What did you do to your Prius v wagon today?
Discussion in 'Prius v Accessories and Modifications' started by Mike500, Mar 31, 2015.
  1. Ben2jz
    Ben2jz Junior Member
    44
    Ca
    2015 Prius v wagon
    Bought these from eBay for $3.50 shipped. Ran some wires from the left to the right. I had to drill a small hole to run the wires behind the panels. All in all, more light then I needed.
    AandMev and JAvendan like this.
  2. cucaio90
    cucaio90 Junior Member
    48
    debary ,fl.
    2015 Prius v wagon
    Got me a LED stick up light instead,no hole drilling, when is time to change the batteries you just pull on those white lips IMG_0041.jpg and the light comes off and you're able to put it back on.This is the lazy way method of doing it.
    RAM v likes this.
  3. JAvendan
    JAvendan Junior Member
    27
    Northern San Diego County
    2015 Prius v wagon
    Installed the front mud flaps. Could not find my floor jack to install the rears.
    AND, bought this little guy... older Yakima Rocketbox Box.
    The Prius v3 easily handled it :)
    Joel
    SM-N920V ?
    Bmr4life likes this.
  4. Ben2jz
    44
    Ca
    2015 Prius v wagon
    Nice! Please update on what kind of rails you decide to go with and lots of pics be great too.
  5. cucaio90
    48
    debary ,fl.
    2015 Prius v wagon
    Got me another stick up LED light just under the dash.I got tired going 65 at night on the highway trying to hook up my IPod cable while driving and unable to see the audio output hole,this makes it a lot easier to find it or trying to find anything else for that matter. IMG_0046.jpg
    #45 cucaio90, Oct 10, 2015
    ricomtl likes this.
  6. Ben2jz
    44
    Ca
    2015 Prius v wagon
    Mounted some LS460 projector for fog light on my 2015 v 4. Everything is in place just need time to do final alignment and filling in the gaps.
    Also since the bumper was off I did the squirrel finder mod as well. If anyone was wondering the 2015 shield is very big compared to most projectors.
    EDIT: projector aim and running. This a close up about 20 feet. Just random pics I needed to take.
    This is with headlights on, no more squirrel finder. Cutoff is still horrible but I am going to live with it since I don't have time to play with them.
    #46 Ben2jz, Oct 12, 2015
  7. tangcahyadi79
    tangcahyadi79 Junior Member
    17
    2015 Prius v wagon
    hey bro , may i know where you buy that fog light
  8. xliderider
    xliderider Senior Member
    7,852
    3,103
    Honolulu, HI
    Aren't the LS460 projectors open to the elements? How do you keep water and grime out of the projectors?
    Got these from PriusChat member Cheizy: For Sale - 2010-2015 Prius HID Projector Fog Lights (BOLT ON FINALLY!) $120 | PriusChat
    I also did the squirrel finders on my Camry. The flaps were really large, and had flaps on the sides too. Did you just bend them up and JB Weld a piece of aluminum over the cutouts?
    #48 xliderider, Oct 13, 2015
  9. Ben2jz
    44
    Ca
    2015 Prius v wagon
    They are actual projector that are taken off a Lexus LS460 headlight. I am using them as fog light because I have two set laying around and I didn't want to spend money on new stuff.
    I saw Cheizy fog and was really considering them over the blazer but I had these laying around and thought I put it to use. Plus this this is our family car too. So it's a long term investment.
    I have a big rubber cap from a pair of BMW projector somewhere that I will use to keep as much junk out as possible. I will also built a plastic housing around it to keep both ballast and projector protected. Maybe two week from now I will have time to work on it more. And whenever I do an oil change I will go in and clean it if I have too. Plus the 3 inch lens are dirt cheap and free sometime if I ever need to replace it. No clear lens it be a waste.
    For the projector flap, just like you said. Bend it and jb weld soda can over it. The result i am a bit disappointed because it effected my cut off. A little soft and fuzzy. I plan to go back and add more jb weld to completely cover the area and make final adjustments then.
    #49 Ben2jz, Oct 14, 2015
  10. xliderider
    7,852
    3,103
    Honolulu, HI
    I think the cutoff shield gets bent slightly from bending the metal shield up then down to access the squirrel finder cutouts. That's the main reason why the cutoff isn't as sharp I believe.
    I've been contemplating going back in and adding more JB Weld and trying to pull on the shield slightly to see if I can get it straightened out to where it was to get the nice, sharp cutoff again.
  11. Ben2jz
    44
    Ca
    2015 Prius v wagon
    I say go back and do it. Taking off the bumper is ridiculous easy on the Prius. Especially the 2015 there is less bolts and clip to take off. Maybe dozen total.
    Anyways I will do it to mine in a few week. The fuzz is driving me nuts. I think pulling the shield back will fix the problem. Also keep in mind the bulb seating is important too.
  12. Mike Moon
    Mike Moon Member
    31
    48
    Marietta, GA
    Four Touring
    IMG_7281 2.JPG I replaced my antenna with a 30-caliber bullet. It's subtle but cool. I don't know if anyone will even notice...
    #52 Mike Moon, Oct 16, 2015
    D_n_D, TC400 and kenichols29 like this.
  13. tangcahyadi79
    17
    2015 Prius v wagon
    i want to install led bar light in my prius v front bumper . any advise from you guys
  14. ultravorx
    ultravorx Junior Member
    50
    Pa
    Three Touring
    Finished my custom installed Sti-r radar detector and AL-P "parking sensors" 20151015_205651.jpg 20151013_221839.jpg
  15. tangcahyadi79
    17
    2015 Prius v wagon
    d
    do you think the grill on the front bumper could be take it out , cause i would like install LED bar light . Thank you
  16. Mike Moon
    Mike Moon Member
    31
    48
    Marietta, GA
    Four Touring
    My tribute to Made in Japan... Swapped out my v (lowercase v for the Prius v wagon. Only 2010 Prius used uppercase Roman numerals for model designation) logo with an alpha one from Ebay. alpha.jpg
    HeliosMagnus, PvPDX, icyrius and 3 others like this.
  17. Ben2jz
    44
    Ca
    2015 Prius v wagon
    Yes
  18. Sinoman83
    Sinoman83 Junior Member
    16
    San francisco CA
    20150910_191500.jpg View attachment 101071
    Installed some revier led turn signal. Not to happy with brightness of the drl function thoe.
  19. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    I took my wife's v3 in for its initial 5k service...
    She kept telling me something is wrong with the car, something about "check engine light or service something light on the dash". I said I do believe it is simply telling you that service is due soon... And that's what it was :)
    TC400 likes this.
  20. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Took my wife's v3 in to the body shop for an estimate for a repair today. She unfortunatly had a fender bender the other day. Fortunatly no one was injured and nothing that can't be repaired..
    Michael Leary likes this.
