1. Offline
    Hurricane Gio New Member
    Start a Conversation
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    My wife's Prius V 5 came with 17" wheels, which look great. Now, I am fine with the low-profile 5o Series tires. By why the W rated tires? These are harder and rated higher than Z rated ones.
    H or even V rated tires are more than adequate on a Prius. ;)
  2. Offline
    jdenenberg EE Professor
    Nov 21, 2005
    2,058
    508
    Trumbull, CT
    Your Vehicle Year:
    I buy H- rated tires for all my cars. They are stronger than S or T ones and are still reasonably priced. Higher rated tires are wasteful on a Prius (max speed 104 MPH).
    JeffD
  3. Offline
    firepa63 Former Prius Owner
    Jul 23, 2005
    1,761
    192
    SE Pennsylvania
    Your Vehicle Year:
    Are they 'run flat' tires?
  4. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    Nope
  5. Offline
    Aug 14, 2006
    18,119
    3,433
    Sacramento, CA.
    Your Vehicle Year:
    Is there a load rating difference between the V and W tires? Is there even a lower rated version? available?
  6. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    OEM tires are usually of poor quality - it's not just Toyota by any means. I can only assume they're chosen for mileage ratings and cost. An extra few hundred dollars of profit on each car would really add up.
  7. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    No idea. But i assume the 17" 50 series would be lower than the 16" 60 series tires.
  8. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    My 93 Honda Civic Si came with nice OEM tires, as did my 2000 Jeep Cherokee ann my 2004 Ford Explorer. All came with TOL tires, IMO.
    Now my 2011 Subaru Outback, comes with ok OE Continental tires.
    The Toyos on the Prius v 5 look nice and so far feel great. Toyo makes some nice tires.
    My point is why put High Performance Street tires on a Hybrid wagon?
    Same with my neighbors, Mazda 5. Falken HP Z rates low profile tires.
  9. Offline
    Aug 14, 2006
    18,119
    3,433
    Sacramento, CA.
    Your Vehicle Year:
    There are not a lot of cheap LRR 17" tires out there so maybe these were as close as you could get to LRR while still being cheap. I would think that price negotiations between the two manufacturers also played a large role in the decision.
  10. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    With the Gen II Prius, Toyota specified higher rated tires because of the weight of the front end. Perhaps they did the same with the newer Prius.
    Tom
  11. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    I guess thee are super cheap tires. But I found plenty of reasonably priced tires by Michelin, Goodyear, BF Goodrich, Kumo, Cont, Pirelli, Yokohama, Dunlop and Bridgestone in a V rated tire. Even a few H rated form Michelin!
    Hopefully we can get 20K out f these OEM tires.
  12. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,416
    1,298
    Northern California
    Your Vehicle Year:
    The primary market for those sized tires isn't low performance cars.
    Higher speed rated tires usually give better handling and some people get the 17 inch option for the better handling.
  13. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    Speed rating are about maximum speed compared the the vehicles load.
    Speed rating
    The speed symbol is made up of a single letter or an A with one number. It indicates the maximum speed at which the tire can carry a load corresponding to its Load Index
  14. Offline
    Aug 14, 2006
    18,119
    3,433
    Sacramento, CA.
    Your Vehicle Year:
    I think a lot of people will switch out the worn oem tires for the Primacy MXM4 once they read the reviews.
    There are a lot of tire options out there. Some are cheap, some perform well, some are very efficient and some have great longevity. You usually only get to choose 3 of those 4 characteristics. :)
  15. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    Not a normal driving speeds. No really. I have had HR rated tires handle better than Z-Rated tires when I had my Rice Burner Honda Civic Si back in the day. that's not true. its about top speed!
    So why would toyota design a car to use 15-16" wheels, then be forced at the FACTORY to put HP/LP tires to get 17" to work? Design the car with the max wheel sized desired form the factory, add use the appropriate tires. No if some looking for AFTERMARKET wheels, then they can cram 18' or 19" wheels if they want.
    Look at the Venza. Stock 20" wheels and they are NOT HP/LP tires on any model. IMO, Toyota messed up here with factory 17" wheels with a W speed rating. Toyo could make the same OE tire for Toyota cheaper and a more appropriate speed rating.
  16. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    that's the tire I am thinking of. I love Michelin tires and prefer them over any other one. Can't wait to ditch the Conti tires on my 11 Outback.
  17. Offline
    Aug 14, 2006
    18,119
    3,433
    Sacramento, CA.
    Your Vehicle Year:
    They come in both V and W ratings. :) I got the V, obviously.
  18. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,416
    1,298
    Northern California
    Your Vehicle Year:
    Most 20 inch wheels are sold for the bling factor.
  19. Offline
    Nov 8, 2011
    38
    Miami
    Your Vehicle Year:
    Sure. But I am taking about OEM, not AM. Look at the Venza the the Infinity F series SUV.
    20" regular profile tires.
  20. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,324
    1,766
    Queens, NY
    Your Vehicle Year:
    You didn't know Prius v can hit 149 mph? j/k
    1 people like this.
Share This Page
