Which plug is the engine block coolant drain??
Discussion in 'Gen 3 Prius Fuel Economy' started by kswebb1, Jan 15, 2012.
  1. kswebb1
    kswebb1 Junior Member
    33
    Ohio
    Ok is the coolant drain the one closer to the pass side??Behind that bracket that holds up a small wire harness coated in green locktight i guess??
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    From what you are describing that sounds right because I remember it is just above and behind a bracket holding an electrical connector. It is on the firewall side, closer to the passenger wheel and up higher than I would have suspected. It is also a brass plug which stands out if you can get a flashlight on it.
