while i have the HV battery out of my gen1
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Aug 14, 2013.
  1. bwilson4web
    16,044
    I am not familiar with that charger but I would call that module dead.
  2. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    thanks bob! can you explain how on your "module notes list" of d/c capacity readings you came to the conclusion that your 2nd cycle was the actual Ahr? for ex. module #27 is 3.670 Ahr and your notes list shows D2 is 3670, module #28 is 3.907 Ahr and on your list it shows D2 is 3907, and so on for the other module? i seem to be missing some basics here. my apologies.
  3. bwilson4web
    16,044
    3.670 Ahr = 3,670 mAhr (milliamp hour)
  4. ChapmanF
    17,493
    Hmm, my reading of the question was more like "why D2?".
    Here's my stab at it: It looks as if Bob only did two cycles: D1, C1, D2, C2. D1 wouldn't tell you what you want to know about the full module capacity, because it would be starting from an unknown charge state. You wouldn't estimate capacity from the charge values because batteries have inherent losses - you'll always put more in than the capacity you'll be able to draw out. Since he didn't run more cycles, D2 is the only number left to measure the capacity available to discharge from a just-fully-charged module.
    If he had run more than two cycles, there would be more of a question of which Dn to use ... or an average of the Dns, or an average of the last 3 Dns, or whatever. But in this case D2 is the only choice.
    -Chap
    bwilson4web likes this.
  5. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    yes chap! thank you, that was exactly my question and i now understand the reasoning. although i do see a line on his cards where below it looks like he ran another 2 cycles? ...trying to get into the minds of you electrical engineers is no easy task. lol
  6. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    sorry folks! i actually missed the whole paragraph where bob explains his process and how he is being conservative by using his first cycle Ahr numbers. i now understand. thank you guys!
  7. bwilson4web
    16,044
    No problem . . . I didn't understand your last question. Chapman got right but let me add a few details.
    I've found that there is no improvement after the first discharge/charge cycle. The second cycle is usually the last one where the metrics have any reproducibility. But as the number of cycles increases, the dV/dt trigger appears to become weaker and Ahr capacity shows no significant improvement. Thereafter I'm seeing variability and possibly a slight decrease in capacity. But in these tests the MRC 989 is really stressing the battery.
    In normal operation, the 40-80% range keeps the NiMH batteries in a 'sweet spot' for long life. But in these automated, capacity discharge/charge cycles, the MRC 989 is going pretty much to the limits. The limits eat into the battery charge-discharge life.
    So when I suggested staying in the 8.0-8.1 V charge range for balancing and well above the 6V/cell discharge limit . . . well there is a method to my madness.
    slimfrancis likes this.
  8. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    Ok. With the 4 modules I have put through 3 cycles I am seeing discharge amp hour capacity numbers such as 00010. I was hoping I was doing something wrong but I think they are just completely dead modules. I will try a cycle with a known good module to be sure. Thanks fellas!
  9. scotman27
    scotman27 Active Member
    735
    81
    PA
    2001 Prius
    ok guys, im back from vacation and checked my voltages as bub suggested.
    here is where we are at.
    Thursday night i charged the battery in parallel to 8.1 v then left it sit for an hour to stabilize then took it out of parallel friday morning. voltage across was 8.02v.
    here is where they rested now since friday.
    1. 7.80
    2. 7.66
    3. 7.69
    4. 7.68
    5. 7.63
    6. 7.64
    7. 7.66
    8. 7.60
    9. 7.63
    10. 7.65
    11. 7.66
    12. 7.87(the one i replaced this was bad)
    13. 7.67
    14. 7.66
    15. 7.62
    16. 7.62
    17. 7.63
    18. 7.62
    19. 7.61
    20. 7.66
    21. 7.71
    22. 7.64
    23. 7.62
    24. 7.62
    25. 7.65
    26. 7.89 (replaced as precaution)
    27. 7.64
    28. 7.60
    29. 7.65
    30. 7.67
    31. 7.62
    32. 7.65
    33. 7.67
    34. 7.66
    35. 7.67
    36. 7.68
    37. 7.73
    38. 7.89(replaced as a precaution)
    so this is where im at. now to group these together. any ideas.
  10. bwilson4web
    16,044
    I would recommend sort by voltage:
    • pair weakest and strongest - this will even out the 19 pairs voltages as much as possible
    • put the weakest pairs on the ends where it is coolest and strongest pairs in the middle
    One last balance charge to 8.0-8.1 and then assemble the pack. Be careful:
    • at least one footer screw per module, CHECK the terminal module polarity!!
    • long buss bar first, careful torque the terminal nuts correctly
    • last sanity check of sense wires
    • as the remaining buss bar pairs are installed, lethal voltages, ~150V DC, become available
    • one last chance to check terminal nut torques, carefully
  11. scotman27
    735
    81
    PA
    2001 Prius
    ok so would I be starting from the middle of the pack based on the voltages above in my last post of resting voltages
    Would i be doing it this way? Figure 1:
    8,18,16,15,17,5,22,6,14,32,11,7,30,33,4,3,37,1,26 middle38,12,21,36,35,13,2,34,20,10,29,27,25,9,23,31,24,19,28
    or would i be taking these paired like this with strongest modules with weakest based on voltages above
    in my last post.
