Wheel bearing needs replacing - how to avoid?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikepaul, Sep 30, 2007.
  1. richard schumacher
    7,663
    1,040
    United States
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Are you hearing from the front or rear? The rear bearings are original right?
  3. northwichita
    481
    102
    29
    Wichita KS
    Postulating a hypothesis is easy but the hard part is to follow-up with facts and data. What we need need is a volunteer who will take the failed bearings, disassemble them and look for wear patterns that might reveal their individual failure mechanism(s) and with a collection, common patterns.
    Personal practices could be a factor. More than just water,
    my personal hypothesis is car wash soap may be a factor, I have no data, just reasoning soap is made to dissolve grease.
    I have watched others, usually teen males spend there time washing their cars clean enough to eat off them .
    I try to avoid (within reason of course) spraying the inner wheel hub area with soapy water and have only replaced one wheel bearing in 20+ years of driving which has has been many, including dusty roads , with high mileage vehicles.
  4. gggGary
    gggGary gggGary
    79
    27
    Baraboo WI
    2023 Prius Prime
    XSE Premium
    Maybe soneone else can answer but the G2 Prius uses angular ball bearings in the front hub (reduce friction) and switched the carrier to aluminum (save weight). If I designed it, it would have tapered rollers. Do other FWD cars use tapered rollers? The older rear wheel drive cars always used them in front. I wouldn't be surprised if G3 went back to tapered rollers. If Toyota's field reporting and repair parts frequency analysis system works they did.
  5. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    I see an opportunity for a great mod here - replacement ceramic bearings. They're all the rage in high end road racing bicycles because of their reduced friction but they also have a much higher level of durability. They're expensive of course, but I'm actually a little surprised Toyota didn't use them stock. Given the volumes I doubt it would have made much difference in the price of a car.
    - D
  6. EdwardF
    EdwardF New Member
    New York
    2008 Prius 105,000 miles. Was noticing noise driving especially on highway. Seemed also to be a friction sound about once per wheel rotation. Also noticed poor mileage under 30 MPG. Had both front wheel bearings replaced for $700. Mileage now over 50 MPG, much quieter ride. Mechanic said he had to replace rear wheel bearings on his 2010 Prius. Seems to be a common issue. Loving the improved mileage and lighter touch needed on the accelerator!
    SFO likes this.
