Featured Why the auto industry is in trouble
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 11, 2016.
  1. CR94
    CR94 Senior Member
    2,642
    1,136
    Northwestern S.C.
    Likewise with catalytic converters (1975 model year), closed-loop fuel systems (1981), etc.
    Robert Holt likes this.
  2. telmo744
    telmo744 HSD fanatic
    2,170
    764
    Portugal
    I find it very hard to stop burning fuels to power our transportations needs, because there is no single viable solution. BEVs and FCVs can "decarbonize", but both will depend on primary sources being renewable. The other solutions are...half solutions, meaning ICE powered vehicles have its share of responsibility. Hybrid cars pose a good way of saving fuel, PHEV even more. Prius itself (3 million sold, some 2 million operating) has saved the equivalent of dozens/hundreds of thousand BEV cars on the road, technically speaking.
  3. TomSwift
    TomSwift Member
    37
    Louisville, KY
    2014 Nissan LEAF
    You're right. There isn't a solution available, today, that would supply all the energy required to meet our transportation needs using sustainable (renewable) energy sources. We would need much more solar, geothermal, hydro, and wind as well as a place to store the energy when the sun isn't shining, the wind isn't blowing and the water isn't flowing, but I believe there are solutions to those problems. I don't think there are solutions to the problems associated with burning fossil fuels to power the transportation sector.
    BEVs and FCEV (perhaps) can be fueled with "decarbonized", renewable energy. As far as that goes, one could "unburn" CO2 and water to produce gasoline for a Prius, but that would be even more energy intensive, "well to wheel" than producing hydrogen for a fuel cell and hydrogen for a fuel cell is probably too energy demanding to make it a viable approach as it is.
    Some companies are working to build a set of solutions that allow us to capture solar energy, store it in batteries or other storage systems, and use it to meet our energy needs. I can't think of any company, besides Tesla, that is working on energy capture (solar), storage, and transportation in one more or less integrated approach, but I suspect that others will follow, if it works out for Tesla.
    Most electrical utilities in the US are retiring coal fired plants and replacing them with other lower carbon producing electrical generation systems or, better still, with utility level solar or wind energy. I believe other countries in the world are doing much better than the U.S. in embracing renewable energy sources. Utilities in Portugal, as I suspect you know, supplied electricity to the entire country for 107 consecutive hours using renewable energy alone. So, there are ways to produce carbon free energy... we just need more countries like Portugal.
    hill likes this.
    49,062
    this doesn't have to be class warfare, we're all in this together.:)
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Actually, there is a very viable solution. It's called > $10/gallon gas.
  6. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    The "first drive" reviews of the Bolt claim it is excellent.
  7. bwilson4web
    15,432
    Let's do a compare and contrast in December when we'll also have the wonderful, remarkable, Prius-killer, IONIQ too. <GRINS>
    Truth be told, we need to have cars at the dealer. Too often the early reports tell us more about the reviewer than the car.
    telmo744 likes this.
  8. telmo744
    2,170
    764
    Portugal
    Haven't worked with $8 in Europe so far...
  9. hill
    8,086
    $8 gas Didn't seem to work too bad - it put much of their folk onto a much better system of public transportation then we seem to even be willing to contemplate.
    cwerdna and telmo744 like this.
  10. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    $8 gas moved europe to diesel, smaller cars, and fewer miles. Percentage commute on public transportation in Europe is actually down. Most of the attitudes and infrastructure differences between europe and the US were in place by 1960
  11. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Incorporate the EU taxation conversion factor. If it is $8/gal in the USA, it would be much higher in Europe.
  12. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    To be fair, in Germany at least the taxation of diesel was apparently intentionally set lower than gasoline by the government to induce drivers to move to diesels for at least the last 20 years or so.
  13. bisco
    49,062
    government induced lung cancer.
  14. Trollbait
    11,360
    The Prius, and other hybrids without a plug, are still ICE powered cars. The electricity they use for propulsion was utlimately made by burning some fuel in its ICE less efficiently than burning the fuel at a power plant.
