Who has done their recall?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Feb 15, 2014.
  1. Gary in NY
    Gary in NY Member
    153
    Poughkeepsie NY
    I had mine done Saturday (and I haven't even received the recall letter yet). I was there about 2 hours, but I did arrive 15 min before my appointment and the car didn't get in to service right away, and I had a state inspection done during this time too. I notice no difference after the update, but I did hear that someone else thought their traction control was more limiting than before, and the car didn't go through snow as well. My traction control actually kicked in when I arrived home after the update, because I've still got some ice and snow on my driveway. I didn't notice any difference in performance myself, the car got across the ice and kept moving.
  2. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I had mine on Friday. I've noticed that the SOC indicator reads higher than I recall in the past, but I haven't noticed other performance-related changes.
    I did get two "KEY DETECTED IN VEHICLE" messages on the drive to work this morning. Wth?? this has never happened before. Both came on while I was driving (obviously, the key was in the vehicle!), and I pulled over and restarted the vehicle for the first one (warning cleared). On the second one, I just kept driving and it cleared by itself after a couple of minutes. If this keeps up, I'm going back to the dealership and complaining.
  3. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    Your tailgate not close completely, open and close the hatchback again. this happen to me "once" when I didn't give it a push to close the gate. Hope this help.
  4. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Thanks for that tip. I'll check & reclose the hatch before heading home today. In 4.5 years of ownership, this will be the first occurance.
  5. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I had mine done this morning. Took about 40 mins. He downloaded the file to his laptop to flash the system and then he put a Batt. charger on the aux. battery before proceeding. I asked him about it and he said that if for any reason the aux. battery gets low, it could cause the flash to stop or intermittantly stop and create errors or completely crash the Prius computer which would lead to a replacement.
    So far I see no change in anything before/after the recall procedure.
  6. Nutstoyou
    Nutstoyou Junior Member
    34
    Southern California
    Just wanted to follow-up with the group here, as I've noticed a couple of changes (for the better) in my Prius since the update.
    1. The care feels much smoother during acceleration, before the update it was smooth, but now it is smoother...I know this sounds weird...but that is the only way I can describe it.
    2. The battery status bar hardly moves at all, it stays at 1 empty bar from the top....even in stop/go or stop/crawl traffic, that bar stays the same. I have seen it drop to 2 empty bars for a very short time, but then reutrns to 1 empty bar very quickly.
    I drive in "power" mode at all times. Please do not get me wrong here, I am quite pleased with the changes I see in my Prius....I just love my Prius.
  7. Denver Corrick
    Denver Corrick Junior Member
    North central Ohio
    I called my local dealer about 9:00 this morning, and set up an appointment for first oil change, tire rotation, and the recall software update. He told me to have it there at 4:30 PM today. I arrived with the car at 4:20, and drove it out at 6:00 sharp with all work completed. The tech that brought the car around complained that the software update was very slow on my car, but it finally took. I asked how he could be sure it took, and he said, it would not start if it did not take properly. The dealer report shows "SOFTWARE UPDATE FOR MOTOR GENERATOR ECM AND POWER MANAGEMENT ECM 2010-2014 PRIUS AGGO9A .7 SSC AGG09A CONFIRMED COMPLETE". I can see no difference at this time with the update in place.
  8. nedear88
    246
    142
    2/24 ****UPDATE****
    After a few days of driving observing with the new software, the most noticeable different is gas pedal input ratio changed, I actually have to slow down even with ECO mode, I am still monitoring the MPG, my current MPG is dropping with the same route, same commute to work, I suffer 3-4 mpg lost after the software update. I will post update next few weeks.
  9. Lawrence S.
    Lawrence S. Junior Member
    Old Bridge, NJ
    I went in to Freehold Toyota in NJ on 2/24 for my 10k service and mentioned the recall. The service rep said that they had a "call" from Toyota in the morning to stop doing the software update because it was causing driveability issues with the Prius. Skeptical, I also asked the Service Manager who said the same thing. Apparently, I am to "ignore" the recall letter I may get from Toyota and wait for a 2nd recall notice that will eventually update the software a second time.
    snead_c likes this.
  10. Bwrx
    Bwrx New Member
    For those people that have gotten the recall done, does the toyota website indicate that the recall has been done?
    I got the recall done Saturday but the toyota website still lists it as an open recall that hasn't been completed for my car.
    Anyone know if there is a way to tell if the recall has been done from inside the car? I haven't noticed anything different other then when I got the car back the traction battery indicator was only showing two bars of charge (when I dropped it off it was almost full) and that Eco mode which was previously enabled was switched off.
    Thanks
  11. myPriusAcct
    myPriusAcct Junior Member
    29
    17
    Well this is a pretty huge development. Could Toyota really screw up this badly? Has anyone else had the same message from their dealer?
  12. Hoosiermama
    Hoosiermama Junior Member
    39
    My update was done last night. It took a little over an hour and included the 20,000 mile service and oil change. The dealer didn't mention anything about Toyota notifying them not to do the update.
  13. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    I got my update done on Saturday and it seems to drive the same (at least to me). I believe the techs removed the lower glove box to gain access to the ECUs to do the recall software flash as my glove box was jostled a bit. Now whether they removed ECUs to do this or there's an access port under there, I can't say. I have looked in there in the past and it looks allot like a miniature "blade" server with several ECU modules in slots.
  14. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    I'm glad I read to page 6 of the thread...will wait for 1st and 2nd letters before visiting my dealership.
  15. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Pretty sure the guy above who says you need 2 letters etc. and dealers are stopping doing the recall procedure is just trolling. I've heard of no drivability issues with anyone who did the recall, don't believe everything that you read here.
    KingToph and snead_c like this.
  16. Fore
    Fore Don't look back!
    494
    107
    Had mine done this morning, no notable difference at this time. NO recall letter needed. Who knows if they actually did the software update. I was told by an Toyota employee that recall work is a big money maker for the stealerships.
  17. KingToph
    KingToph New Member
    Kansas City, MO
    QFT
    This would have been all over the news again.
  18. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Though my work location has changed resulting in a much shorter commute, I'm seeing what could be a definite hit on my MPG after the update. I'll do my old long commute on Thursday of this week and check mileage afterward.
  19. BZzap!
    BZzap! Senior Member
    1,607
    878
    I'm schedule in for tomorrow morning, first light. Taking it in to Longo Toyota. Called it in yesterday with no questions asked. If you haven't received a recall notice, don't wait. Just get it done. The dealer data base will confirm the recall with your V.I.N..
  20. Mendel Leisk
    40,939
    For Canadian perspective:
    I emailed our service manager, included link to Toyota Document on the subject of the software recall. He acknowledged something's happening, that our vehicle's effected, but said to wait, they're not set up yet, and that there should be a letter sent out. And if the letter doesn't come, call, say in about 3 weeks.
