What I don't like about the Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by cproaudio, Mar 23, 2016.
  1. Trollbait
    11,368
    To say another way, they don't care for them.;)
    Has there been any issues with Li-ion traction batteries to date? There the Leaf's in hot climates, but PHEVs have more of a buffer in SOC for protection. I admit I had concerns with the Ford Energi's on introduction. They seemed to have the widest range of SOC in a PHEV at the time. Has there been any issues with them?
    I know Toyota has claimed that Li-ion isn't ready, and there are scenarios for hybrids in which NiMH could be a better choice, but they are also heavily invested in NiMH production down to the nickle mines.
    49,072
    with li-on in all but one level of usa gen 4, it would be hard to hunk they still believe that.
  3. wjtracy
    wjtracy Senior Member
    11,315
    3,588
    Northern VA (NoVA)
    Not to my knowledge except as you mentioned.
  4. Tideland Prius
    16,081
    Looking at the C-Max Energi, that means Ford has allowed a wider range of SOC on the 7.6 kWh battery. Typical of Toyota, it's conservative with the use of charge on the 8.8 kWh battery to (I assume) maintain battery longevity. If Toyota had announced that the Prime maintains the PiP's 50mpg combined rating but has 5 seats, I'm sure most people on PriusChat wouldn't mind. Yes it's not ideal in Toyota's mind and their goal to provide the ultimate in efficiency but the result is a suitable family vehicle. Now, it's a vehicle for empty nesters, couples or young professionals.
    There might be other external factors at play. Toyota was the first to announce their next gen PHEV. Hyundai was later that afternoon and Tesla was at the end of the month. When I was at the event (and I'm sure you guys saw that video too), a lot of the numbers were estimates. 600+ mile range and 120+ mpge. He did say 22 miles without a qualifier. I suspect Toyota can match the Ioniq's number if it wanted to.
    KrPtNk likes this.
  5. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    This is certainly a fair point. I guess I'd say two things in response.
    The first is that I'm being selfish. Having a 4-passenger BEV for all my commuting and most of my shopping and weekend errand-running, I have a particular set of requirements for the 2nd car in the garage, plug-in or not. It needs to be the road trip car, because that i-MiEV ain't leavin' town. I'd also strongly prefer it to provide the 5-passenger capability that the BEV lacks. The changes from the PiP to the Prime move Toyota's PHEV in the wrong direction on every count, so my initial unease about pulling the trigger on the LB before seeing the Plug-in have been greatly allayed - the Prime is all wrong for me, not even worth a look. A little more AER is nice, sure - but it's not nearly as good as the reduced seating and trunk space is bad.
    Second, even putting aside my very specific use case, it just feels to me like the Prime's specific compromises miss anything resembling a sweet spot. If it does avoid the "teeny AER" criticisms you mention, it's not by a lot. Matching Ford's Energi models doesn't exactly put them in the thick of things when the Volt's rockin' 50 mi. of AER. Sure, the Volt might be way out beyond where Toyota wants to go right now, but given that Toyota's made that judgment, my argument is that it's foolish to give up the only practical advantages the PiP had. This is especially irksome because the Prime fixed what was for me the PiP's biggest shortcoming as a PHEV (aside from not being sold in my state) - effectively zero AER, because its milquetoast MG was no more capable of driving the car through traffic than the non-plugin's identical setup (i.e., hit an upward slope, pass somebody crawling along below the speed limit, hit the go pedal with a tad too much gusto, and up spins the ICE). The Prime really will burn no gas if your itinerary is within its AER, and that's a pretty big win. But that win loses a lot of its luster if it comes at the price of so little trunk space that the non-plugin side of its mission is compromised. The Prime just didn't gain enough in AER over the PiP to make up for what it sacrifices in real-world utility.
    So to your point, I think what makes this compromise worse and harder to explain than, e.g., 16 mi. AER with a full trunk and back seat, is that Toyota's making customers give up as much as Volt buyers do, but not delivering commensurate AER goods. I would agree that in and of itself more AER is a good thing, but Toyota's chosen not to be competitive on that metric. Given that, while the shorter AER would be weak from a marketing perspective, at least there would be specific advantages on the other side of the ledger that could help close the deal for some shoppers. Now there aren't.
    #245 Vike, Apr 28, 2016
    skayaks, Tideland Prius and Trollbait like this.
  6. Tideland Prius
    16,081
    Well said. I hope Toyota can remedy that sooner (midlife update) rather than wait the entire generation. (That is, unless Toyota has some near breakthrough technology that they'd rather launch with the next gen Prius or Prime in the 2020s)
    Vike and bisco like this.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Your post certainly reflects my feelings. I don't buy a car to fit the manufacture's priorities, I buy it to match my priorities. Over the years I've bought a 2001, 2007, and 2010 Prius (all still in full use). They were the best match for the priorities of all the drivers involved.
