 but Gen2. Where do you live...cool climate I am thinking.
  8. TCW1184
    Thanks everyone for the replies.. Seems like the general question of 'is it normal', the gist is no. The car is a 13' with 20k miles so I'll make an appointment with the dealer to have them check it. Which, of course, means they won't hear it and tell me it's normal. That being said, I'm in FL so it's not cold and the air isn't on when I hear the sound. It's right on initial startup and I only hear for a second or two ( like water quickly running down a pipe) and then I don't hear it after that. The levels are max so they're not low, but I suppose air in the system is possible.
    iPhone ?
  9. Mendel Leisk
    38,253
    Just being a grumpy old man: you do know the sun doesn't rise and set only in the United States of America. Priuschat has members from all corners of the globe. A two letter acronym is a bit esoteric for a lot of them.... Done. :p
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    The very fact a member doesn't put their location usually indicates they're from the US ;)
    Oh and ML, you don't have the monopoly on here for being grumpy (y)
  11. TCW1184
    Are you sure? I'll keep that mind.
    iPhone ?
  12. bisco
    48,995
    maybe you hear the inverter pump.
  13. Mendel Leisk
    38,253
    Like London I guess. What do you guys call it: the City? ;)
  14. TCW1184
    Just realized I never gave an update to this. Just in case anyone looked back I wanted to give the resolution. It took an while but the dealer finally heard the sound I was describing and fixed the issue. They said the thermostat was sticking opening and I likely had some air in the system (that part I already knew). They replaced the thermo and purged the coolant. Been good so far.
    iPhone ?
    Former Member 68813 likes this.
  15. Former Member 68813
    3,524
    981
    US
    interesting, i have the same symptom in a non-hybrid car.
  16. bisco
    48,995
    software should require, city, state, country.
    GrumpyCabbie likes this.
