When did you have to replace the Hybrid Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by auart, Jul 28, 2014.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I really think that's the key if you buy a higher mileage, older Prius.
    Knowing that the Hybrid Battery does have a finite life span, and IF you buy the vehicle, being ready and capable of affording the replacement IF it should happen.
  2. Mylar
    Mylar Member
    160
    31
    Cincinnati, OH
    2019 Prius
    I replaced the HV Traction Battery in my 2006 Prius on 11/22/2011 @ 92,600 miles. There was nothing wrong with the battery, but I had an opportunity to swap it out with one from a newer 2008 Prius for $625. I did see a slight 1 - 2 mpg improvement with the replacement battery. My 2006 Prius now has 145,000 miles on it. I avg 43.1 mpg per the MFD display.
  3. writes123
    writes123 Junior Member
    92
    23
    Riverside, CA
    I recently bought an 05 with 100k on it. It had just had the HV battery replaced at 99k due to failure. The previous owner drove it all the time but had a hill/small mountain to climb and descend everyday. I think that may contribute to earlier, as in 100k, 9 year, lifespan vs. other cars that don't have a higher taxing drive such as those on long straight highway commutes. The previous owner drove the car just like a regular car without any real regard to maximizing the mpg or other prius features, so even with "normal" use it lasted a good while.
  4. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Hey Bobby.
    You're going to see a serious drop in mileage during the winter. I've suffered through the last nine winters up in Lake County and trust me, if you see 50mpg you're lucky. I normally expect closer to 45mpg.
  5. Bobby T
    Bobby T Junior Member
    Chicago
    Thanks for letting me know. This is something I expected. Also, the electrical system warning light just came on. On to the dealership I go tomorrow at Naperville Toyota. :(
  6. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,182
    Wembley, London
    The winter drop in MPG might appear drastic, but literally every car suffers dramatic drops during winter. Where some standard cars might even get as little as 15 MPG or even less, at least the Prius II will give around 40 MPG - no less than 35 for sure. No matter how you look at it, Prii reduce our fuel costs substantially. Example: my old Mazda MX-3 1.6 gave me 180 miles out of 45 litres of fuel in cold UK winter months. The Prius gives me over 450 miles for the same amount of fuel in winter. It's a winner! :)