    But priorities evolve. The advantage of EVs is only going to get better and ICE vehicles have reached the point of decreasing sustainability. The immediate payoff of EVs (for me) is home charging. The eventual payoff is solar energy sourcing if and when the situation arrives. This is huge.
    With both the PiP and the Prime, I'm not really sure what Toyota's priorities are, but they sure have gone in an opposite direction. This is extremely sad. While the purpose of a corporation is to "make money", it also the reason companies avoid critical technology shifts. (I have a brother who worked in the film processing business...till he left for obvious reasons.)
    Felt and Vike like this.
  8. bisco
    49,072
    i think most of us were expecting greater aer, to some extent or other, without any other compromises. now whatever the focus groups told them, i have no idea, but they didn't have any 'skin in the game', as a famous priuschatter once said.
  9. gvp1995
    gvp1995 Active Member
    199
    141
    Three Touring
    I feel the same way. I think it has more to do with the amount of risk one is willing to take going for a long trip rather than old vs. new school.
  10. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    I'll add my worthless anecdote that I choose the PiP because it sacrifices very little compared to the regular Prius. If the PiP did not have the same utility as the standard Prius, I wouldn't have been interested. At that point, I might as well bought a different vehicle such as a Ford Energi, or VW TDI.
    The floor in the PiP is flat with the folded down seats, allowing me to sleep in the back. I'd probably remove the spare tire in the standard Prius since I've never had a flat tire due to sidewall damage, and all other damage can be repaired with a $2 plug kit.
  11. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    That's far from worthless - I think it's the central point. The PiP, much-mocked as it was in some EV-enthusiast quarters, was pretty much "All the EV range we can fit into the vehicle without compromise." It wasn't a lot, but you gave up nothing (except a spare tire and some $$$) to get it. Compared to that, the Prime's giving us a bit more (and better) AER, but at the expense of doing exactly what the PiP didn't - compromising core functionality.
  12. bisco
    49,072
    and i thought the chassis redesign would allow for the increased aer, without any compromises.
    plus, i figured after 5 years, toyota could sell 8 kWh for little more than 4 kWh. or maybe 7 kWh would double the range due to increased efficiency.
    mrlebop likes this.
  13. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    You weren't alone. A lot of us were expecting a much better product than the "let's hang some batteries on the side" quick-and-dirty PiP. As it stands, I now have more respect for the PiP, despite its lack of curvy rear window glass and a luxurious center console in back. ;)
    mrlebop likes this.
  14. Redpoint5
    1,026
    508
    Portland, OR
    People have unrealistic expectations about technology. There are certain limits to energy density (among other performance characteristics) that nature has imposed in her rules of chemical reactions. Like all things, battery technology has a diminishing return on investment, meaning that simply throwing more research money at the problem is less and less likely to reveal significant improvement.
    The Prime had to double the capacity to double the range because it allows a higher performance EV mode. Despite efficiency improvements, allowing the vehicle to accelerate more quickly and travel at higher speeds on the highway will require more energy.
    Future cost reductions in battery technology will have more to do with economies of scale than groundbreaking discoveries in chemical reactions.
    I agree that Toyota should have figured out how to design the chassis to accommodate the battery without sacrificing utility as much as it did.
    #254 Redpoint5, May 27, 2016
  15. bisco
    49,072
    so you're saying, for us slowpokes, my current 16 miles should become 40+?
    mrlebop likes this.
  16. Redpoint5
    1,026
    508
    Portland, OR
    I wouldn't be surprised to see some getting 40+. My guess is that I'd get somewhere around 35 miles if I drove the same as I do now, but I might be more tempted to use those electrons when I have more power and range available.
    mrlebop and bisco like this.
  17. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    That's called not understanding purpose... which is interesting, since the problem is usually not understanding audience.
    Anywho, availability of short-term middle seating was never on the priority list. That higher & harder cushion wasn't sighted as necessary. It was a "nice to have" though.
    Prius focused on need. The fact that it also delivered a few wants is what pushed it into the mainstream and kept it there... profitably, without any special incentives.
    Core functionality was:
    - Reliability
    - Affordability
    - Clean Emissions
    - Great Efficiency
    Later came the ability to transport cargo much larger inside than you could using a vehicle with a trunk.
    All that still holds true.
    #257 john1701a, May 28, 2016
  18. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    I do not know if this helps anyone but you can get one of these
  19. Trollbait
    11,368
    Considering how far the Volt has come in terms of battery size, packaging, and cost, what we were shown at the unveiling of the Prime was disappointing. For a battery pack of less than half of the capacity of the gen2 Volt's, the Prime appears to have the same level of compromises.
    mrlebop likes this.
  20. bisco
    49,072
    it's obvious prime is intended to attack a new audience, one that is unfamiliar with pip hatch space and rear seat. it's just disappointing to long time prius/pip buyers who have supported toyota's effort. ah well, you always hurt the one you love.
    mrlebop and Mendel Leisk like this.
