What is the logic between 12v battery and lower MPG?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by morglum, Feb 1, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Alas even that isn't fool-proof.......because sometimes the fool running the test stops it after only a few seconds and pronounces it "good".
    The test load needs to be left on for at least 10 to 15 seconds as specified in the book for the tester.......which likely is long gone.
    It will always identify a battery that is REALLY sick; marginal ones, not so often.
    morglum, edthefox5 and Britprius like this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Yep...I got one an old school toaster. Leave it on just till the resistor starts a stinkin'. 10-15 seconds and watch if the needle nose dives. Tells me all I need to know about the patient. You can buy them real cheap on Ebay like $15. I paid $5 for mine. It does not lie.
    Works really good as surface charge remover.
    This one:
    #22 edthefox5, Feb 1, 2015
    morglum likes this.
  3. morglum
    morglum Junior Member
    45
    gatineau,qc
    hey,
    I charged last week and the battery is now at 12.5V, but falls to 11.5V when I put a load on it. I'll bring it to Canadian tire as it should still be warrantied. cheers
  4. morglum
    45
    gatineau,qc
    Hi!
    Here is the printout. Some numbers are *exactly* at the limit, should I complain about it? (front right camber)
    32 MPG average on the last 10 000km | PriusChat
  5. jdenenberg
    jdenenberg EE Professor
    3,838
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You will need to shim the rears to fix the toe and the fronts should have a slight toe in to avoid "wandering" at highway speeds. Camber should not directly affect MPG.
    JeffD
  6. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Don’t you mean toe out? But I don’t think it should wander with toe at zero.
  7. Patrick Wong
    18,200
    6,464
    No, toe out would result in unstable handling.
    Imagine trying to ski with the tips pointed out.
  8. morglum
    45
    gatineau,qc
    Do you think it's worth paying for a new alignment ? I didnt feel any wandering.
    Or is this some obvious error so bad that I should get a new one for free?
  9. Patrick Wong
    18,200
    6,464
    If the alignment is within spec then there is no obvious error. However if the last alignment was recently done, you could go back and ask for the front toe to be set exactly to zero. Maybe the garage would take care of that without charge to you.
