Where can I find hybrid battery charger
Discussion in 'Gen 2 Prius Technical Discussion' started by blue 04, Oct 4, 2014.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    With instructions (Not the best) and the man that sells them is always quick to respond via email. I know, because I had a question
    49,090
    perhaps you can pass that along to blue 04.(y)
  3. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I would but it's been like 8 months and I've lost the sheet. But Blue 04, I might be able to help you from memory. I you'd like you caprivate message me
    49,090
    i would love to caprivate you.:love:
    ColoradoCrow likes this.
  5. blue 04
    blue 04 Junior Member
    26
    Huntsville Alabama
    It's from Venice California! Venicehybridtech. It doesn't discharge so I'm trying to figure a way to discharge my Prius battery.
  6. bisco
    49,090
    venice? i've been there. foreign land, no?:p
  7. Mr Mik
    Mr Mik Junior Member
    43
    Australia
    The charger shown on page one (From the PriusChat Shop) is in my opinion not safe.
    The charging cables should be terminated with diodes at the battery terminal end, so that discharging through the cables is impossible.
    Regarding deep discharging: This can be done by putting the transmission into N and then adjusting the current draw by turning aircon, lights and other power consumers on or off. A slower discharge rate would be preferable (I could not get it to go below 1.7A), but it is better than nothing. It might be possible to supplement the 12V system with an external charger or power supply to reduce the current draw on the HV battery, but I have not tried this.
    If the battery is well balanced, each cell gets discharged down to about 1.2V. If the battery is not so well balanced, then some cells will reach a lower voltage than 1.2V.
    See below Torque app screenshot taken just before the hybrid system shut down the DC/DC converter while discharging in N mode (2008 Prius):
    And next a screenshot taken about 20s later, DC/DC converter is now off, not that HV battery current has dropped to 0.1A (from 1.7A) and 12V system voltage has dropped to 12.1V (from 14.0V when Dc/Dc converter was running):
    #27 Mr Mik, May 23, 2015
    tarita virtue likes this.
  8. kiwi
    kiwi Member
    245
    85
    New Zealand
    Building charger for traction battery is not that hard. I designed and built my chargers from tested and certified quality power boards, blocks and components made in Japan and South Korea.
    Input: 100-240V AC - they will work worldwide. Isolated, OVP protection. Constant Current. Different models provide different voltages (for Prius, Camry, Lexus, Highlander and Honda) and currents - from 1 to 2 and also 6-8 amps in my own stationary set up.
    Model for Lexus is not displayed on my site yet. That one is operated from 12V DC or from 100-240 AC with optional power supply.
    For interested garages in USA - I can ship to US or you can have vacation in New Zealand and bring one back home. See Testing Complex - HYBRIDS
  9. Lionelbuffman
    Lionelbuffman New Member
    Australia
    i-Tech
    Hey there everyone! Sorry to resurrect an old thread like this, but this seemed like a good place to ask - I've only just purchased a 2012 model Prius C this week, does the PriusChat traction battery charger work with the Prius C?
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,210
    Madison, Wisconsin
    Do you already own a charger?
    There is not a Priuschat branded charger.
    I think you mean the Hybrid Automotive brand charger?
    Depends on which version you have.
    If you are trying to ise thier gen2 Prius charger, you would likely need a different connector harness.
    Noatter what brand you have, I would c ontact the mfg of the specific charger to be sure.
  11. Danny13pruisc3
    173
    27
    maryland
    how much shipped to USA?
