What type of Gas should Prius stay AWAY
Discussion in 'Gen 3 Prius Fuel Economy' started by Hy-Bird, Dec 10, 2009.
  1. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    use 87 while cruising around town, 89 on long distance highway driving.
  2. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    So 89 is only useful in power mode with "spirited" driving?
  3. richard schumacher
    7,663
    1,038
    United States
    Save your money: it never needs 89 octane. If the engine ever pings it needs a repair, not different gas.
  4. oldasdust
    oldasdust Member
    356
    47
    illinois
    I would love to see what kind of mpg my Prius could reach if real 87 octane was available instead of E-10 and the special additives requiored in the Chicago area and the crap winter blend. I found real gasoline in Alabama on a trip to florida used 2 tanks to and 2 back going through the state got 6 mpg better on that gas. First tank of E-10 and everyone after back down minus 6. I have been told less energy in a gallon of E-10 vs real gasoline and even less energy in a gallon of E-85. Everyone i have met with a flex fuel vehicle says E-85 drops their mpg compared to E-10.
  5. oldasdust
    oldasdust Member
    356
    47
    illinois
    I'm not totally sold on the idea of E-85 having less energy than E-10 or real gasoline. I met an owner of a shop that specializes in changing over vehicles to E-85 only. I'm not sure what parts are changed and what tuning tweeks he then uses but he said i would be suprised the power and mileage gains they can get. I saw how many vehicles were waiting for the change over lots of mustangs some were getting the full treatment turbo, E-85 change over and then tune tweeks. I'll stay with my tweeks called Toyota Prius.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    http://www.afdc.energy.gov/afdc/pdfs/afv_info.pdf
    Alternative Fuels to Gasoline - Cost of Alternative Fuels - Popular Mechanics
    www.fuelgaugereport.com
    The ethanol myth
    http://www.motorweek.org/features/goss_garage/e85_compatibility
    But, http://www.theautochannel.com/news/2009/05/25/462650.html claims the above is an exaggeration.
  7. oldasdust
    oldasdust Member
    356
    47
    illinois
    cwerdna nice video but the shop does not do a flex fuel conversion it is E-85 only . The parts that are needed to be changed they do then some type of tune. They have lots of happy customers who are gearheads and probably charge a couple thousand. They have been refining this for a few years. From what they said flex cars are a joke because they have to do both fuels their conversion takes full advantage of E-85 they are more of a race shop for muscle type cars. This is not my area of knowledge at all but they have a following so they must be doing something right. They also say small engine, turbo and set up to run only E-85 is what car manufactures should be doing but it's all Greek to me.
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    High performance cars often run alcohol or methanol to increase octane and decrease the chance of detonation. I ran methanol injection in my truck. I can understand why high performance turbocharged or supercharged cars would be interested in E 85 but that doesn't means it's the way to go for everyone. Ethanol is expensive to produce and doesn't offer any real reduction in fossil fuel use.
  9. mariposer
    mariposer Junior Member
    33
    17
    Hot Springs Village, AR
    Three Touring
    We are moving to south Utah, elevation 2800-5000 feet. Regular gas is 85 octane and has 10% eethanol. Is that OK for my
    2009 Prius with 85000 miles
  10. Mendel Leisk
    38,260
    Yes. The lowest octane in your Area is always fine. 85 is likely tailored to your higher altitude. It's a rare vehicle that needs anything higher, but you wouldn't think that's the case, looking at the plethora of higher octane pumps.
  11. bwilson4web
    15,410
    Our Prius has a knock sensor that I've tested and works just fine. You should have no problem. Still, ask a local Toyota dealer for the last word.
    dorunron likes this.
  12. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    Reg 87 is all you need, I get mine at Costco or Sams it works just fine
  13. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    ^^^keep in mind MPG, high up in the mountains they can go with Reg 85 octane as equivalent to Reg 87 octane at sea level
  14. qdllc
    qdllc Senior Member
    1,358
    396
    Other than that high-ethanol gas you are NOT supposed to use, you can use any regular gas out there. Even the 10% ethanol gas (most common) is perfectly safe on the Prius.
    Also, regarding "high octane" gas, a Prius would really never benefit from it. The Prius power plant does not use the ICE to produce motion in quite the same way as a standard automobile does. Even then, octane's benefit is frequently questioned.
    You WILL get more benefit running a fuel system cleaner on a somewhat regular basis (every 3 months) to ensure you keep the system running at 100%. Every vehicle my family has owned that used a FI system has done this. Go a year without doing it, and you will notice an improvement when you start doing it again. The additives gas companies put in are a much lower concentration, and requires you always use THEIR gas to get the long-term benefit. OTC additives are much more powerful and do the job in one application.
