What is the easiest way to get a base charge in a discharged pack
Discussion in 'Generation 1 Prius Discussion' started by orange4boy, Sep 23, 2013.
  1. orange4boy
    orange4boy Member
    231
    43
    Vancouver BC
    2003 Prius
    Hi
    I have a friend with a Gen 1 that won't start after sitting. ECU considers the pack disconnected. 12v brand new. What is the easiest way to get it going without removing the pack?
    We were joking about a "Prius jump" using my pack but that just sounds dangerous. High voltage and high amps. Could this be done with a simple current limiter?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The dealer needs to order a special charger as even they do not keep one on hand. I have seen someone document on Prius Chat a method that entails disassembling the battery pack and charging modules one by one. Good Luck and don't fry yourself.;)
  3. bwilson4web
    15,407
    How was this diagnosed?
    Does the battery controller respond with anything?
    We have seen various cases of interlock failures. Also ECU/immobilized issues. But the first thing I would want to understand is if the battery ECU is responding.
    Welcome back!