    In terms of moving from place to place, hybrids can be a big step up over non-hybrids in reducing fuel use. But without a plug, they will never be efficient enough to allow the 100% shifting of the fuel used in their ICE from non-renewable sources to renewable ones. A hybrid fleet without electric grid input would still require too much fuel for renewable fuels to be made sustainably and be economically acceptable.
    TomSwift likes this.
  15. hill
    8,086
    duno - haven't been to fhop for maybe 2yrs - but it sure seems we're not together in there
  16. bwilson4web
    15,432
    I would be cautious about such claims as the thermodynamic efficiency of power plants has a wide range and often dependent upon having waste-heat market or topping cycle. Not to have 'heads explode' but a Prius operating in cold weather can have substantially higher efficiency when the cabin heat from the engine is added to the efficiency metrics.
    Robert Holt and telmo744 like this.
  17. Trollbait
    11,360
    I was thinking of the 50% to 60% thermal efficiency of a natural gas fired turbine. Combined cycle for heating, such would be 95% or higher.
    While some of the electricity of a hybrid is generated from braking energy that is normally thrown away, the ICE of the current Prius peaks 40% thermal efficiency.
  18. bwilson4web
    15,432
    I went to: What is the efficiency of different types of power plants? - FAQ - U.S. Energy Information Administration (EIA)
    Using their formula and data for 2014:
    system Coal Petroluem Natural Gas Nuclear
    1 Steam Generator 33.8% 33.6% 32.8% 32.6%
    2 Gas Turbine -- 25.4% 30.0% --
    3 Internal Combustion -- 32.8% 36.4% --
    4 Combined Cycle W 34.4% 44.6% --
    The data suggests a natural gas fueled, Prius engine would be in peak efficiency group. Co-located at a home to provide space heating and hot-water, it would be nice 'Combined Cycle' solution
  19. austingreen
    13,533
    4,063
    Austin, TX, USA
    Although that is good data its the wrong data.
    What are we building -
    Wind adds the most electric generation capacity in 2015, followed by natural gas and solar - Today in Energy - U.S. Energy Information Administration (EIA)
    In 2015 new capacity was 41% wind 26% solar and 30% natural gas. In 2014 gas was 44%, wind 26%, solar 27%. What about coal? Well more coal was retired than was built and I would expect that to accelerate. The same goes for petroleum.
    Now this new gas is mainly 58%+ efficient unless it is cycling bellow 40%, and has around a 70% utilization. Why would it cycle low? well to react to all that wind and coal of course. If we use 35% utilization for wind and 20% for solar in 2014 we get 68% of new power generated was natural gas, and just about all the other new power was renewable.
    Now the model S 70D gets about 102 mpge when we multiply out @44% natural gas ignoring all the renewable and that the new stuff is closer to 54% efficient we get 45 mpge natural gas well head to wheel or about the same as oil in a prius eco 56 x 84% (oil to gas) = 47 mpge oil well to wheel. If we use the new grid natural gas/wind/solar the tesla is much lower impact. If we use old coal steam power plants the tesla is much worse.
    Its a tough nut to crack. Do we count mainly the 60 year old power plants to fuel the cars, or what we are building today. Further complicating the hybrid is cleaner for the future language, is in many states like california and texas power is already lower in ghg, and these states have most of the plug-ins.
    What are the bad states? Ohio, Indiana, Kentucky, West Virginia, Missouri as for having over 60% coal and a lot of coal burned.
    #79 austingreen, Aug 23, 2016
    TomSwift and bwilson4web like this.
  20. bwilson4web
    15,432
    I understand where @austingreen is going but the numbers, especially the percentages, get a little ... difficult to follow. Heat engine thermodynamics is easy but mixing non-heat engine sources into the mix is not so straight forward.
    Of course it might be amusing to consider the sun as our heat source and calculate the efficiency of a PVC or wind turbine ... BIG denominator. <GRINS>
