  1. sfprankster
    sfprankster Active Member
    443
    490
    Santa Cruz Mountains, CA
    Partially correct on 2/5 :rolleyes:
    :eek:
    Does that include a lifetime supply of lube? :censored:
    Sean Callahan likes this.
  2. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    American Tire charge $150. Then I went to another shop in Long Beach which charge $100 to move TPMS from 15" to 17" and balance. Give me new stems
  3. sfprankster
    443
    490
    Contents of mystery package #1, an inverter cover installed...
    ...and no, I didn't forget to re-attach the ground wires... ;)
    ...6am be damned... o_O
    ...at least that is the thought process for now... :p
    ...tomorrow morning it may be different thought process entirely... :unsure:
    Footwell LED Update:
    Actually bright enough to see the dirty mat and carpet without any other light source... :oops:
    sfv41901 likes this.
  4. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    Blocked the lower portion of my grill. Haven't done any driving yet so not sure what the MPG gains will look like. I typically don't turn on my heat when driving, which has gained me around 3 MPG. Where's the warm weather so I can get my upper 50 MPG back!
    Need to give it a bath to!
  5. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
  6. TopRamen
    307
    578
    Fremont, Ca.
    Special thanks to @B2FiNiTY for installing my steering wheel, great to meet you. When you're in Fremont, let's hook up.
    Steering wheel feels and looks 100% better, so happy with this upgrade.
    sfv41901, cheizy, Ramtart and 4 others like this.
  7. Xterra72
    Xterra72 Senior Member
    1,364
    1,635
    How was the install? Difficult? Do you have to get a steering wheel Alignment?
  8. TopRamen
    307
    578
    Fremont, Ca.
    Install looked easy when B2FiNiTy installed it, steering wheel is cocked a little to the left but not so bad. Probably will have to do alignment again.
  9. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Would it be an alignment or adjusting the tie rod ends?
  10. xliderider
    xliderider Senior Member
    7,854
    3,103
    Honolulu, HI
  11. TopRamen
    307
    578
    Fremont, Ca.
    Thank you @xliderider, saves me from doing another alignment, I've Gone through 2 already. One for lowering & two for installing camber bolts & camber shims.
  12. Sean Callahan
    Sean Callahan Senior Member
    314
    582
    Honolulu
    fatdawg, Ramtart, TopRamen and 3 others like this.
  13. Accordlayingkit
    1,616
    1,747
    377
    We get to @eight08customs ride with his new wheels before he even posts himself! lol
  14. apt5020
    881
    1,294
    Prius City, CA
    CT200H Rims.JPG Got my CT200H rims installed. Very happy. Ran 25mm spacer in the rear and none in the front. It's nice and flush. Prius Plugin 2014 rims + tires + lugs on sale in Private Sales. No center cap. I moved it over to the CT200H
    sfv41901, Ramtart, Johnsk93 and 4 others like this.
  15. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
    Out with the old...in with the new:) lil sneak peak before i take better pics tomorrow. 3hrs installation 20150131_195520.jpg 20150131_191432.jpg 2015-01-31 20.22.49.jpg
    sfv41901, TopRamen, Starbrand and 4 others like this.
  16. sfprankster
    443
    490
    No need to cut the ground wire bracket.
    Once I removed the stock mini cover, it went right on without a problem. Otherwise I would have had to cut the edge of the stock cover in front of the ground tab. There's a small edge on the right side that gets in the way. It's a single strip of double sided tape that holds it on.
    #5956 sfprankster, Feb 1, 2015
    RightOnTime and TopRamen like this.
  17. TopRamen
    307
    578
    Fremont, Ca.
    I see, I tried putting mine on with the stock mini cover on & didn't want to go on. Thank you for the advice, I'll do that tonight. Cheers!
  18. sfprankster
    443
    490
    ...and don't worry about any of the warnings on the cover about electrocution... :whistle:
    650+ volts is harmless in small doses... :LOL:
  19. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    @sfprankster that is some kind of mod list for a signature you got there... :eek:
  20. B2FiNiTY
    979
    226
    @TopRamen it was a pleasure, enjoy! :cool: I ended up going down to fremont in the afternoon after all and spent 4 hours detailing my buddy's car. Going to get some good night sleep tonight.
    TopRamen likes this.