    38-8 (15.49)
    26-28(15.49)
    12-19(15.48)
    1-31(15.42)
    37-24(15.35)
    21-15(15.33)
    3-23(15.31)
    36-16(15.30)
    4-18(15.30)
    35-5(15.30)
    33-9(15.30)
    30-17(15.30)
    13-6(15.31)
    2-27(15.30)
    7-25(15.30)
    11-22(15.30)
    14-32(15.31)
    20-10(15.31)
    34-29((15.31)
    let me know if these above are correct
    and would assemble these so they would go together like this? Figure 2:
    11-22(15.30)
    2-27(15.30)
    33-9(15.30)
    35-5(15.30)
    36-16(15.30)
    14-32(15.31)
    3-23(15.31)
    21-15(15.33)
    12-19(15.48)
    38-8(15.49)
    26-28(15.49)
    1-31(15.42)
    37-24(15.35)
    13-6(15.31)
    20-10(15.31)
    34-29(15.31)
    4-18(15.30)
    30-17(15.30)
    7-25(15.30)
    i hope this does not confuse the heck out of you. Figure 1 is one way i would do it, figure 2 is the other way, let me know which way is correct or if there is a better way.
    as i speak the pack is on parallel charge to 8.1 v
  12. bwilson4web
    16,044
    That looks good. Based upon what we see, the lowest and highest pairs:
    • 15.49 - 15.30 = 0.19 V . . . 0.30 V is the difference that leads to a code
    Assemble working with deliberate but careful speed. We are hoping the remaining, weak modules are not on the verge of failure but there are no guarantees!
    Without any basis in fact, I am hoping that driving the car will help equalize the voltages around the mean.
    Do you have a Prius aware scanner that can read out the 19 module pairs? This will make it much easier to track the health and progress as well as identify any problems that happen early.
    You may want to take the remaining pair and using your charger, measure their Ahr capacity. Be sure and put them between clamped boards. Use small charging currents, say 0.15-0.25 A as they are likely to be weak. Consider these your 'on hand' replacements if one or more of the other weak modules 'gives up the ghost.'
  13. scotman27
    735
    81
    PA
    2001 Prius
    ok great! i will do that with the modules in figure 2 correct?
    my prius scanner is my scanguage 2, i can read voltage high/ voltage low, block high/ block low and if i want to i can put on xgauges to read each module pair voltages.
  14. bwilson4web
    16,044
    Not sure, can you make that a link?
    Consider putting in the 19 reads. The reason is after you do a sanity check, drive for a week monitoring the high/low pair and voltages:
    • BEST - the low/high indices change between 2-3 different values and; high-low voltages seems constant < 0.20 V
    • GOOD - the low changes between 2-3 different values and; high-low voltages stay < 0.30 V
    • OWCH - the low value and high index are stuck on single values and; low/high voltages close to 0.30 V or higher
    • CODE - and one module pair is 1.2V low . . . <gerrrr>
    What we're looking for is the optimum, 'balance charge' voltage. Record the 19 module pair voltages as much as possible both at start and end of trip. My data suggests 8 V/module, close to 304 V total is a good place to start. But as you've seen, there is self-discharge overnight. So taking some metrics gives us a clue if the balance charge should be a little lower or higher.
    "ev_Cor" has done full-pack charge using a high voltage supply and might have some insights to share.
  15. scotman27
    735
    81
    PA
    2001 Prius
    well I'm at work now but I have the pack paired together and assembled but its in parallel so I can do one last parallel charge tomorrow and then put it back in my Prius and fire it up. then I'll work on getting the capacities of the two models that were weak in my pack
  16. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    hello folks! (and of course bob wilson our mentor)
    here are 3 cycles worth of mili-amp hour readings i took from my supermate dc6 on a 2005 module:
    D1 2922
    C1 4705
    D2 4552
    C2 4828
    D3 4638
    C3 7249
    is it correct to say that the amp hour capacity for this module is 4.552 Ahr and that this would be a good working module? i know 6.500 is the ideal capacity for a perfect module.
  17. scotman27
    735
    81
    PA
    2001 Prius
    bob,
    im discharged my one weak module from 7.34v to 6.0v at .30amps and it came out at 385mah after 77.5 mins. i am now charging it at .30amp. what voltage do i stop it at? 8.0v, 8.1v, 8.2v or 8.3v?
  18. scotman27
    735
    81
    PA
    2001 Prius
    charged it to 8.15v at .30amps, i stopped it there at 227 mins for a total of 1088mah charged. when i return, ill discharge it.
  19. scotman27
    735
    81
    PA
    2001 Prius
    well i didnt duscharge it, im afraid to because my superbrain 977 cannot do programmed charge/ discharge cycles using voltage and temp. so i would have to be with it to keep an eye on it and with the amount of time it takes, its nearly impossible to complete a charge /discharge cycle with work and all so i may go get another charger that will allow me to set it up for 3 cycles at .30 amps 6.0v low discharge voltage/ 8.15v high charge voltage.
    anyone know of a decent charger that will do this.
  20. bwilson4web
    16,044
    Perhaps it is less important to worry about the two 'spare' modules and concentrate on getting the traction battery in and the car up and running. Work with 'deliberate speed' . . . not haste, not rush, but deliberate speed.
