When turning I feel power loss, wondering if thats normal?
Discussion in 'Gen 2 Prius Main Forum' started by Jeffrimerman, Jan 30, 2014.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    When making lefts and I think rights I can feel the power cut out sometimes. It's always done it so I was thinking it was normal. I was wondering if there is a cv joint that could be wearing out, but it would do it all the time versus just turns I would think.
  2. Patrick Wong
    18,199
    6,464
    Not normal. What is the fuel tank level when this happens?
  3. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    It's a full tank. I think it does it at all levels. I'll have to feel if it is power to the wheel or total power. What could it be?
  4. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Can it be traction control cutting power? Can I shut it off to test?
  5. Patrick Wong
    18,199
    6,464
    Well, if the fuel level was low, maybe the fuel pump is not picking up fuel when the fuel sloshes around. Since that is not the issue, check the engine oil level on the dipstick.
    The traction control light would turn on (which is the car with a wavy track below it) if traction control was an issue.
    Do any warning lights appear?
  6. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    No warning lights. I'll check oil and check if lights come on when I turn and report back later. Thanks for you help
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Do you mean the power cuts out to the engine or do you mean the power cuts out to the steering?
  8. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Jeff,
    If it is the traction control triggering there will be a momentary flash of the yellow "wheel slip" icon on the dash. This is a common occurrence in a Gen2 when accelerating into traffic while turning if a front wheel slips (sand, ice, bump ... ). It can also be caused if you have mismatched tire diameters.
    JeffD
  9. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Thanks Jeff,
    I think it's what you describe with the accelerating into a turn. I'll check tire pressure also. I think it tends to kick on more if one tire is too low relative to the others.
    Jeff
  10. Patrick Wong
    18,199
    6,464
    If this is the problem, then the solution would be to get better tires and keep them properly inflated.
  11. JC91006
    16,470
    8,383
    What brought you to think this was not normal all of a sudden, since thinking it was normal behavior before? How long have you owned the car?
